Good morning .
I have a problem I have downloaded the last update of the A320 and even the IRS, the route well introduced in the FMC, and the corresponding parameters, I do not see the speed or altitude of the waypoints in the FMC. Of course, the plane stopped. Could it be for the latest update of xplane 11, or why can it be?
A greeting and I await your news
Nicolas G.
77 (edited by dimkzr 2017-04-05 14:40:47)
You probably haven't filled fuel init page (FMC > INIT > right or left arrow to display second page):
http://jardesign.org/forum/img/m/4188/t/p1bcv8ou3db1d18bb2be15kl73h3.png
http://jardesign.org/forum/img/m/4188/t/p1bcv8pb2u6vodfv1hoc1udr1noia.png
P.S. You can take screenshots with X-Plane by pressing Shift+Spacebar. They'll be saved into YOUR-XP11-FOLDER\Output
My ground steering issue is solved. I had "Nosewheel Tiller" assigned on the large dial of my throttle and this overwrote the yaw signal from the joystick.
So far I can say that I like the XP11 quite a lot and it looks like the issues I had on XP10 are solved!
Glad to have my a320 back!
airbus321ib wrote:
Good morning .
Nicolas G.
Please post your log.txt from this flight, otherwise no news...
nevzatolum wrote:
The plane shadow looks like a sawtooth.
That's because you are using NVidia Sourround for multiple monitor display.
If you set up a multimonitor in XP11 itself (without NVidia sourround) the shadows
are fine :-)
I don't think it was a bug. Just a mistake on his side. Let him try my suggestion first.
82 (edited by MikeyOT 2017-04-06 07:46:54)
Apologies if someone has asked this before but I did search before posting this!
When I load the A320 (3.0r1) into X-Plane (11.0rc1) it appears to come with a tow truck.  I use your Ground Handling Deluxe and some of those vehicles drive through that tow truck as though it weren't there.  Then, when I "Call Tow" a second tow truck appears and drives itself into the same location as the original, occupying the same space.
I suspect that the tow truck that comes with the A320 is also the reason the A320 icons appear so small in the icon tiles in XP11.
How can I get rid of the tow truck?
83 (edited by marcelbrietzke 2017-04-06 18:42:01)
Dear JAR and Crew,
today i had some weird experience with the A320. I was testing 124th ATC plugin(not sure if this is conflicting)
Full documented on Video.
https://www.youtube.com/watch?v=fzHUgbFSs8o
First Error at 20:30 minute
Second Error at 23:35 minute watch to 25:00!!!
Last Error at 43:23
To mention i use custom soundpack!
Log file attached.
Hummm, I am having a bit of trouble. The new R! version does not want to lock onto the route .
Has anyone else had this problem?
iMac (Retina 5K, 27-inch, Late 2015
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
AMD Radeon R9 M395X 4096 MB
mac os 10.12.4
Xplane 11RC1 (64 bit)
X55 Saitek Pro Rhino Stick
X55 Saitek Rhino Throttle
I suspect that the first tow truck is part of the scenery you are at. You would have to "hide" or delete it from there using WED., for example.
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
mac os 10.12.4
I have the same machine except I use the Saitek X52. Please post your log.txt, otherwise it's not possible to help.
Haha!  I was just coming back on here to say exactly that.  I loaded the A320 at a different gate this time and there was no tow truck!  Thanks anyway laohu314! smile
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
mac os 10.12.4
You should make a short HD video so we can have a look at your problem. We have same hardware configuration so this problem can be easy reproduced ..
Tried to do a flight from EIDW to LEMD this morning.  Got an SASL error after 30 mins.  Reset the SASL plugin and recovered the flight, but it happened again 10 mins later so had to abandon.
I wanted to report that the cabin lights do not work for me. Specifically the regulator that is above the switch SYS radar and that is the "Flood LT NLP"
Please thank the solution
91 (edited by dimkzr 2017-04-07 16:23:23)
I would like to report two issues I have with JAR320r1
1. If you look on pedestal or behind in the cockpit (where passengers cabin is) FPS drops VERY noticeable. From ~40 to 20-15 for me. Even with the cockpit door closed.
