I did another test filght with X-LIFE plugin. Also I used GndHandling and FM plugins.
No CTD.
Please looking only x-life plugin as test (not my flight, he,he).
Here is my suggestion and report bugs:
- ATC window (active ATC should be coloured (GREEN))
- AI Ground traffic seems aviod colision when Transponder and TCAS is ON , What happen If TCAS is OFF ?(After vacated Ground asked us to turn off-possible collision).
- ATC APPROCH should switch us to CENTER ATC after passing FL (140 - depend of local rules)
- When flight end, no contect ATC to disconnect (say goodbay, or other like any information (local time, weather ...)
- X-life seems only recognoize ILS (VECTOR, NDB, VOR...I know this will be maybe in future).
- I cannot remember...see my video test.
Thanks JAR for excelent idea, plugin.
Sorry if I too critic, You will see What you want to implement.
http://www.twitch.tv/ivota_hr/v/51093481
HERE is LOG:
ATC LOG -----------------------------------
> Pilot: SCHWECHAT Delivery ,CROATIA 6 TANGO, Stand E44, A320, with information Bravo, QNH1013, request clearance
> ATC: Initial Altitude 7000 feet, Squawk 2655
> ATC: CROATIA 6 TANGO, SCHWECHAT Delivery, Cleared to SALZBURG, Runway 11, via OGBA1A departure,
> Pilot: Cleared to SALZBURG, Runway 11, via OGBA1A, Initial Alt 7000, Squawk 2655, CROATIA 6 TANGO
> Pilot: SCHWECHAT Delivery ,CROATIA 6 TANGO, Stand E44, request push and start
> ATC: CROATIA 6 TANGO, Contact SCHWECHAT Ground
> Pilot: Roger, CROATIA 6 TANGO
> Pilot: SCHWECHAT Ground ,CROATIA 6 TANGO, Stand E44, request push and start
> ATC: CROATIA 6 TANGO, push and start approved
> Pilot: Push and start approved, CROATIA 6 TANGO
> Pilot: SCHWECHAT Ground ,CROATIA 6 TANGO, Stand E44, request taxi
> ATC: CROATIA 6 TANGO, SCHWECHAT Ground, taxi to holding short runway 11, via TL36,TL35,L,EX15,M,A12
> Pilot: Taxi to holding short runway 11, via TL36,TL35,L,EX15,M,A12, CROATIA 6 TANGO
> Pilot: SCHWECHAT Ground ,CROATIA 6 TANGO, Stand E44, request FollowMe car
> ATC: CROATIA 6 TANGO, SCHWECHAT Ground, expect FollomMe car 1 minute
> Pilot: SCHWECHAT Ground ,CROATIA 6 TANGO, approaching holding short runway 11
> ATC: CROATIA 6 TANGO, Contact SCHWECHAT Tower
> Pilot: SCHWECHAT Tower ,CROATIA 6 TANGO, approaching holding short runway 11
> ATC: CROATIA 6 TANGO, SCHWECHAT Tower, line up runway 11, and wait
> Pilot: Lining up and wait runway 11, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, Set Transponder, Squawk 2655
> Pilot: Transponder On, Squawk 2655, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, runway 11 cleared for take-off, wind 135 degrees 16 knots
> Pilot: Cleared for take-off, Runway 11, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, contact SCHWECHAT Approach 124.6
> Pilot: Contact SCHWECHAT Approach on 124.6, CROATIA 6 TANGO
> Pilot: SCHWECHAT Approach ,CROATIA 6 TANGO, OGBA1A departure, passing 2500 feet, climbing to 7000 feet
> ATC: CROATIA 6 TANGO, SCHWECHAT Approach, radar contact, climb to FL 70
> Pilot: Climbing to FL70, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, Climb to FL 180
> Pilot: Climbing to FL180, CROATIA 6 TANGO
> Pilot: Ready for Descend, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, Contact Center
> ATC: CROATIA 6 TANGO, Descend at Pilot's Discretion to FL 120, expect BAGSI arrival, Runway 33 in use
> Pilot: Pilot's Discretion Descending to FL120, expect BAGSI arrival, Runway 33, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, contact SALZBURG Approach 123,625
> Pilot: Contact SALZBURG Approach 123,625, CROATIA 6 TANGO
> Pilot: SALZBURG Approach ,CROATIA 6 TANGO, FL158, descending to FL120, information Bravo on board
> ATC: CROATIA 6 TANGO, SALZBURG Approach, Wrong ATIS Information
> Pilot: SALZBURG Approach ,CROATIA 6 TANGO, FL155, descending to FL120, information Delta on board
> ATC: CROATIA 6 TANGO, Identified, expect BAGSI arrival, ILS approach Runway 33, descend FL 70
> Pilot: Descending FL70, expect BAGSI arrival, ILS approach Runway 33, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, Descend 2900 feet, QNH 1003, transition level FL 60
> Pilot: Descending 2900 feet, QNH 1003, transition level FL60, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, cleared for ILS approach Runway 33, report established
> Pilot: Cleared for ILS approach Runway 33, will report established, CROATIA 6 TANGO
> Pilot: Established ILS Runway 33, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, continue approach
> Pilot: Continue approach, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, contact Tower 123.45
> Pilot: 123.45, CROATIA 6 TANGO
> Pilot: SALZBURG Tower ,CROATIA 6 TANGO with you, ILS approach runway 33
> ATC: CROATIA 6 TANGO, Cleared to land Runway 33, wind 156 degrees 7 knots
> Pilot: Cleared to land Runway 33, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, take taxiway B, when vacated contact Ground 118.35
> Pilot: Take B, will contact Ground 118.35, CROATIA 6 TANGO
> Pilot: SALZBURG Tower ,CROATIA 6 TANGO, runway vacated
> ATC: CROATIA 6 TANGO, Contact SALZBURG Ground
> Pilot: SALZBURG Ground ,CROATIA 6 TANGO, runway vacated
> ATC: CROATIA 6 TANGO, Taxi to E9 via B,L,C,M
> Pilot: E9 via B,L,C,M, CROATIA 6 TANGO
> ATC: CROATIA 6 TANGO, Set Transponder to standby
> Pilot: Transponder Off, CROATIA 6 TANGO
> Pilot: SALZBURG Ground ,CROATIA 6 TANGO, request FollowMe car to E9
> ATC: CROATIA 6 TANGO, SALZBURG Ground, expect FollomMe car 1 minute
ATC LOG END ----------------------------
Ivo
