Topic: XP11.50 JD330 v.4.2
JD330 for X-Plane 11.50
What new:
v.4.2R1
+ BAT indication on overhead panel fixed
+ Special points drawing on ND (on curved pathline) fixed
+ Chrono work fixed
+ Clock reworked
+ Alt CNSTRs indication on PFD fixed
+ V/S FCU indication fixed
+ Coordinates on MCDU INIT page (wrong format fixed)
+ TCA Engine Master Switches Support improved
+ Profile altitude for alt CNSTR points recalculated
+ NPA approach calculation and indication improved
+ ILS Information on PFD fixed
+ MDA entering fixed
v.4.2R2
+ include hot fix for APU/ENG firetest sound
v.4.2R3
+ Target speed indication fixed for mach mode
+ Engines "can't shut down" issue fixed
+ PFD speed indication fixed
v.4.2R4
+ Baro indication on PFD fixed
+ CNSTR Alt indication on ND fixed
+ SPD <-> MACH switch logic improved
+ Track indication fixed on PFD & ND
+ Spd CNSTR logic fixed
+ mode reversion on done phase fixed
Download link for version 4.2.3:
http://jardesign.org/a330/download/inst … 0_4230.zip
Download link for version 4.2.4:
http://jardesign.org/a330/download/inst … 0_4240.zip
For macOS Catalina / BigSur users - please follow instruction:
Download link to updated Ground Handling plugin to be well-compatible with XP11.50
http://jardesign.org/forum/viewtopic.php?id=11824
- be sure, that you use X-Plane 11.41-11.53
- copy unziped "JD330XP11" folder to ..\X-Plane 11\Aircraft\ folder
(create it if need)
Please care about information what you will post here and try to determinate reason if issues happen - sure, he interesting in aircraft test and troubles but want to avoid work with "pilot" issues.
Thank you!!!!
