Topic: JD340 v.1.4
http://jardesign.org/forum/img/m/22/t/p1fbu2cdtnlgd1tu3mp041i15jo3.png
JD340-500 for X-Plane 11.55 (11.41 work too) macOS Catalina&Big Sur and Windows 10
X-Plane.ORG Product Page:
https://store.x-plane.org/JARDesign-340 … _1469.html
What new:
Version 1.4r1:
+ updater plugin add
+ liveries installer add
+ diagnostic plugin improved
+ ND VOR mode indication fixed
+ rudder 3D geometry fixed
+ DIR TO function improved
+ ALL and Camera mode conflict
  fixed for SYS display
Version 1.3r2 250921 what new:
+ cockpit door open fixed
+ overhead switches screws fixed
+ FCU knobs and light improved
Version 1.3r1 040921 what new:
+ taxi & ckpt entry camera add
+ xEnviro issue fixed
+ RAT hydraulic supply fixed
+ Tablet show/hide option add
+ F and S indication fixed on EWD
+ editable version.txt file (custom callsign)
+ minor bugs fixed
+ left FCU baro issue fixed
Version 1.2r3 210821 what new:
+ PFD, ND, EWD, SYS display drawing issue fixed
+ initial pilot position fixed for VR purpose
+ transponder knobs 0/7 issue fixed
Version 1.2r1 140821 what new:
+ PFD, ND, EWD, SYS displays 2D widgets add
+ AP disconnect indication improved
+ add command for AP takeover button
+ mouse wheel manipulators included
+ central landing gear brake hoses 3D model fixed
+ ND brightness manipulator fixed
Version 1.1R1 060821 what new:
+ CoPilot ready build
+ AP disconnect conditions improved
+ AP parameters tuned
+ FlightModel parameters tuned
+ Autoland improved
+ bug fix
v.1.0R1
+ Just a release
Download Actual version 1.4R1:
http://jardesign.org/jd340/download/ins … 161021.zip
When you install updated version - please make clean new installation!
Old version 1.3R2 link:
http://jardesign.org/jd340/download/ins … 250921.zip
Please download manual:
http://jardesign.org/jd340/download/Manual.pdf
Please READ MANUAL and Install/Activate aircraft with your serial key.
You may download some liveries here:
AAL http://jardesign.org/jd340/download/liveries/AAL.zip
AFL http://jardesign.org/jd340/download/liveries/AFL.zip
Air Canada http://jardesign.org/jd340/download/liv … canada.zip
AZAL http://jardesign.org/jd340/download/liveries/AZAL.zip
BA http://jardesign.org/jd340/download/liveries/BA.zip
Emirates http://jardesign.org/jd340/download/liv … irates.zip
ETIHAD http://jardesign.org/jd340/download/liveries/ETIHAD.zip
Lufthansa http://jardesign.org/jd340/download/liv … thansa.zip
QATAR http://jardesign.org/jd340/download/liveries/QATAR.zip
Also you may find liveries at our simliveries website:
http://simliveries.com/index.php/category/340-liveries/
PaintKit download link:
http://jardesign.org/jd340/download/JD3 … 310721.zip
CoPilot plugin for this aircraft:
http://jardesign.org/forum/viewtopic.ph … 615#p40615
Re: JD340 v.1.4
place holder
Re: JD340 v.1.4
place holder
Re: JD340 v.1.4
Where is the GHD set for aircraft?  Also download link for all liveries is broken via store
Re: JD340 v.1.4
I had low expectations about this aircraft and I'm still disappointed. You simply took the A330, lengthened the fuselage, slapped two new engines and a landing gear and released it. You made no effort to make any improvements at all. I can't wait for Toliss to release its A340 so I can uninstall it.
You want to know something: If you at least overcome what you call 'X-Plane limitations', which all the other developers have managed to overcome but you, especially in replay mode, I'll be satisfied. But I have little hope that you will make it. You will probably released another broken aircraft before thinking about fixing the existing ones.
Re: JD340 v.1.4
It's embarrassing for you that I have to come here to report a bug that I reported in the A330 thread because the A340 also has...
- In replay mode, spoilers do not extend or retract. They stay in the position they were in before activating the replay.
But you managed to introduce two new bugs in replay mode.
- V/S knob clicking itself multiple times, producing an annoying clicking noise. Sometimes it stops when the aircraft touches the ground and sometimes it keeps clicking even after exiting replay mode.
- After exiting the replay mode, the engines go to full throttle, even if the throttle lever is at 0%.
So, are you going to fix it or blame the 'X-Plane limitations' and leave it at that?
