Hello! This time X-Life plugin was reworked again. We use X-Plane fresh API now and make this plugin VR-compatible. About 2300 strings of c++ code added.
Download link to Actual build
http://www.jardesign.org/x-life/downloa … 090219.zipWhat New:
v.4_050718 (first test build of v.4)
+ new ATC panel design
(movable, auto-hideable, resizable with mousewheel)
+ add VR-support for ATC-panel
+ add "Set Baro readback"
+ add "Set Squawk readback"
+ many CTDs fixed
+ framerate optimisation
+ pdf manual includedv.4_070718 (updated build of v.4)
+ flightplan import/export buttons for JD320/330 fixedv.4_090718 (updated build of v.4)
+ landing performance for AI aircraft(s) updatedv.4_210718 (updated build of v.4)
+ long Callsign is possible now
+ "cant close" ATC Panel issue fixed
+ takeoff without clearance issue fixed
+ any Departure Airport may be entered at FPLN pagev.4_090219 (updated build of v.4)
+ METAR issue fixedInstallation:
Please unzip pack and follow .PDF manual.
If you prefer use HD “Bluebell XL” traffic AI library, please download 3 files from
http://jardesign.org/downloads/BBXL/BBXL-3.zipNext unZIP and put “Bluebell XL” folder to ../X-PLANE 10/Custom Data/ folder
../X-PLANE 10/Custom Data/Bluebell XL/ folderUPDATE YOU NAV DATA WITH FRESH CYCLE (if needed)
and put new cycle to ../X-PLANE/Custom Data/GNS430/navdata/ folderAirport Editor manual by Philip Walchester posted here
http://jardesign.org/forum/viewtopic.php?id=3261FMCar update
http://jardesign.org/forum/viewtopic.ph … 877#p17877All remain the same
- post your log.txt + x-life.dmp if Crash happen and you are on Windows.Where is version 3? Why v.4 just after v.2? Hmm.. v.3 was build but without VR-support. So - v.4 with VR-support is come.
