Topic: v.3.0 beta 1, 2, 3, 4, 5, 6 public tests
This is next public version of a330 for X-Plane 11. Please take part in this beta-tests if you really want be beta-tester. If you want fly-ready product - please just wait.
Main improvement - new FMGS, based on C++ (instead of SASL + basic X-Plane FMS)
new features:
+ compatible with GHDeluxe v.040118
+ new MCDU MENU functions (you can operate with Ground Handling, Doors, Loading, Tow)
+ operate settings via MCDU MENU
+ separate Ground Handling operation (MCDU MENU -> Handling, next - select neeeded cars and click Drive Up)
+ MCDU movable widget (click on 3D MCDU or use Command jd/fmgs/CommandShowMcdu)
+ ND non-movable widget (click on ND)
+ Save coRoute flightplan using MCDU DATA -> Click right Arrow -> Pilots ROUTES, enter name and click SAVE
+ takeoff with heading preset
+ ND && MCDU indication and functions reworked
+ follow Speed Constraints
beta 2:
+ enter Cruise Level/TEMP as 410/-62 = CTD fixed
+ no SPD Cnstr on DEScend fixed
+ VLS is too high fixed
+ Heading knob turns with the plane during taxi fixed
+ 111.50 as ILS freq here, it tells me not in the Data base (my enter via radio panel)
+ several CTD fixed
beta 3
+ bug fix
beta 4
+ bug fix
beta 5
+ add instant flightplan generator
beta 6
+ bug fix
!!! no X-Plane plugins/330/ menu exist more, please set command jd/fmgs/CommandShowMcdu for some keyboard key and use MCDU MENU to operate ground handling.
Download link: http://jardesign.org/a330/download/install/JD330_v3.zip
  - be sure, that you use X-Plane 11.01-11.11
  - copy unziped "JD330_v3" folder to ..\X-Plane 10\Aircraft\ folder
a330 use NavData from
Please note what this time we have beta of JD330 ("beta" - product for testing and may not work well, hare errors and so on). If you need release, need stable version, please wait.
- please post your log.txt + x-life.dmp if Crash happen and you are on Windows.
Thank you!!!!
When trying to enter Cruise Level/TEMP as 410/-62 get consistent crash to desktop of Xplane
3 (edited by Porthos 2018-02-15 02:20:21)
Suggestion and request:
1: individual range setting capability please instead of turning one knob changes both ranges;
2: individual QNH setting knobs instead of one knob changes both QNH windows and STD setting.
3. INdividual throttle movent;
4. Individual reverser movement
5. Mouse wheel to rotate knobs
Reason is if shared cockpit becomes available these features are needed.
First test flight: handles well.
Just made a quick hop from LFBO to LFPG.  For the most part, things went very well.  On approach, I selected RWY ILS 26L with the KEPER 7W arrival.  Then, I should have been able to choose the BANOX 4W RNAV transition for 26L but the CDU did not list any available transitions.  I had to input the individual waypoints for the RNAV transition and the CDU did recognize them as valid NAV points.  I have verified that the AIRAC is current and both locations have the current AIRAC installed (default XP 11 and the JARDesign/_navdata).
A few questions:
1) When using the settings in the CDU for ground handling, how does one execute the command to call specific items, i.e. only one stair and specific loaders?  I clicked each one individually but nothing happened.  When I selected "call all," all of the ground equipment arrived (things worked as normal if I used the ground handling from the plug-ins list in the menu bar).
2) Is there no longer a setting to turn off the turbulence effect?  I tried to page down and left and right in the CDU but there aren't any other pages.  It would be nice to have this option back.
5 (edited by snapshot21 2018-02-03 05:55:26)
VLS is too high. Should be lower than Vapp.
Plus im getting left to right oscillations during cruise no matter what altitude.
@griff:
To geh the trabsitions, you have to select the arrival rwy and then chose no star. After that the transitions should be displayed.
To question 1: Chose the Desired Service and Click Drive up. If you then want to get another one just select it.
CTD while taxiing to Rwy 23R in EDDL:
Sorry I do not know if this is the correct topic, but I have a question: buying the current A330 that is for sale on the JAR or Org site, will I have all updates throughout XP11 or will I have to pay an extra fee to update the new V3 version?