I know it's probably because there's a lot of polygons back there. But I don't have this problem with the latest FlightFactor 757, and their pax cabin is also very detailed.
2. The lights in the cockpit are very dim! Displays are hard to read in sunny day. Dome light have almost zero effect at dawn/dusk. Illuminated buttons (like EXT PWR) are very dim, too. And yes, I have HDR enabled.
Could it possibly be that JAR still using "old" textures? Take a look please: http://developer.x-plane.com/2017/03/dr … -aircraft/
Here's my cockpit at midnight. Each and every light is at max/bright, dome included:
http://jardesign.org/forum/img/m/4188/t/p1bd4hjhku1bau1b0c1rfo1f3d101q3.png
simonbarget wrote:
I'm having an issue with AP and SASL. How do I post my log file?
Ok - I just did it!
So the problem is that I get an on screen SASL error message at the beginning of the flight and the autopilot goes crazy. Hoping you can help.
Got the same issue.Autopilot is going crazy
93 (edited by VMaximI 2017-04-07 21:23:19)
Разработчикам спасибо за прекрасную работу, но ложечка дегтя имеется.
При превышении максимальной скорости слетает SASL и пока скорость не вернется в допустимые пределы ошибка не пропадает. Прилагаю логи и видео.
https://youtu.be/1uQ0vfqZB1o
Кстати то-же самое происходит и при снижении скорости ниже минимально допустимой (приближении к сваливанию).
OS Win7,  Intel Core i5-6500 3.20GHz, DDR4 16GB 2133MHz, nVidia GTX-970 4096 MB, XP11v.pb13, A320v.3.0b4, Python Interface, XP NOAA Weather v2.4.4, XPUIPC, BLU-fx, EFASS XPSM, FlyWithLua.
The A320 icon in plane select menu is still incorrect.  It looks pretty bad compared to all the other aircraft that are doing it correctly.
"Finally, third party aircraft authors: please use our icon generator and don’t just splat a screen-shot into the X-Plane 11 icons. The aircraft picker is going to look terrible if it turns into a tile grid of screenshots."  - Ben Supnik from Laminar.
95 (edited by asgar 2017-04-08 09:14:12)
Hi there,
i have a new issue with the JAR320 rc1, which did not happen on older beta versions.
The cabin pressurization is not working correctly. X-Plane reads a different cabin alt then the Pressurization Screen (where everything is fine).
http://jardesign.org/forum/img/m/3448/t/p1bd6dela2c1gpk1re0dui7ku3.png
This results in hypoxia, which is very annoying.
I use the latest version of the A320 and XP11.
Asgar
96
Dear Sirs,
today I bought the A320 via download link.
Until now I have mighty problems with the product.
I have NO IDEA what is going on, but I submitted a ticket, as I got a logn row of
Data ERRORS, and RED MESSAGES on screen, that I need to contact the support,
what I have done via ticket, including the log file.
I PAID 79.- EUROS for a product, that is giving me a killing headake, as I do not know
what is going wrong. The Activation was a horrortrip.. and now I have nothing what I
can do as waiting for someone to reply to my ticket......
-- FMC is giving me a killing klicking.... continues.... klicking and klicking sound, when pressing buttons,
    what I cannot stop in any way
-- Cannot continue the start up, as Server is always disconecting
-- RED ALLERT WARNINGS popup constantly that the SASL or what ever is accring an Error
--- Please contact Support RED ALLERT... again and again and again
--- WHY am I connected to a server??????
Is this a JOKE
I am so upset
Patrick
Ok - I just did it!
Need just redownload 320 please.
dimkzr wrote:
When I'm trying to disable "TERR ON ND" after landing the whole ND display goes black (and "terr on hd" switch stays illuminated):
http://jardesign.org/forum/img/m/4188/t/p1bcqk8eu2lnd1vjh1udj1prg1umo3.png
Will try to get the same on my computer to fix this in R2.
marcelbrietzke wrote:
Dear JAR and Crew,
Last Error at 43:23
Log file attached.
So, you are not stabilize aircraft and get toga lock at 20:30
You need just redownload and reinstall aircraft
