MikeyOT wrote:Apologies if someone has asked this before but I did search before posting this!
When I load the A320 (3.0r1) into X-Plane (11.0rc1) it appears to come with a tow truck. I use your Ground Handling Deluxe and some of those vehicles drive through that tow truck as though it weren't there. Then, when I "Call Tow" a second tow truck appears and drives itself into the same location as the original, occupying the same space.
I suspect that the tow truck that comes with the A320 is also the reason the A320 icons appear so small in the icon tiles in XP11.
How can I get rid of the tow truck?
I suspect that the first tow truck is part of the scenery you are at. You would have to "hide" or delete it from there using WED., for example.
