Topic: a320neo JARDesign ver 3.0r1-6 WIN/MAC 64 bit (X-Plane 11)
http://jardesign.org/forum/img/m/22/t/p1bckck0mj1qcgg3n1ge4vd26er3.png
Download link: http://jardesign.org/a320/download/inst … 20XP11.zip
  - be sure, that you use X-Plane 11.00
  - please visit www.simliveries.com to get 130+ free liveries
a320 use NavData from
and put new cycle to ../X-PLANE 11/Custom Data/GNS430/navdata/ folder (create this folder if need)
What new in this version:
+ External 3D updated by Felis
+ Internal 3D and Ground stuff updated by Dron
+ Systems updated by JAR
Need details? Well..
for R1:
+ objects and textures was reworked according with new material system of XP11.
+ redesigned/retextured MCP especially around displays (so you can see all panels layers here)
+ new textures on spots around
+ reduced amount of loaded textures (some are gone)
+ no more any gaps between panels (no flicker on any gaps in cockpit)
+ new reflections
+ now all cockpit screens/lcd panels have new glass with reflections
+ new things in cabin and new cockpit/cabin glasses (inside and outside)
+ some changes in Sky lights in cabine by yours requests
+ reflective ground stuff
+ NavData was removed from XP11 by Laminar Research and this was fixed for a320 (add _navdata with old Aerosoft cycle direct to a320 folder). Fixed.
+ User can select navData source at MCDU Status page. Improved.
+ add Diagnostic plugin, what can help if some installation was wrong (red message at screen if problem happen)
+ Perfomance and fuel calculation was broken in XP11 and fixed for version 3.0
+ Navigation system was broken and FMGS was reworked to be compatible with new XP FMS.
+ Cockpit buttons night lighting was broken. Fixed.
+ rework ND flightplan path drawing.
+ vertical profile calculation reworked
+ NEW CRZ FL option was reworked
+ Go Around fixed
+ ILS approach fixed
+ Impossible engines shutdown fixed
+ cockpit 3D light fixed
+ SPEED mode unstable fixed
+ LVR CLB flash fixed
+ display brightness improved
+ flight log improved
+ horizontal FD during SRS/RWY fixed
+ "CF" legs drawing improved
+ Rollout mode (Autoland) unstable fixed
+ reflection maps for external 3d improved (thanks Rashid)
+ brake and clock night lighting (front panel) fixed
+ baro selector work fixed
+ fcu knobs work improved (mousewheel selection work both for classic/comfort manipulators style) - please use MCDU Menu page 2 to switch style
+ not-transparent in-cockpit sunglasses fixed
+ engines start issue fixed
+ ILS DOTs indication fixed
+ JARDesign "Home" livery add (Thanks to Slava!)
+ www.simliveries.com download service add for free a320 liveries
For R3:
+ EWD/SYS disp/brightness fixed
+ displays incockpit reflections fixed
+ Terrain On ND "black" issue fixed
+ SASL error during AP auto disengage fixed.
+ Perfomance table fixed
For R4:
+ Add ability to hide rain windows using MCDU MENU Page 3
ForR5,R6:
+ NEW CRZ FL issue fixed
+ “flying cars” issue fixed
+ TOW issue fixed
- All users who bought the A320 AFTER the X-Plane 11 presentation event (October 2016 and later) may use their serials with X-Plane 11. If problems - please http://www.support.jardesign.org
- All users who bought the A320 BEFORE the X-Plane 11 presentation event (October 2016 and later) may update their serials (get new one) to make it worked with both - XP10 and XP11.
This JARDesign service should help for any users, what have a320 from any shop http://jardesign.org/a320-serial-update-step-13/
Update fee is about $19,95 (not include VAT for your country). Sure, you own a320 for X-Plane 10 and may continue to use it with X-Plane 10 simulator with no problem. No update need in this case. Support is continue.
Thank you!!!!
very nice! thanks for your work smile
Good efforts , can't wait for the download link )
Very good news ;-)
5 (edited by dimkzr 2017-04-06 07:24:45)
Completed my first flight with R1 today, EGPH-EHAM.
It went suspiciously well :-)
And thanks for fixing those stripey windows.
Keep up the good work!
http://jardesign.org/forum/img/m/4188/t/p1bcmdhvehl2m1bsjmlsts119au3.png
whiskey... waouhhhh...
Cheers Eugeny
I found out why I can't do an ILS landing on EDDL RW05L: ISL frequency is wrong in MCDU.
Any idear why this frequency is wrong ? Where does these data came from ?? Is it the airac
cycle ?? Or the airport data ??
http://jardesign.org/forum/img/m/552/t/p1bcmp0osm18ff9o1149l1evs1rh93.jpg
Need load at EDDL and select X-Plane MAP. Next - check what freq fot that ILS you will read. a320 take it from NavData. Scenery - from own X-Plane files (different navdata cycle or data may be).
9 (edited by dimkzr 2017-04-02 09:04:46)
thomas_99,
Where did you get 109.50 from?
The correct frequency for 05L is 110.95.
I have 1702 cycle for "new" XP11, "old" GNS430 and JAR.
