Topic: XP11 JD330 v.3.1 r1, r2, r3
Version of a330 for X-Plane 11.
features:
+ X-Plane 11.30 ready
+ AirFMC plugin ready
+ JARDesign CoPilot plugin ready
+ macOS Mojave ready
+ some Aircraft/FMGS bugs and CTD fixed
r1 features:
+ in fact r1 is release candidate
r2 features:
+ default F/O voice is back to installation pack
r3 features:
+ METAR reading issue fixed
+ GPU button fixed
+ MDCU MENU Ground Handling operation fixed
about using with macOS Mojave:
Please open system preferences, security and privacy, accessibility, check X-Plane.
about using with AirFMC plugin:
Please wait and update to version 1.7 of this software if you use it
about using with JARDesign CoPilot plugin:
You can download and install it
http://jardesign.org/a330/download/inst … PL-330.zip
Setup and using manual already included. This plugin is a separate product by JARDesign, work with JD330 for free. Voice recognition function execute by your computer OS (Win 10 or MAC OS). CoPilot plugin just use it. So, voice recognition ability and quality depend of your OS settings and hardware. Speech quality also depend of your installed text-to-speech voices. This plugin will not work with non-English version of your OS. You should setup and check your English voice recognition on Windows 10 or Mac BEFORE this plugin installation.
!!! no X-Plane plugins/330/ menu exist more, please set command jd/fmgs/CommandShowMcdu for some keyboard key and use MCDU MENU to operate ground handling.
HOW TO INSTALL / UPDATE:
Download link
http://jardesign.org/a330/download/inst … 11_313.zip
Please be sure what you have actual version of Ground Handling plugin to be well-compatible with XP11
Download link: http://jardesign.org/forum/viewtopic.php?id=4133
- be sure, that you use X-Plane 11.30
- copy unziped "JD330XP11" folder to ..\X-Plane 10\Aircraft\ folder
- please visit download more fresh version of Ground Handling plugin. It work with JARDesign 330 without registration (for free). Please note what “Deluxe” version of this plugin (may work with other aircrafts) is payware.
- enter your serial key (use exist serial from "JD330 for X-Plane 11"), click NEXT and after a successful activation reopen aircraft via X-Plane menu
a330 use NavData from
../X-PLANE 11/Custom Data/GNS430/navdata/ folder
../X-PLANE 11/Aircraft/330_JARDesign/_navdata/
and put new cycle to ..X-PLANE 10/Custom Data/navdata/ folder
- you may post you opinion about this version, post what you like/unlike
- please post your log.txt + x-life.dmp if Crash happen and you are on Windows.
Thank you!!!!
This is FREE update for users who own "JD330 for X-Plane 11" product.
