Re: JD340 v.1.4
Gyroscope wrote:
Sluijsens wrote:
Gyroscope wrote:
Does anybody knows why light in the cockpit sometimes becomes darker and darker until it comes to totally black screen?
Is that bug or is it featrure? Cought that strange effect for several times but do not understand what it causes by ?
That is the Hypoxia effect, meaning your cabin pressure was not set correctly. You can enable/disable it in the settings (first tab iirc).
Thanks a lot ! It is a magic to get Hypoxia on runway during tacking off. smile
Nota bene: Hypoxia becomes if I load the plane with running engines. Why ?
Haha well that is magic indeed.
However, the docs say you shouldn't load the aircraft with the engine running option. If you do, then this might be one of the issues that occur.
Instead you should load without engines running and then use the hot start option that you see in the bottom left corner.
Re: JD340 v.1.4
kamalskerba wrote:
Thank you for the update.
Quick question, is it better to delete the aircraft completely or simply copy over the aircraft, with the new files /
I did a complete reinstall, had to get my activation key and set up views again...... not a big deal just curious how others update.
thanks
K
A good way - just make new installation with another folder name, activate it and next - copy liveries and settings files to this new folder.
Re: JD340 v.1.4
IBE1001 wrote:
hello Mr Romanov.
I would like to put the icing on the cake in this beautiful plane, I do not know if it will be very complicated is to put a camera in the front train and with a button in the cabin just like the 340 in real life so that you can see where the front wheel and tail in the ECAM2 go.
I remember that the Airbus 350 of FF in the version with the x-plane 10.50 worked and already in x-plane 11 does not work.
We well know that with the xcamera plugin you can put all the cameras you want, both inside and outside, but as I said at the beginning it would be a wonder to turn in the taxi that have more than 90 degrees.
Greetings.
We already done this, but delete. Sure, X-Plane have display camera in Plane Maker, but when we trying to use it - we get just terrible quality and the problem was - this camera not show any another objects, but pavement only. So, it was useless. I don't know about another way/tool to implement camera into display. Sadly, but as is for now.
Re: JD340 v.1.4
Aircraft have own (custom) pressurisation system and default hypoxia settings should be disable for this case.
Re: JD340 v.1.4
Well I would disable it,  but I have not found where is it ?
Re: JD340 v.1.4
First tab of X-Plane settings as I remember
Re: JD340 v.1.4
Hello...
FLOOD IT - Main Panel is still not working.
Its a bit annoying, if you take night flights.
Does anyone have the same issue?
Hope this can be fixed soon
Re: JD340 v.1.4
peikai wrote:
Hello...
Could you tell what you mean by "main panel" and by "not working ".
Explanations could make your question understandable .
Re: JD340 v.1.4
peikai wrote:
Hello...
Have it worked well. So, please check:
1. Aircraft is powered
2. X-Plane Graphic settings -> Visual Effects is set to High or Maximum (HDR should be ON with this settings)
Re: JD340 v.1.4
Perfect! That worked very well!!!
What an awesome COCKPIT !!! Love it!
Thank you, Romanov
Re: JD340 v.1.4
Version 1.2 140821 what new:
+ PFD, ND, EWD, SYS displays 2D widgets add
+ AP disconnect indication improved
+ add command for AP takeover button
+ mouse wheel manipulators included
+ central landing gear brake hoses 3D model fixed
+ ND brightness manipulator fixed
Re: JD340 v.1.4
Thanks for the updates... much appreciated!!!
Re: JD340 v.1.4
2D pop ups appear with blank screen having horizontal lines..please check.[
Re: JD340 v.1.4
I have the same problem as coolgovind180 with 2D pop-ups
90 (edited by _al_ 2021-08-16 11:04:55)
Re: JD340 v.1.4
The load capacity in terms of passengers for this plane is representative of which configuration? The MCDU Menu, under load and fuel, shows a MAX value for passengers  = 250 that seems far below what could be expected.
Within the 340_JARDesign folder can be found a file "type340.txt" where PAX = 313, but there's a further set of data with 250 PAX only applicable to MSN0912, what plane that is?
Official Airbus data (https://www.airbus.com/aircraft/previou … 0-500.html) show typical seating  in the range 270-310 with max seating at 440. Therefore limiting at 250 PAX seems quite limitative, at least for players who like to use realistic data. Would be possible to provide better context to that 250 PAX limit or to lift it?
Anyway, had a look in the cabin of the JARDesign A345 model, there are 250 seats (jumpseats excluded).
Re: JD340 v.1.4
Hallo, ich habe ein Problem bei Start und Landung. Ab einer bestimmten Geschwindigkeit lässt sich das Flugzeug nicht mehr kontrollieren. Ich komme ständig von der Start und Landebahn ab. Es fängt an zu schlingern. Das Bugrad reagiert auch ziemlich langsam. Ich benutze den Airbus Stick von Thrustmaster. Hat irgendjemand eine Idee.
Hello, I have a problem with takeoff and landing. Above a certain speed, the aircraft can no longer be controlled. I keep getting off the runway. It starts to lurch. The nose wheel is also quite slow to respond. I use the Thrustmaster Airbus Stick. Does anyone have an idea?
Re: JD340 v.1.4
weired issue. I updated (new installation). Old version worked perfectly well, the update does not let me switch on the batteries. I can connect the GPU, but the middle part of the overhead panel does not let me switch any button. On the left or right side (still overhead) I can switch buttons - but of course without switching on the batteries this leads nowhere. Also the MCDU setting panel is not working without the batteries (if there is a solution there to find).
Any ideas?
Re: JD340 v.1.4
Any ideas?
Look like something special. I am not get mass reports about this. Please reinstall aircraft and if no luck - contact me Skype j.a.romanov
Re: JD340 v.1.4
Any details about "certain speed" and screenshots of PFD+FCU or Log file. So, need more details, please.
95
Re: JD340 v.1.4
Get reports like this, but have not this issue on out test computers. So, look like I need someone in Skype who have this bug to check conditions, settings and so on. My Skype is j.a.romanov
96
Re: JD340 v.1.4
This is very good question! Is it may be what A340-542 may have less than 270 seats? Why not? At least this specification allow this https://www.hifly.aero/public/uploads/2 … CS-TFX.pdf
For different time period the same MSN may fly for different Airliners who may have different seats number.
As example - this is the same MSN aircraft:
Kingfisher Airlines as VT-VJE
Hi Fly 2009 as CS-TFX
Arik Air 2009-2015 as CS-TFX
Hi Fly 2015-2018 as CS-TFX
Re: JD340 v.1.4
And that's a really good answer, many thanks for those specifics. So now I know what I'm flying, will choose routes where this luxury liner fits better!
98 (edited by Lumpi12524 2021-08-18 12:50:30)
Re: JD340 v.1.4
@Romanov, habe einige Bilder vor und während des Startes. Ich habe auch noch zwei Videos von der Landung. Aber irgendwie bekomme ich die hier nicht hoch geladen. Ich melde mich über Support.
@Romanov, got some pictures before and during the launch. I also have two videos from the landing. But somehow I don't get this uploaded here. I will contact the support.
Re: JD340 v.1.4
When will the V/S knob bug be fixed?
When using replay mode, this knob starts clicking and rotating on its own. And it keeps happening even after exiting replay mode, making the button unusable, not to mention the annoying noise it makes.
Re: JD340 v.1.4
Same problems as other forum members, the popup does not show an image, only in black.