Re: JD340 v.1.4
What they write here is absolute bullshit and they lie that you bend bars. If you are not satisfied then do not buy it. Romanov is the best support developer there is. Then buy an xbox and fly MS2020 and don't talk shit here. Or play Fortnite
Re: JD340 v.1.4
Spoiler during replay! Jd330 and 340 have this problem. The replay is too strange! This needs to be repaired as soon as possible! I hope jardesign is getting better and better
Re: JD340 v.1.4
Also ich finde auch, dass "edu2703" ziemlich übertrieben "vom Leder zieht". Das wird einem Entwicklerteam wie JAR Design nun wirklich nicht gerecht.
Woran man bei JAR Design allerdings dringend arbeiten sollte ist, dass man die Kundenwünsche und Anregungen ernster nimmt, aber zumindest darauf eingeht. Beispiel: Die schon lange geforderte Frachter Variante der A330. Oder eine A321.
Jedenfalls bin ich, mit beiden, der A320 und der A330 sehr zufrieden und werde mir sicher auch die A340 von JD zulegen.
Noch einen Tip an "edu2703": Erstmal in den Spiegel schauen und die eigene Perfektion abfragen.
10 (edited by peikai 2021-08-01 09:13:08)
Re: JD340 v.1.4
I fully agree with ULFT and gigabenga!
Romanov is an excellent developer, and I very like to fly his A330 & A320 as one of my favorite aircraft!
I'm going to order his JARDesign A340-500 today.
Cheers,
Kai
Re: JD340 v.1.4
Das hast du richtig gut geschrieben toller Post. Super
Re: JD340 v.1.4
JD340-500Airlin.set file already in aircraft folder. GHD can read it directly from this folder.
Re: JD340 v.1.4
The reason for this is X-Plane replay mode can not play back custom datarefs (we use custom for this), but should. Already talk with Ben Supnik (LR lead coder) about this, he promise, but still not done.
14 (edited by gigabenga 2021-08-01 12:13:03)
Re: JD340 v.1.4
Dear Romanov Thanks for fantastic aircraft
you are the best and best support thanks for all
Here Pictures absolutly sharpnes
Re: JD340 v.1.4
Non-official mod what allow you to use mouse wheel for cockpit switches.
by Vitaly Dedylia
You may replace this file in your 340_JARDesign folder.
http://jardesign.org/jd340/download/mod … ockpit.OBJ
by Vitaly Dedyulya. А по паспорту вообще страшно на латинице. wink
Aures habent et non audient
Re: JD340 v.1.4
by Vitaly Dedylia
Пардон-мардон! Уже поправил! Already fixed.
Re: JD340 v.1.4
Wow! So quality screenshot! What screen resolution you use and what frame rate you get?
Re: JD340 v.1.4
Thank you very much! But why did the spoiler display normally in the early version of jd330 and other aircraft during replay? Is there any other way?
Re: JD340 v.1.4
Hey Romanov
My solution iss 2560x1440P and my framerate ist over 50 FPS with your aircraft null Problems
Greetings
20 (edited by filachudobik 2021-08-01 19:22:14)
Re: JD340 v.1.4
Hello, I have just started a thread on the x-plane forum about user-made liveries, starting with fictional SWISS. I will be very happy if you join me smile
https://forums.x-plane.org/index.php?/f … nt-2228663
Re: JD340 v.1.4
Not sure where to post this?
Just did my first flight and on landing approach about 250 ft from the runway the engines went from approach mode to full thrust without any command from me i had to manually disconnect auto throttle and bring the thrust back down. also upon touchdown had to manually deploy the speed brakes as they did not deploy and were armed before hand still no deployment. Also when using auto land function the plane did not flare at all and hit the ground at about -654 fpm. overall i think it a good plane but still needs a few tweaks.
Re: JD340 v.1.4
You were still lucky. My attempt to use the autoland function ended with the aircraft starting to deviate from the G/S at about 1000 ft AGL and suddenly pitching the nose down at about 15-20°. Speed was on target and there was no icing. Not even disconnecting the AP and pulling the stick did the aircraft pitch up again.
I think we can call this the 'kamikaze bug'.
Re: JD340 v.1.4
https://forums.x-plane.org/index.php?/f … es-9v-sge/
Singapore A340-500!
Re: JD340 v.1.4
would be best that you disappear full posts from the forum or you Mr. Romanov gives your money back request a refound if you are not satisfied you are a complete idiot. You don't seem to know anything about flying or you can't even operate an airplane. As the saying goes then go to Toliss. Or play Fortnite. You heiner. Sorry that had to be said if I were an administrator, you would have long been blocked with your very stupid statements
Re: JD340 v.1.4
Hello Romanov,
First wanted to thank you for all the amazing work with these planes, I am simming since 1990 and at the current stage you as developer have taken it is just brilliant. Have done some test taxi,flight, landing and the A340 handles amazing. Thank you for all the hard work.
Gilles
