Re: X-Life ver.2 Early BETA 1,2,3, RC1
JAR wrote:
apt.xlf - what is this? You mean as example EDDM.xlf ot like LDDU.xlf? If yes - please understand what if file EDDM.xlf exist in /Airports/ folder it will NOT overwrite from server.
Sorry, I was a bit unclear. I made a KBOS.xlf file by using Airport Editor and saving the file. I had removed the KBOS.dat and KBOS.txt file but when I restart XP, the KBOS.dat and KBOS.txt files re-appeared, so I was assuming that they were downloaded from the server. They KBOS.xlf file is still there too. I have added screenshots before and after starting XP.
Understand.
Yes, that file will be download again if deleted before. But if .xlf file for this airport is exist, plugin will read it only and just ignore .dat + .txt files
Ah, that's good to know. I thought it would still use the .dat file. All is well then. Thank you for clarifying!
FMCar update
I had a CTD three times in a row trying to load Xlife 2b3 at EGPH.  I am using X-Plane 10.51 and tgd's EGPH for X-Plane 10 found here: http://forums.x-plane.org/index.php?/fi … irport-uk/
I have the dat and txt files installed from jardesign.org.  Log.txt attached.
Thank you in advance for your help.
Ron West
KBNA
Ron West
KBNA
You need open your EGPH.txt file and read strings what begin with
S,23, ...
S,24, ...
You will see what that stand names are ubnormal. I think this error come from initial apt.dat file
30
Ron West
KBNA
S,23, ...
S,24, ...
Thank you for checking the CTD report.  I will look at these two lines.  Right now my computer skill may not be enough to make the repair.
Ron West
RC1 just posted. You may update .xpl files (attached to first post).
We just add check taxiroute network during save operation:
- if two points very close but not connect
- if not connected end of the line not have gate/stand
- if gate too far from nearest taxiline point
- if there is no holdshort marked lines exist between runway and taxiways
Nice  thank you i will testing now smile
Ron West
KBNA
S,23, ...
S,24, ...
Ron West
JAR,
I made corrections to the EGPH txt file.  Thank you for the tip.  Will report findings in http://jardesign.org/forum/viewtopic.php?id=2245
Ron West
Hi EFHK-ESSA goes very well, fps drop goes much slower than before. That is nice 1h when fps drop goes from 60 to 19 and locked there, before that time was 20 min. good night.
i forgot mention plugin setup it is xEnviro + JD320+ xLife+ 2 or 3 smaller plugins
36
To understand where FPS drop come need use only X-Life and Airbus (turn Off all other, include default traffic)
37 (edited by wesader 2017-07-06 16:38:37)
Hi. JDa320 stadionary mode in EFHK at start fps above 50 and plugins only what xlife and airbus need, when i start xlife traffic comes tiny fps drop what is naturally. and after 20 minutes it start going below 30. i have pics but cannot add here cuz size limit.
ah. i forgot mention at my version of game is X-Plane 11 11.02r1
And what is your computer configuration? What is your videocard?
Next.. What will happen if you:
- turn off traffic
- set all traffic settings to minimum?
- set CAVOK weather?
And the last quest.. What you expect from me?
40 (edited by wesader 2017-07-06 21:01:45)
https://www.msi.com/Motherboard/Z170A-X … o-overview
https://www.msi.com/Graphics-card/GeFor … o-overview
http://www.overclockers.com/g-skill-rip … it-review/
https://ark.intel.com/products/88195/In … o-4_20-GHz
2 pcs corsairs 250GB ssd drivers
Corsair Rm750i PSU
corsair H110i liquided cooler
at now system was not overclocked cuz i wanted reliable results, but when i was read forums i figure out at X-plane11 have fps leak anyway without plugins.
41 (edited by wesader 2017-07-06 21:20:41)
when i turn off traffic soon after when i put it on fps rise from 45 to 55 about but when i let it goes to 19 it locked there and never came back again even i turn off all plugins.
Dosent matter if i set all traffic option to minimum and all graphic settings also same happend, but fps start leaking when i turn x-life a live and using ATC and all other options what include it.
i need check that cavok weather option. But i it is option in xenviro.
I dont expect nothing special from you.. i wanna let u know issues if someone else have not this kind of issues then in my system or acting are something wrong i am still new with x-plane, before i was simulating with msfs simulators sense ms98 or 95 came out many years ago if we dont count c64 flight simulator over 30 years ago.
Just trying to understand the new functions. If you use one of your own Custom Scenery airports, the airport editor is reading that .dat file? And then you can edit that airport taxiway network using the editor? Hopefully a manual will be made available soon, thanks!
Ok, good. This is interesting for me. You may contact me skype j.a.romanov
Sure, you may try different settings for your videocard (try different optimisation) and try to tune/change your computer multithread optimisation. I never try by myself, i am on MAC, but i have several reports about successful with this way.
44
Search/read airport data way is follow (as eXample it will be EDDL airport):
- From EDDL.xlf if this file exist in /X-Life/Airports/ folder
else
- From EDDL.dat and EDDL.txt (old format) if this files exist in /X-Life/Airports/ folder
else
- From apt.dat if this file exist in /Custom Scenery/EDDL Dusseldorf ../Earth nav data/ folder
45
Thank you for all your opinions and info!
We just switch to release http://jardesign.org/forum/viewtopic.php?id=3222
