251 (edited by screetch82 2016-02-27 15:10:31)
some more crashes:
JARDesign Ground Handling 3D Sound Engine Disable
JARDesign plugin: E:\X-Plane 10\Resources\plugins\X-Life\Metar/EDDH.TXT file updated.
GroundHandling CarClass error: DRF not found: sim/custom/xap/doors/bulk_kn
GroundHandling CarClass error: DRF not found: sim/custom/xap/doors/c_f_kn
GroundHandling CarClass error: DRF not found: sim/custom/xap/doors/c_b_kn
Failed to open E:\X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/heavy/b767-300/jal/object.obj: the file cannot be opened.
X-Life Object load error: E:\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/heavy/b767-300/jal/object.obj
SkyMaxx Pro: Memory Check: 283072 KB GPU, 19336192 KB CPU
SkyMaxx Pro: Memory Check: 291072 KB GPU, 19353256 KB CPU
252 (edited by ivota 2016-02-27 15:19:39)
I did another test filght with X-LIFE plugin. Also I used GndHandling and FM plugins.
No CTD.
Please looking only x-life plugin as test (not my flight, he,he).
Here is my suggestion and report bugs:
- ATC window (active ATC should be coloured (GREEN))
- AI Ground traffic seems aviod colision when Transponder and TCAS is ON , What happen If TCAS is OFF ?(After vacated Ground asked us to turn off-possible collision).
- ATC APPROCH should switch us to CENTER ATC after passing FL (140 - depend of local rules)
- When flight end, no contect ATC to disconnect (say goodbay, or other like any information (local time, weather ...)
- X-life seems only recognoize ILS (VECTOR, NDB, VOR...I know this will be maybe in future).
- I cannot remember...see my video test.
Thanks JAR for excelent idea, plugin.
Sorry if I too critic, You will see What you want to implement.
http://www.twitch.tv/ivota_hr/v/51093481
HERE is LOG:
ATC LOG -----------------------------------
> Pilot: SCHWECHAT Delivery ,CROATIA 6 TANGO, Stand E44, A320, with information Bravo, QNH1013, request clearance
> ATC: Initial Altitude 7000 feet, Squawk 2655
> ATC: CROATIA 6 TANGO, SCHWECHAT Delivery, Cleared to SALZBURG, Runway 11, via OGBA1A departure,
> Pilot: Cleared to SALZBURG, Runway 11, via OGBA1A, Initial Alt 7000, Squawk 2655, CROATIA 6 TANGO
> Pilot: SCHWECHAT Delivery ,CROATIA 6 TANGO, Stand E44, request push and start
> ATC: CROATIA 6 TANGO, Contact SCHWECHAT Ground
> Pilot: Roger, CROATIA 6 TANGO
> Pilot: SCHWECHAT Ground ,CROATIA 6 TANGO, Stand E44, request push and start
> ATC: CROATIA 6 TANGO, push and start approved
> Pilot: Push and start approved, CROATIA 6 TANGO
> Pilot: SCHWECHAT Ground ,CROATIA 6 TANGO, Stand E44, request taxi
> ATC: CROATIA 6 TANGO, SCHWECHAT Ground, taxi to holding short runway 11, via TL36,TL35,L,EX15,M,A12
> Pilot: Taxi to holding short runway 11, via TL36,TL35,L,EX15,M,A12, CROATIA 6 TANGO
> Pilot: SCHWECHAT Ground ,CROATIA 6 TANGO, Stand E44, request FollowMe car
> ATC: CROATIA 6 TANGO, SCHWECHAT Ground, expect FollomMe car 1 minute
> Pilot: SCHWECHAT Ground ,CROATIA 6 TANGO, approaching holding short runway 11
> ATC: CROATIA 6 TANGO, Contact SCHWECHAT Tower
> Pilot: SCHWECHAT Tower ,CROATIA 6 TANGO, approaching holding short runway 11
> ATC: CROATIA 6 TANGO, SCHWECHAT Tower, line up runway 11, and wait
> Pilot: Lining up and wait runway 11, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, Set Transponder, Squawk 2655
> Pilot: Transponder On, Squawk 2655, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, runway 11 cleared for take-off, wind 135 degrees 16 knots
> Pilot: Cleared for take-off, Runway 11, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, contact SCHWECHAT Approach 124.6
> Pilot: Contact SCHWECHAT Approach on 124.6, CROATIA 6 TANGO
> Pilot: SCHWECHAT Approach ,CROATIA 6 TANGO, OGBA1A departure, passing 2500 feet, climbing to 7000 feet
