Re: X-Life ver.2 Early BETA 1,2,3, RC1
laohu314 wrote:J.A.Romanov wrote:apt.xlf - what is this? You mean as example EDDM.xlf ot like LDDU.xlf? If yes - please understand what if file EDDM.xlf exist in /Airports/ folder it will NOT overwrite from server.
Sorry, I was a bit unclear. I made a KBOS.xlf file by using Airport Editor and saving the file. I had removed the KBOS.dat and KBOS.txt file but when I restart XP, the KBOS.dat and KBOS.txt files re-appeared, so I was assuming that they were downloaded from the server. They KBOS.xlf file is still there too. I have added screenshots before and after starting XP.
Understand.
Yes, that file will be download again if deleted before. But if .xlf file for this airport is exist, plugin will read it only and just ignore .dat + .txt files
Ah, that's good to know. I thought it would still use the .dat file. All is well then. Thank you for clarifying!