Is our current Serial# for v2 valid for this Beta (v3)?
The existing serial will work guys.
Another bug I noticed, the Heading knob turns with the plane during taxi.
Plus the aircraft pitches down to the point of losing altitude during acceleration (for example when accelerating to 250knots after takeoff)
I was hoping controls would be unified with the A320, so that the mousewheel could be used for rotary switches.
+1
I don't know where the trouble is from but got X-plane crash when trying to enter "xxxxx/xxx" flight level/ temp ...
see added files .
regards
PS:
Please what is the format for this input ? an example ?
15 (edited by Luke173 2018-02-03 11:30:53)
Many thanks for the new Version, this is very much apprechiated JAR!
I do have some findings:
Screenshot 1: I can not delete the discontinuity here
Screenshot 2: I try to enter 111.50 as ILS freq here, it tells me not in the Database. This might be true, but I have the ILS, so why not just tune it anyway? Also here, I can not set a course CRS for LOC 1. (Screenshot 5 is the ILS here)
Screenshot 3: The Push-Pull indication stays on if I switch from Cockpit mode to another view, if the cursor is left on one of the push-pull knobs
Screenshot 4: I cannot manually enter waypoints here, I thin it should let me? (not sure about this)
As said, looking forward to this fine JARbus big_smile
Luke
http://jardesign.org/forum/img/m/118/t/p1c5dmgfhd10239bf103k1e5dp3l3.jpg
http://jardesign.org/forum/img/m/118/t/p1c5dmgfhdh691qcm2ct1v0k1tmv4.jpg
http://jardesign.org/forum/img/m/118/t/p1c5dmgfhd2liq6e1olj15vp8sb5.jpg
http://jardesign.org/forum/img/m/118/t/p1c5dmgfhd1p3ejs2vjj12b1q6b6.jpg
http://jardesign.org/forum/img/m/118/t/p1c5dmgfhdlj1jmhjjbl0v10bs7.jpg
is the A330 usable with 11.20 in vr ?
I know that on the A320 the AP is not working, is this the same for the A330 v3 ?
After starting the APU or connecting the GPU my ND and my mcdu  wont light up. I checked the brightness and everything i could think of but cant get it working. Also i cannot  set a command  for jd/fmgs/CommandShowMcdu as recommended as i dont have this Option in my Settings. In the Log file I found out that there is an error Code 1114 while loading the fmgs/win.xpl file
see added files .
regards
PS:
I put 330 and click on CRZ FL, the temp put alone.
Henri
I like the A330 v3 a lot. First trial flight from EGKK to EHAM went very well, everything in XP 11.11 Final ran smoothly. I had a few problems when opening the 330, not sure how to open the menu on the MCDU without the aircraft powered up, the way I found to do it was start the GPU from the dropdown ground handling and then go into the aircraft and carry on from there.
Had a couple of problems loading the flight plan which caused a crash to desktop, probably down to me, but once loaded it was fine. I like the new MCDU layout and I love the popup screen to see the route better.
I also like the extra information on the screen, VOR 1 and VOR 2 giving information, and flight levels all showing. The A330 seemed to fly the arrival better.
Worked well with X-Life, no problems there. Sounds were good, I don't know whether or not there has been some collaboration with BSS.
I will be running the 330 a lot in the next few days to try it out.
Great work JAR.
Great work JAR.
Can you add you profile data...
Вылетел на рабочий стол при заходе в Риге.
Great work JAR.
You don't need power. Just click on the MCDU  and you can change your settings.
23 (edited by zpampal 2018-02-03 16:32:31)
Downloaded, installed. Used my existing key. And this is what I get.
24 (edited by vishido 2018-02-03 17:31:07)
Hi Roman, I can't takeoff with the airplane. My xplane crashed on LIRF taxiway and now during MCDU configuration putting FL and T in INIT PAGE with the airplane at stand 306 EGLL.
Running Xplane 11.10 on Windows10.
Works excellent. Thanks!
X-Plane 11.30, JarDesign A320, Jardesign A330, Jardesign X-Life Deluxe, Jardesign Ground Handling Deluxe.