> ATC: CROATIA 6 TANGO, SCHWECHAT Approach, radar contact, climb to FL 70
> Pilot: Climbing to FL70, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, Climb to FL 180
> Pilot: Climbing to FL180, CROATIA 6 TANGO
> Pilot: Ready for Descend, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, Contact  Center
> ATC: CROATIA 6 TANGO, Descend at Pilot's Discretion to FL 120, expect BAGSI arrival, Runway 33 in use
> Pilot: Pilot's Discretion Descending to FL120, expect BAGSI arrival, Runway 33, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, contact SALZBURG Approach 123,625
> Pilot: Contact SALZBURG Approach 123,625, CROATIA 6 TANGO
> Pilot: SALZBURG Approach ,CROATIA 6 TANGO, FL158, descending to FL120, information Bravo on board
> ATC: CROATIA 6 TANGO, SALZBURG Approach, Wrong ATIS Information
> Pilot: SALZBURG Approach ,CROATIA 6 TANGO, FL155, descending to FL120, information Delta on board
> ATC: CROATIA 6 TANGO, Identified, expect BAGSI arrival, ILS approach Runway 33, descend FL 70
> Pilot: Descending FL70, expect BAGSI arrival, ILS approach Runway 33, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, Descend 2900 feet, QNH 1003, transition level FL 60
> Pilot: Descending 2900 feet, QNH 1003, transition level FL60, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, cleared for ILS approach Runway 33, report established
> Pilot: Cleared for ILS approach Runway 33, will report established, CROATIA 6 TANGO
> Pilot: Established ILS Runway 33, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, continue approach
> Pilot: Continue approach, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, contact Tower 123.45
> Pilot: 123.45, CROATIA 6 TANGO
> Pilot: SALZBURG Tower ,CROATIA 6 TANGO with you, ILS approach runway 33
> ATC: CROATIA 6 TANGO, Cleared to land Runway 33, wind 156 degrees 7 knots
> Pilot: Cleared to land Runway 33, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, take taxiway B, when vacated contact Ground 118.35
> Pilot: Take B, will contact Ground 118.35, CROATIA 6 TANGO
> Pilot: SALZBURG Tower ,CROATIA 6 TANGO, runway vacated
> ATC: CROATIA 6 TANGO, Contact SALZBURG Ground
> Pilot: SALZBURG Ground ,CROATIA 6 TANGO, runway vacated
> ATC: CROATIA 6 TANGO, Taxi to E9 via B,L,C,M
> Pilot: E9 via B,L,C,M, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, Set Transponder to standby
> Pilot: Transponder Off, CROATIA 6 TANGO
> Pilot: SALZBURG Ground ,CROATIA 6 TANGO, request FollowMe car to E9
> ATC: CROATIA 6 TANGO, SALZBURG Ground, expect FollomMe car 1 minute
ATC LOG END ----------------------------
Ivo
253
hotfix 1 for beta 8
+ 2 kind of CTD fixed
+ alert if scenery not x-life full compatible
+ “no TOD button” issue fixed
+ engines start period added
254
No CTD.
thanks for feature requests and ideas
255
@Eugeny
Flying from LOWS to LIRF with stop in LIPZ with A330 and xlife beta8 without any problems.
There is only one thing: ATC settings and flightplan settings will not be reseted at arrival airport, means eg. at LIPZ all items (ATC) are from "Salzburg" LOWS and flightplan generating in LIPZ to LIRF doesn´t work, have to import from file.
256
Holding short RW06 at EHAM on route to EGLL and CTD with beta 8 HF1 :-(
257
ctd mid flight
258 (edited by captbullett 2016-02-27 18:53:50)
any of the  plugins could be an issue with X-Life so it is up to you how you want to test the issue and as a member of long standing you know the drill;
Have a most excellent day if I can help please IM me ...
Loaded: E:\X-Plane 10/Resources/plugins/XAdventures/64/win.xpl (XAdventures.BenjaminWhitehead.v1.05).
Loaded: E:\X-Plane 10/Resources/plugins/XPFlier/64/win.xpl (moblisoft.plugin.xpflier).
Loaded: E:\X-Plane 10/Resources/plugins/XPUIPC/64/win.xpl (XPUIPC/XPWideFS.).
