Topic: XP11.50 JD330 v.4.2
http://jardesign.org/forum/img/m/22/t/p1e57cq5ln9odvjslepct41o5h3.png
JD330 for X-Plane 11.50
What new:
v.4.2R1
+ BAT indication on overhead panel fixed
+ Special points drawing on ND (on curved pathline) fixed
+ Chrono work fixed
+ Clock reworked
+ Alt CNSTRs indication on PFD fixed
+ V/S FCU indication fixed
+ Coordinates on MCDU INIT page (wrong format fixed)
+ TCA Engine Master Switches Support improved
+ Profile altitude for alt CNSTR points recalculated
+ NPA approach calculation and indication improved
+ ILS Information on PFD fixed
+ MDA entering fixed
v.4.2R2
+ include hot fix for APU/ENG firetest sound
v.4.2R3
+ Target speed indication fixed for mach mode
+ Engines "can't shut down" issue fixed
+ PFD speed indication fixed
v.4.2R4
+ Baro indication on PFD fixed
+ CNSTR Alt indication on ND fixed
+ SPD <-> MACH switch logic improved
+ Track indication fixed on PFD & ND
+ Spd CNSTR logic fixed
+ mode reversion on done phase fixed
Download link for version 4.2.3:
http://jardesign.org/a330/download/inst … 0_4230.zip
Download link for version 4.2.4:
http://jardesign.org/a330/download/inst … 0_4240.zip
For macOS Catalina / BigSur users - please follow instruction:
Download link to updated Ground Handling plugin to be well-compatible with XP11.50
http://jardesign.org/forum/viewtopic.php?id=11824
  - be sure, that you use X-Plane 11.41-11.53
  - copy unziped "JD330XP11" folder to ..\X-Plane 11\Aircraft\ folder
(create it if need)
Thank you!!!!
Re: XP11.50 JD330 v.4.2
Hotfix for APU/ENG firetest sound (apply it to ver 4.2R1)
Please put (replace) this .xpl files to /Aircraft/JD330XP11/plugins/330va/
reserve
I am having a problem with this plane. i just bought this and the engines wont shut down despite the engine leavers being down.
Thanks JarDesign team, great job!
System: Core i9 11900F ~ 5,2Ghz , 32Gb DDR4 3200MHz, NVidia RTX3070Ti 8Gb, W10Pro. 64 bits, SSD 512Gb, HDD 4Tb
Monitor: Samsung SyncMaster S27A650D (1920x1080)
joystick: TrustMaster T.Flight Xotas X
Sim.: X-plane 11.55r1
Thank you for this up date .
Everything works perfectly ....except engines which keep running with levers on shut down position ....
Any possible fix ?
About engines keep running - thanks for report - I should check this on my side again to understand a reason. We was not get this issue during tests, but will try again. I will inform.
Any possible fix ?
Hmm.. we just test this issue on 3 different computers - we can not get this. So, if possible - please call me via Skype j.a.romanov - we will check mason for this issue online, check possible reason include hardware affect (may be sone hardware switch control mixture or ignition and produce this issue).
i have an issue with the plane, i have a black square in the corner where the GPU and HOT START icons are, it goes when i turn off Xenviro
Hello. Im using a330 4.2 version, I wonder when the speed limit bar will be created again in the pfd. (depend on flaps setting)
It was disappeared, after 4.0 version..
and I have some problem with autobrakes, spoiler,
I need to activate the approach mode of the fmgs so that the auto-brake or spoiler recognizes it and works when landing. But it often causes errors and sometimes it doesn't work. (not deployed and brakes) I hope the auto brake or spoiler will work when landing without fmgs setting. (I wish it can be rolled back in the old way, it works immediately ( wink )
So, this texture of MCDU display in the left bottom corner draw by xEnviro. You may check this easy using X-Plane Menu->Plugins->xEnviro->On click to turn it On and next Off - you will see smooth increase of this texture transparent. I think xExviro take one of framebuffer what created by JD330 and draw it. Sure, old version of JD330 not do this, but new version was recreated for XP11.50 rules. May be xEnviro will be updated for 11.50 rules too and this issue will gone.
Sure, you can contact me skype j.a.romanov - we will do flight together and will see what happen wrong
13 (edited by jcdp 2021-04-19 20:50:24)
Any possible fix ?
Thanks for your answer .
I am going to re check hardware configuration and make new try .
If not solved I shall manage for calling you on skype .
Any possible fix ?
thank you, my friend!
hello from my tset flying
found 2 big probleam
1.apu fire test and engine test no sound
2.cabin crew no sound
So, please apply hotfix for APU/ENG firetest sound http://jardesign.org/forum/viewtopic.ph … 631#p39631
About FA sound - please select PA on radio panel and adjust PA volume
17 (edited by fred750 2021-04-20 12:13:50)
yes i using it from mcdu
18 (edited by fred750 2021-04-20 12:22:46)
as you see my set
realy no any sound
19 (edited by rafalec 2021-04-20 14:28:11)
Hello, same problem for me, sound correctly configured into MCDU and  Sound3D.
20 (edited by rjarret 2021-04-20 15:51:51)
Hi, plane is amazing, but when I hit UPDATE on the CPDL sim freezes. Tried different airports. Different flight phase (ground, crz, after landing, etc). Always freezes. Here is the latest LOG from when on the ground @ SAEZ on flight to SAWH.
Some part of users describe crash just after click Update button on DCDU. As you can see at Log.txt (just after crash happen) Metar data was readed/saved ok, but you may read xPilot plugin info in several strings after this. So, if you will remove xPilot plugin - crash will not happen and you will get metar info on your DCDU. JD320/330 not affect on xPilot plugin, but just send weather request to internet. It is may be what xPilot just intercept metar server answer and trying to parce it with no luck and generate CTD, I dont know, but guess only. Anyway, this issue may be solved on xPilot side and we ready to deal with xPilot developers if need.
23 (edited by jcdp 2021-04-20 21:23:59)
About engines ...
After a try for recalibrating "yoke" I have no change when engines are shut down ... from outside view blades of turbines keep rotating ...
so I shall try to contact you on skype ..
regards
Edit: Curiously this doesn't happen with A320 (same config )
About engines ...
regards
So, from outside view blades of turbines keep rotating, but what about EPR and N1 indication on EWD?
Many thanks
