There is no longer a plugin menu. All settings are accessed from the MCDU. This also applies to ground handling when calling service vehicles, etc.
JARDesign Group Board → Beta-versions (Download & Discussions) → v.3.0 beta 1, 2, 3, 4, 5, 6 public tests
I loaded the A/C again today and couldn't get rid of the pink windscreens. I cant disable the rain effects (suggested in another post) in the A330 menu as it is missing from the plug in menu.
I think you missed the information ,written in red, in the first post (#1) .
Downloaded last version 3 beta 4 and had a complete flight from LFMN to DTTJ with Tunisair livery (as the line exists in real life).
Great flight from cold and dark to landing and securing the aircraft.
I noticed any problem, except the bird occasionally wanders off the NAV course during cruise.
She also seems floating sometimes in the air from left to right and right to left, as taken by violent turbulences (but there wasn't any turbulences, because the problem stops immediatly when descending). I never noticed such "behaviour" by flying with the 2 version wich is this last stable version of A330.
Except this kind of problem, this bird is really amazing !
May I suggest to implement more pop-up screens if possible ? It should be more greater.
Thanks to JAR designers for all this perfect work, and for all to be done... ![]()
Hello, just flew LSGG / LFBD with beta 4. Nothing to report particular everything went well since dark and cold. The plane is very stable even with wind at 60 knots at 26000 feet. Great work beautiful aircraft and thank you to the JAR team. Keep improving ...
Flying from DTTJ to LEMG , everything was fine up to climbing .
After a while all buttons became inactive ... no possibility to change altitude ,turn off landing lights, to set std pressure ...
and to set a target altitude for starting descent ...
So I stopped X-Plane ...
(on other previous flights this also happened ...
and to set a target altitude for starting descent ...So I stopped X-Plane ...
X-Plane has an issue where "focus" is lost while in the flight deck. To fix this, move the cursor to the top of the screen on the menu bar, click the bar with the mouse, and then the flight deck should be active again where your mouse works, i.e. you can manipulate knobs, press buttons, etc. This is a problem with other planes too....just FYI if this is the problem you're experiencing.
jcdp wrote:Hi
Many thanks for your quick answer .
PS: sorry but I did not catch "FYI"
Griff wrote:jcdp wrote:Hi
jcdpPS: sorry but I did not catch "FYI"
maybe ..."For Your Information"
Yes, "for your information." Thanks.
Good evening... I Just crashed on putting the arrival on a330 v3 b4.. here the logs:
beta 5 just posted.
Need to reinstall full aircraft.
New feature add (if someone really need this) - instant flightplan generator:
As example:
Enter from-to like LFPG/EDDH at Init A page and select R1
Select <REQUEST at next page to generate flightplan
There is a MANY rules to generate plans, this feature use just one of them.
Sure, you may continue to use service like http://rfinder.asalink.net/free/
or prepare plan yourself or use X-Life for this or enter it manually
This is only one additional way..
Got it !
I made a new complete flight from EDDS to LFML for another testing.
Nothing special to report. Everything worked well during the flight.
Except the same behaviour as reported above (post 230), i.e. the bird occasionally wanks and swings in the air like floating when in cruise. I'm sure it's not a question of turbulence, because the swing and dancing effect is regular from left to right and from right to left, and immediatly stops when descending at T/D.
Nothing else to report but I'd like to know if it occurred to others beta-testers.
Thanks to all of you and to JAR Team.
The A330 is a very nice plane that gives me satisfaction.
But two problems:
1 / impossible to remove the discontinuity located after the airport of departure. Obligation of an SID.
NB: In the V2, it was possible and interesting to make "takeoff-landing loops"
2 / IMPORTANT : the A330 cannot follow the LNAV and VNAV parameters of the MCDU. As a result, the A330 loses AUTO-PILOT, speed, altitude, etc.
Here is a 7 minute video to show you the problems. Here : https://drive.google.com/file/d/107aXLK … sp=sharing
Flight LFSB (Basel-Mulhouse) - LFPO
RWY 33
SID: LUME6N
AIRAC: 1801 - January 2018.
Thank you for your attention. Best regards.
Peter (in French)
But two problems:1 / impossible to remove the discontinuity located after the airport of departure. Obligation of an SID.
NB: In the V2, it was possible and interesting to make "takeoff-landing loops"2 / IMPORTANT : the A330 cannot follow the LNAV and VNAV parameters of the MCDU. As a result, the A330 loses AUTO-PILOT, speed, altitude, etc.
RWY 33
SID: LUME6N
AIRAC: 1801 - January 2018.Thank you for your attention. Best regards.