Xchecklist: ver 1.09
Loaded: E:\X-Plane 10/Resources/plugins/Xchecklist/64/win.xpl (Michal_Bill.Example.Xchecklist).
Loaded: E:\X-Plane 10/Resources/plugins/efassxpsm/64/win.xpl (efass.xpsm.connection).
SmartCopilot: Starting...
Loaded: E:\X-Plane 10/Resources/plugins/smartcopilot/64/win.xpl (Rhard.SmartCopilot.plugin).
are you running out of Memory ;
Cache coherency: 2510 misses in 6858 indices  and 1749 vertices.
Miss rate: 14.895283%.
    LOD 0: (0.000000 to 1000.000000)
screetch82 wrote:
ctd mid flight
259
Incredible plugin - thank you! I only wish there were more airports completed. Very few in the US at this time. I also am looking forward to the payware addition.
260 (edited by captbullett 2016-02-27 20:16:02)
Using Beta 8, X-Life and the route EGLL/EDDM the flight plan was in the Flight-Plan folder and was generated by an on-line flight-planner.
then it was imported to the X-Life Flight Plan widget from there the X-Life plugin took over the details of the Flight Plan and all went as to be expected.
here is the bbox.txt and the log.txt for data to be use to compare the good with the CTD's
this is a must if the issues are to be resolved .
I also included the screen JPG's of the rendering setting i use on the iMac 27" .
this is my SOP.
Your friend,
Attachment icon Screen Shot 2016-02-27 at 3.05.03 PM.jpg 105.02 kb, 159 downloads since 2016-02-27
Attachment icon Screen Shot 2016-02-27 at 3.05.41 PM.jpg 107.34 kb, 124 downloads since 2016-02-27
261
Hotfix 1 + Beta 8 -> WORKING. NO crash.
EDDL to EDNY no problem with 1 hour watching traffic at EDDL.
looks very good !! No problems at all.
I used your YouTube video to start making the atc routes. I don't know why, in my routes the aircrafts don't make the backtrack correctly, even if I created the route to it. iss it possible to you to verify with one of my files ? Madeira Island is one the airports that they didn't do that. If you need I'll send to you the wed xml file.
Paulo Moreira
PM1970 wrote:
Hi Romanov
Just create ATC routes for LPMA, but this time after start the x-life plugin I get a message saying that LPMA is not x-life compatible, besides this I have from my 6 gates 3 that are busy, for the moment any movement of aircraft. Do you have any idea why does this occur ?
Updated: Just reloaded the simulator, and now it seems ok, no message at all.
Anyway, got a crash with the last version yesterday after few minutes running the plugin and seeing the aircrafts running in and out.
I am not have an idea as nobody (but you) know how you build ATC-taxiroutes. May be some more info may help.
So, this info may be useful for you http://jardesign.org/x-life/www/how-to- … ompatible/
263
screetch82 wrote:
ctd mid flight
I saw that too in the log. but not running out of RAM. I have 32GB and the most it is used is 16GB for. Could only be VRAM then.
264
tAXIING TO GATE AT egll AFTER FLYING IN FROM eham. ctd FOLLOWING THE fm CAR TO THE GATE AT egll :-(
Sorry had caps lock on...oops
265
X-Plane 10.45 is out!
Has anyone using iMac experience with this upgrade and X-Life?
266
So the crash just after the start (as always) Test on my second copy of X-Plane with A320 2.6b4, x-life b8, hotfix1.
Best Regards
267
1) I have x-life now running for > 12000 seconds, no problem. Hotfix works good.
2) I think there is a Problem with integration with FMcar. Look at the picture:
http://jardesign.org/forum/img/m/552/t/p1ack6i9b057l1qepu3f1q0lbo33.jpg
1) is the actual position of the plane
2) Is the start of runway 06. If I call the FMCar by hand and select RW06 (from list), the car guides me from 1) to 2).
3) If I use X-Life ATC and call FMCar from within X-life, the FMCar stops at position 3).
---+++--- Pilot: FRIEDRICHSHAFEN Ground ,USER123, Stand GA 203, request taxi
---+++--- ATC: USER123, FRIEDRICHSHAFEN Ground, taxi to holding short runway 06, via N4,N,F
---+++--- Pilot: Taxi to holding short runway 06, via N4,N,F, USER123
---+++--- Pilot: FRIEDRICHSHAFEN Ground ,USER123, Stand GA 203, request FollowMe car
---+++--- ATC: USER123, FRIEDRICHSHAFEN Ground, expect FollomMe car 1 minute
Looks like the FMCar is send to F, not to RW06.... Is it possible that the FMCar gets the last via instead
of runway ?
