Topic: X-Life ver 4 for X-Plane 11
Hello! This time X-Life plugin was reworked again. We use X-Plane fresh API now and make this plugin VR-compatible. About 2300 strings of c++ code added.
Download link to Actual build
What New:
v.4_050718 (first test build of v.4)
+ new ATC panel design
(movable, auto-hideable, resizable with mousewheel)
+ add VR-support for ATC-panel
+ add "Set Baro readback"
+ add "Set Squawk readback"
+ many CTDs fixed
+ framerate optimisation
+ pdf manual included
v.4_070718 (updated build of v.4)
+ flightplan import/export buttons for JD320/330 fixed
v.4_090718 (updated build of v.4)
+ landing performance for AI aircraft(s) updated
v.4_210718 (updated build of v.4)
+ long Callsign is possible now
+ "cant close" ATC Panel issue fixed
+ takeoff without clearance issue fixed
+ any Departure Airport may be entered at FPLN page
v.4_090219 (updated build of v.4)
+ METAR issue fixed
v.4_120319 (updated build of v.4)
+ microfreezes issue fixed / improved
v.4_010519 (updated build of v.4)
+ Flightplan export to default X1000 FMC improved.
+ Add pause before takeoff for traffic aircraft(s).
v.4_250719 (updated build of v.4, need reinstall full plugin)
+ ATC panel "auto-hide" off setting add
+ More than 30 compatible airports add
v.4_140819 (updated build of v.4)
+ Nvidia threaded optimisation compatible
+ ATC panel unexpected hide fixed
v.4_211019 (updated build of v.4)
+ macOS Catalina compatible
Installation:
Please unzip pack and follow .PDF manual.
If you prefer use HD “Bluebell XL” traffic AI library, please download 3 files from
Airport Editor manual by Philip Walchester posted here
http://jardesign.org/forum/viewtopic.php?id=3261
Flight Manual (german&english language) with example flight using B757
Attached to this topic (thanks for Horst-Helmut Krause)
FMCar update
All remain the same
http://jardesign.org/forum/img/m/22/t/p1chnfe1eg1sicshjbs58qlim3.png
Attachment icon B 757 Manual DE 20191221 KR V 1.03.pdf 17.27 mb, 1251 downloads since 2019-12-26
Attachment icon B 757 Manual EN 20191226 KR V 1.03.pdf 17.71 mb, 1120 downloads since 2019-12-27
2 (edited by ivota 2018-07-06 15:17:19)
Whooo, finally. I am going to test.
it doesn't load, 2 times downloaded and installed:
Fetching plugins for D:\X-Plane 11/Resources/plugins
Loaded: D:\X-Plane 11/Resources/plugins/PluginAdmin/64/win.xpl (xpsdk.examples.pluginadmin).
2018-07-06 13:36:21 BetterPushback[xplane.c:538]: This is BetterPushback-v0.45 libacfutils-405a90e
Loaded: D:\X-Plane 11/Resources/plugins/BetterPushback/64/win.xpl (skiselkov.BetterPushback).
Loaded: D:\X-Plane 11/Resources/plugins/CEF/64/win.xpl (FlightFactor.CefLoader).
Loaded: D:\X-Plane 11/Resources/plugins/DataRefEditor/64/win.xpl (xplanesdk.examples.DataRefEditor).
FollowMe Car Plugin by JARDesign v.2.6r1 020717 for X-Plane 10.40
FMCar plugin: livery find - Default.png
FMCar plugin: livery find - Orange.png
Loaded: D:\X-Plane 11/Resources/plugins/FM/win.xpl (jardesign.crew.fmcar).
FlyWithLua: Your system path is D:\X-Plane 11/
FlyWithLua: Plugin Dir: D:\X-Plane 11/Resources/plugins/FlyWithLua
FlyWithLua: Plugin Scripts Dir: D:\X-Plane 11/Resources/plugins/FlyWithLua/Scripts
Loaded: D:\X-Plane 11/Resources/plugins/FlyWithLua/64/win.xpl (CarstenLynker.FlyWithLua.Complete).
G64:   0.000: Gizmo64 Script Engine v18.01.02.0458 Windows
G64:   0.000:      built: Jan  2 2018, 05:00:27
Loaded: D:\X-Plane 11/Resources/plugins/Gizmo64.plugin/64/win.xpl (gizmo.x-plugins.com).
D:\X-Plane 11/Resources/plugins/X-Life/win.xpl : Error Code = 126 : No se puede encontrar el módulo especificado.
G64:   0.077: Boot Count: 1
G64:   0.357: Plugin Enabled.
Found stats plugin: 4
I found the following scenery packages (prioritized in this order):
Look very nice, i test it the next days
5 (edited by cmckjodi 2018-07-06 12:48:08)
Version 4 will not load I get the same error as Capto above in my text log Error code = 126  the specified module could not be found. I'm using X Plane 11.20 vr  running Windows 10
6 (edited by twinrix 2018-07-06 13:45:03)
Same here, won't load
F:\X-Plane 11/Resources/plugins/X-Life/win.xpl : Error Code = 126 : Das angegebene Modul wurde nicht gefunden.
If Error code = 126 happen:
1. Check what you use computer under Admin mode.
2. You use Windows 10. In this case, please install "Microsoft Visual C++ Redistributable 2010" pack
http://www.microsoft.com/en-us/download … x?id=14632
Visual C is installed, starting Xplane as Admin. Error 126 for me still (11.20 / Win 10)
If possible - please cal me skype j.a.romanov - we will check online what happen wrong
Works beautifully on my machine. Still a little jerky with 8 active aircraft, no wonder, but otherwise EXCELLENT.
Has anyone been able to get XLife 4 running using Windows? If so what versions? Perhaps we can narrow it down for JAR.
sure, i have it worked well, our beta-testers have it well on Windows 10 and XP11.20. Please call me skype if not work - we will try to determinate this issue reason.
It works fantastic for me under Windows 10.
It can be a conflict with the GroundTraffic plugin. Maybe too many plugins loaded.
Try to remove GroundTraffic in some Scenery folders.
Same here
Tried removing all plugins except Xenviro Version 4 will still not load running Windows 10. There must be a coding difference between version 4 and the previous version that worked fine since XPlane cannot find the module Error Code=126
16 (edited by Darko24 2018-07-06 21:01:46)
For me works for now, but does not import - export plan from-to aircraft FMS JAR330 and not set Squawk code in this plane with command. Other things work fine.
No luck even with no other plugins enabled. Not going to tinker wit addon airports in an otherwise perfect working xplane installation just to make Xlife working. Waiting for a fix patiently smile
installed and seems to work out of box. Windows 10 with all plugins enabled. I updated XP to the 10.25RC1 as well as the GND plugin
It seems really good on framerates so far. One issue i just noticed. The JS41 aircraft which takes off, got switched to a B747 at the moment it took off and now 2 aircraft models are shown. can you look into that?
Now the pictures
please check what default x-plane traffic is Off
One more idea - please try to put this .dll to X-Life plugin folder.
Another way - call me skype j.a.romanov to try sort out this issue.
Loaded now, thank you Jar.
But very bad FPS once is turned on, -30 or so, cpu issue.
Import/export is fixed for actual build. You may just update .xpl files
Squawk code set may not work with some aircraft with custom Squawk system. This is normal.
