Re: JD340 v.1.4
Sluijsens wrote:Gyroscope wrote:Does anybody knows why light in the cockpit sometimes becomes darker and darker until it comes to totally black screen?
Is that bug or is it featrure? Cought that strange effect for several times but do not understand what it causes by ?That is the Hypoxia effect, meaning your cabin pressure was not set correctly. You can enable/disable it in the settings (first tab iirc).
Thanks a lot ! It is a magic to get Hypoxia on runway during tacking off.
Nota bene: Hypoxia becomes if I load the plane with running engines. Why ?
Haha well that is magic indeed.
However, the docs say you shouldn't load the aircraft with the engine running option. If you do, then this might be one of the issues that occur.
Instead you should load without engines running and then use the hot start option that you see in the bottom left corner.
