Topic: XP11 JD330 v.3.1 r1, r2, r3
Version of a330 for X-Plane 11.
features:
+ X-Plane 11.30 ready
+ AirFMC plugin ready
+ JARDesign CoPilot plugin ready
+ macOS Mojave ready
+ some Aircraft/FMGS bugs and CTD fixed
r1 features:
+ in fact r1 is release candidate
r2 features:
+ default F/O voice is back to installation pack
r3 features:
+ METAR reading issue fixed
+ GPU button fixed
+ MDCU MENU Ground Handling operation fixed
about using with macOS Mojave:
Please open system preferences, security and privacy, accessibility, check X-Plane.
about using with AirFMC plugin:
Please wait and update to version 1.7 of this software if you use it
about using with JARDesign CoPilot plugin:
You can download and install it
http://jardesign.org/a330/download/inst … PL-330.zip
Setup and using manual already included. This plugin is a separate product by JARDesign, work with JD330 for free. Voice recognition function execute by your computer OS (Win 10 or MAC OS). CoPilot plugin just use it. So, voice recognition ability and quality depend of your OS settings and hardware. Speech quality also depend of your installed text-to-speech voices. This plugin will not work with non-English version of your OS. You should setup and check your English voice recognition on Windows 10 or Mac BEFORE this plugin installation.
!!! no X-Plane plugins/330/ menu exist more, please set command jd/fmgs/CommandShowMcdu for some keyboard key and use MCDU MENU to operate ground handling.
HOW TO INSTALL / UPDATE:
Download link
http://jardesign.org/a330/download/inst … 11_313.zip
Please be sure what you have actual version of Ground Handling plugin to be well-compatible with XP11
Download link: http://jardesign.org/forum/viewtopic.php?id=4133
  - be sure, that you use X-Plane 11.30
  - copy unziped "JD330XP11" folder to ..\X-Plane 10\Aircraft\ folder
a330 use NavData from
- please post your log.txt + x-life.dmp if Crash happen and you are on Windows.
Thank you!!!!
Re: XP11 JD330 v.3.1 r1, r2, r3
reserved
Sorry JAR, but where is my LINDA in this version sad
Please follow about using with JARDesign CoPilot plugin: in description
THX JAR. I was so happy of the new version that I see through the instructions. Once again, thank you.
6 (edited by jcdp 2018-12-19 19:05:02)
Hi Eugeny
Thanks for the update
Works fine .
But even with a chosen RNAV approach LINDA automatically pushes the "LS" knob so I have to deactivate it and push "APPR" knob for RNAV landing … but now it works correctly .
Can we expect the right choice from LINDA depending on ILS or RNAV approach and landing in the future ?
Anyway thanks for this Copilot addon
features:
Nice to hear that AirFMC should work again from this version on.
But it doesn't work for me yet.
Wumsel wrote:
features:
1.7 !!!
I am in contact with Joao Cabral, we can expect it soon.
I will discuss this with she and with our script autor too. Thanks for this note!
Thanks for the new Version. Hope to find some time to test it soon. Unfortunately I wasn‘t able to to test the Beta as much as I wanted..
Thanks for the update !
But: is it possible that there is no copilot voice anymore ( I don't use the Linda plugin) ?
Did you install it as described in instruction?
I downloaded and installed this version 3.1R1 today and activated with no problems.
Problem though is that all co-pilot call outs are gone.  No "start engine", "V1", "rotate" etc.  Deathly silence.
I also own the J320 and it works fine at this stage.
Any ideas?
Not all of us want to use the co-pilot Linda plugin.  I for one like to do everything myself.  OK, I know that is not how it is done, but after all this is a sim.  I don't see this as an update.  Rather a downdate.
In this case you just not need install new version.
Thanks for this update but i need precision, do i lose the classic co-pilot's voices if i don't install co-pilot plugin ?
Thanks again for your work, happy christmas !
I guess yes, because in base version of A330 v3.1 r1 there is no call outs for v1 or rotate.
Jar Iam a bit disappointed of this update expecting to be adjusted for XP11.30 there is still black smoke from the engines hmm
Please JAR, restore the sounds of the co-pilot when not using co-pilot plugin.
Why not use prev version in this case?
because I would like to benefit from these improvements:
I also really would like the classic previous copilot voice guiding us through the flight while I'm doing all the work. Maybe Jar could keep that feature always but also have the copilot plugin as an option like now. Thanks.
I agree.
This is possible. You may just take ../330/plugins/drf and ../330/plugins/fmgs folders from new version. On this stage - only this way, please.
24 (edited by rafalec 2018-12-22 18:41:20)
Cool, good news, many thanks.
Thank you for the updated A330. But i have a problem, i have no mcdu and no fmc. Can anyone help me,please.
