Topic: v.3.0 beta 1, 2, 3, 4, 5, 6 public tests
This is next public version of a330 for X-Plane 11. Please take part in this beta-tests if you really want be beta-tester. If you want fly-ready product - please just wait.
Main improvement - new FMGS, based on C++ (instead of SASL + basic X-Plane FMS)
new features:
+ compatible with GHDeluxe v.040118
+ new MCDU MENU functions (you can operate with Ground Handling, Doors, Loading, Tow)
+ operate settings via MCDU MENU
+ separate Ground Handling operation (MCDU MENU -> Handling, next - select neeeded cars and click Drive Up)
+ MCDU movable widget (click on 3D MCDU or use Command jd/fmgs/CommandShowMcdu)
+ ND non-movable widget (click on ND)
+ Save coRoute flightplan using MCDU DATA -> Click right Arrow -> Pilots ROUTES, enter name and click SAVE
+ takeoff with heading preset
+ ND && MCDU indication and functions reworked
+ follow Speed Constraints
beta 2:
+ enter Cruise Level/TEMP as 410/-62 = CTD fixed
+ no SPD Cnstr on DEScend fixed
+ VLS is too high fixed
+ Heading knob turns with the plane during taxi fixed
+ 111.50 as ILS freq here, it tells me not in the Data base (my enter via radio panel)
+ several CTD fixed
beta 3
+ bug fix
beta 4
+ bug fix
beta 5
+ add instant flightplan generator
beta 6
+ bug fix
!!! no X-Plane plugins/330/ menu exist more, please set command jd/fmgs/CommandShowMcdu for some keyboard key and use MCDU MENU to operate ground handling.
Download link: http://jardesign.org/a330/download/install/JD330_v3.zip
- be sure, that you use X-Plane 11.01-11.11
- copy unziped "JD330_v3" folder to ..\X-Plane 10\Aircraft\ folder
a330 use NavData from
Please note what this time we have beta of JD330 ("beta" - product for testing and may not work well, hare errors and so on). If you need release, need stable version, please wait.
- please post your log.txt + x-life.dmp if Crash happen and you are on Windows.
Please care about information what you will post here and try to determinate reason if issues happen - sure, he interesting in aircraft test and troubles but want to avoid work with "pilot" issues.
Thank you!!!!