268 (edited by captbullett 2016-02-28 15:23:00)
I think I have been using this X-Life since Beta1 Public or what ever the first version was and have used with the XP 10.45 both r1 and r2 and the Beta 8 and the 10.45r2.  and I am using 10.10.5 OS X So then, you ask a question you should complete you thoughts so I can give you a good answer with-in this one post and in a timely manner.
Thereby, there is a flow to the conversation. you might think I am being mean but in fact I am busy testing, and trying to answer as many question not only for X-Plane and JAR but as an Apple developer I have many other people I talk to in a day I try to help many people and give detailed information so, the person gets the most out of the post.
Therefore, what do you want to know yes, it does work you must follow instructions or you will get a CTD once in a while because, this is still Beta software.
As a result, the work takes testing the full flight un-like other plugins where you can test just part of a flight and know wether or not if the plugin works.
Please ask any questions you need I do like to answer them I just want you to think of what you want to ask and then post so we have good communication.
269
yes you are right the flow of the FMC is not quite right this is above my pay grade though.
B
of runway ?
270 (edited by captbullett 2016-02-29 20:20:47)
Right now I am testing a route from the KLAX/KPDX which is two airports that were designed and then implemented into X-Life and the FollowMeCar plugins.
Since, I added the txt and the dat files into the FMC and the X-Life plugin Airport Files and all worked.
Note #2 set the //* X-Life settings panel / selected aircraft to #75 and press the select,  I run between 45 and 75 on this setting.
and it is one of the first settings I make after starting the X-Life plugin.
Yet, I still got an error message that the airport was not on the google map list and it might not work right. So, you have to look past the error message and work through it and you will be pleasantly surprised by a well populated airport if you make the right settings, more data to come after the flight.
Note #2
the flight plan was good but the ATC widget did not git the data right and only had the departing airport and not the arrival airport therefore, the TOD did not work but there was not CTD so, here is the data ; bbox.txt and log.txt along with some screen shots of the error messages I received.
#3 screen shot is of the ATIS data and where the data only displays the departing airport this is why the route did not work it only shows KLAX when it needed to also display KPDX so I ran the simulation until the TOD to see if it would work out but it did not I will now close down the simulator and re-start it and try the same route.
#4 screen shot shows the message at the TOD where I was given the Data for KLAX and not KPDX . so this should give a complete picture of the scenario.
Note #5
I have rolled back from 10.45r2 to XP 10.45r1 and now the X-Life is not acting up but I still have to test at KLAX since, I am now working backwards from KPDX to KLAX and see what happens.
B.
Attachment icon Screen Shot 2016-02-28 at 1.04.16 PM.jpg 52.96 kb, 137 downloads since 2016-02-28
Attachment icon Screen Shot 2016-02-28 at 12.19.43 PM.jpg 54.03 kb, 130 downloads since 2016-02-28
271
Hi.
This plugin is very interesting for my!!
I am doing atc routes to spanish airports, use WED and following instructions this forum to do it...
My result are very well...Some airports do not get the planes made no movement, but in the others  everything works ...
I have in progress LEMD, LEBL, LECO and LEJR. This latter is not working well, the planes appear but do not move
I hope that plugin continue getting better. Is very good.
Grettings to all!!
PD: Sorry for my English...
272
One question..
there are intentions to include sound ??
I trying Beta 8 but couldn't get airborne.
Shortly after rotating X-Plane stops and crashes - see log attached.
I tried to depart from EDDL with northern winds - runway direction 05 in use. I noticed that some X-Life A/C taxied to rwy 05L for departe. Is it possible to set a preffered rwy for departure? In EDDL it would be 05R for deps.
Well, except from the crash, a great looking addon to X-Plane!
Kind regards
274
thank you for report
cram
if not work well for some airports, mean what .dat need to be reworked. We will think about sounds some later. I want, but reaaly not sure know how.
julio12345
now- not possible, but i will think about RW selection. So.. if you have stable CTD when takeoff, please (if you have time) contact me direst via skype - need check some online direct at your computer.
275
Thanks J.A Romanov for your work, is amazing!!
It´s correct. I check my .dat and now work all perfectly...
With sound the plugin would be a dream... smile
Thanks!!