See my screenshot - I'm standing on 05L in default EDDL scenery.
http://jardesign.org/forum/img/m/4188/t/p1bcmu3vcvvnar9s8kgssa1ia3.png
http://jardesign.org/forum/img/m/4188/t/p1bcmu7eer1q1s1obn1hr01va07en3.png
Congratulations on the update I will produce a video which will be uploaded on Tuesday
www.youtube.com/wycliffeb
Here are my informations:
http://jardesign.org/forum/img/m/552/t/p1bcn3bsmnic7hjk1pkn1sdqtc83.jpg http://jardesign.org/forum/img/m/552/t/p1bcn3bsmn17opldm10a615hrmt24.jpg
The installed Airport is Aerosoft EDDL, the charts are from VATSIm GERMANY.
Hmmmm, about ILS 110.95:
*only available for FS9/FSX/P3D with free addon "EDDL additional ILS05L 1413.zip"
So I'm a little bit confused...
dimkzr wrote:
thomas_99,
Hi , i am not able to see any messages of the ECAM Status. It is just empty. Please advise. Thanks
Great flying well.
Great new paint job.
http://jardesign.org/forum/img/m/48/t/p1bcn51flim6s90f1jhh8t819gt6.png
Mike
hmm
14 (edited by dimkzr 2017-04-02 11:06:12)
thomas_99,
My guess is that in "EDDL additional ILS05L 1413.zip" 1413 stands for ancient AIRAC cycle from 2014.
However, if you look at their latest ILS 05L approach chart dated 20.05.2015 you'll see the correct frequency which is 110.95:
http://nav.vatsim-germany.org/files/edg … ILS05L.pdf
So, my second guess is that you're using very, very outdated expansion for your EDDL scenery (EDDL additional ILS05L 1413.zip). Getting rid of it will probably solve your problem.
Thanks to the team !
Test flight just now LFBH-LFBP
all ok and perfect ;-)
Hello, first l'd like to say THANK YOU for this nice aircraft. I came from P3D to X-Plane 11 and the P11-virus touched me.
But I don't understand the posts about the NAVDATA-UPDATE. I think, it's a little confusing. I am reading about XP11 and then I am reading to put navdata in XP10-folder. Also reading about A320 and putting navdata in A330 folder.... Is it possible to write a short tutorial about updating navdata in XP11 to use A320 and A330 with the newest navdata? Take care, Thorsten
I can't use flaps (voice massage "flaps zerro" ) and can't change flaps. XP11 artist JD 3.0
dtaldykin,
You need hydraulic pressure to operate flaps.
To put things simple, try to extend flaps with your engines running (use "hot start" button).
Lucky for us that JAR is only the developer and not flying as a pilot our newest A320 version !!
We have surely crashed on the Metallica party house......
Totti,
it's not a tutorial, but that's how I did this:
- purchase latest Navigraph cycle or subscription and proceed to this page: https://navigraph.com/FMSDataManualInstall.aspx
- download "JARDesign A320neo - native" or "JARDesign A330 - native" (they're basically the same)
- download "X-Plane 11 - native"
- download "X-Plane GNS430, 777 Worldliner (Ext/Prof) ..... "
- unzip "JARDesign A320neo - native" or "JARDesign A330 - native".
You'll end up with five .txt files and "PROC" folder (see attached screenshot). Select them all and copy-paste into "YOUR-XP11-FOLDER\Aircraft\YOUR-JAR320-OR-330-FOLDER\_navdata" replacing everything there.
http://jardesign.org/forum/img/m/4188/t/p1bcnapafgt79ild1to0qtb1p9b3.png
- unzip "X-Plane 11 - native" and you'll have some .dat files and "CIFP" folder (see screenie below). Again, select everything and copy-paste into "YOUR-XP11-FOLDER\Resources\default data" replacing old files.
http://jardesign.org/forum/img/m/4188/t/p1bcnb08fno5mgrp1ase4ep1gif5.png
- now, I don't actually remember what's in the "X-Plane GNS430, 777 Worldliner (Ext/Prof) ..... " archive. Unzip it, if theres a bunch of .txt files and "Proc" folder (like in the JAR archives above) - copy-paste those into "YOUR-XP11-FOLDER\Custom Data\GNS430\navdata" (if you don't have those folders - create them first). Anyway, this step is required only if you want to update navdata for older XP10 aircrafts and some third-party paywares (FlightFactor etc.)
Can anyone show on the screens what new was added in the cockpit?
I get 2 reports today about crashes on CRZ FL. As i think, one file from ZIP pack may unziped incorrect. I just repack it. Anyway, if you download it before this moment, please take this file and put it to Custom Avionics folder instead of old, to be sure.
24 (edited by amo63 2017-04-02 15:01:36)
Just out for a quick flight it looks like the cfm engine template has been changed can you confirm this and will it be available?
Hopefully get this livery finished and uploaded to simliveries this week
Thanks for your work
http://jardesign.org/forum/img/m/4051/t/p1bcnimbgs1vqoeoro6u1jmv4uq3.jpg
Looks great.  Only problem I'm seeing are ground proximity warnings when on final and fully established on localiser and g/s.  Not sure if this is a JAR or XP11 issue.