Peter (in French)
So.. that was LFSB 33 LIMEN6 departure. I will check.
1. DISCO just try to show you what you cant flight this path. Your task is not "remove" it, but prepare good flight plan.
2. As I see, there is no SPD constrains for this SID. So, only way - set speed in selected mode for this kind of SID during departure.
Thanks for your info and video, so detailed.
Hello can you confirm that for the moment there is no TRANS in the FMC and that the problem will be solved
Beta 5:
1. (Minor glitch) You have to exit and restart X-Plane to get rid of the Rainshield after first activation. Reloading the aircraft is not good enough. (No big deal though.)
2. When in TOGA and then pulling back throttle to climb, the AP goes wild and sets the ATHR to TOGALK, even above the AF. Only way way is to disengage the ATHR, match the TOGA speed manually and reacttivate ATHR again.
3. At TOD sometimes, tuning in your ILS altitude, and the aircraft starts to decent at 8000 FPM. (Only happens sometimes, so I'm not sure how to reproduce yet, working on it.)
4. Also glitch with refueling, when calling only the Gasoline Truck from GHD no refuel window appear. If calling all things it appears.
(Video still processing on YT... https://youtu.be/9TMKOefAKCQ?list=PLEMT … Gkqy-rEc-j )
Yes, any statement on this would be appreciated. At what point in the beta process can we expect a complete MDCU with proper transition selection for the landing runway?
Crash when entering flightplan.
Additionally, I couldn't get the flightplan to load as a company route.
Speedbrakes are without function. XP 11.11 / A330 V3beta5.
Peter092 wrote:Hello
RWY 33
SID: LUME6N
Peter (in French)
2. As I see, there is no SPD constrains for this SID. So, only way - set speed in selected mode for this kind of SID during departure.Thanks for your info and video, so detailed.
The SID is LUME6N
See picture for contraint
Your FLP:
KSFO SID SYRAH Q128 JSICA DCT ILC DCT KD45S DCT KK39A DCT FSM DCT MEM DCT HUTCC DCT KNSAW DCT RUSSA STAR KATLYour FP in SkyVector:
KSFO SYRAH JSICA ILC KD45S KK39A FSM MEM HUTCC KNSAW RUSSA KATL
And in your Log:
FMGS: 553 : ICAO-format plan export to Dataref: KSFO SID NTELL DCT CABAB DCT KICHI DCT KATTS DCT KITTN DCT ROCCY DCT HASSL DCT TAHIB DCT DIXAN DCT MIRME DCT PNH DCT CRUSR DCT IRW DCT TUL DCT PLIED DCT LUKKY DCT ARG DCT ZESAM DCT KIMEL DCT SOPIE DCT BNA DCT LGC STAR KATL
FMGS: 596 : add Leg: I10,IF,CTEEE,33.620017,-84.651053,IOMO,275.0,11.8,2,4000,0,0,0,0,0,0
FMGS: 596 : add Leg: I10,CF,ZMANN,33.620169,-84.550981,0,IOMO,275.0,6.8,95.0,5.0,1,2700,0,0,0,0,2,0
FMGS: 596 : add Leg: I10,CF,RW10,33.620272,-84.447878,0,IOMO,275.0,1.7,95.0,5.2,1,1055,0,0,0,0,3,0
FMGS: 596 : add Leg: I10,CA,0,95.0,2,1400,0,0,0,0,0,0
FMGS: 596 : add Leg: I10,CF,SCARR,33.378639,-84.435069,2,ATL,185.0,15.0,185.0,15.0,2,3000,0,0,0,0,0,0
FMGS: 596 : add Leg: I10,HM,SCARR,33.378639,-84.435069,2, ,0.0,0.0,5.0,04.3,0,0,0,0,0,0,0,0,0
FMGS: 596 : MessageRed: Missed Leg: I10,HM,SCARR,33.378639,-84.435069,2, ,0.0,0.0,5.0,04.3,0,0,0,0,0,0,0,0,0Hello
RWY 33
SID: LUME6N
Peter (in French)
Did the same flight, yes SID is needed (LUME6N) otherwise no problems with speed or AP out of Basel.
Video, log, picture? For me they work fine.
Just some reflections, I might be totally off, but it feels like most, including myself, is used to the old version of the A330, which was more basic and now have moved up to a more advanced version and that is not as forgiving to the pilot. This is all good at least in my opinion, but I think it can also be very confusing if you have flown the more forgiving version a long time.
I don't claim that this is a fact, it's more of a reflection on what's going on.
