101 (edited by VadimAir 2016-10-24 07:47:37)
Here are a some bugs in 1.3 r3.
Spoilers can be managed by mouse, but they can not be armed by mouse.
Flaps can not be managed by mouse.
Spoilers and flaps can be successfully managed (spoilers can be successfully armed) by keyboard.
I'm running Windows 10 and X-Plane 10.50.
102 (edited by Mad Mat 2016-10-25 22:55:11)
Tested again with a clean installation. The aircraft still cannot follow the FMS. It remains stuck on the rwy waypoint after take-off.
I faced with the same problem on A320.
The problem was X-FMC 2.7.
You should remove it (or rename win.xpl to win.xpl.dis), disabling by Plugin Admin doesn't help.
try to put the aircraft directly to the x-plane aircraft folder. It's said that this solves some strange problems. At the moment you have it in Aircraft/ADDON folder...
Ok, I suspected the problem was X-FMC. I had it disabled but I'll try with the plugin completely out of the plugins folder. I'll report again. Thanks for the suggestions.
Ok. The problem is X-FMC: once removed, everything goes nice and smooth. I think it should be investigated, because x-fmc is widely used for many other aircrafts.
Still no terrain "radar" on the MFD screen, and very low cabin voice.
107
Another problem. Not all the time, but 50% of the time the aircraft, after calling "positive climb" goes in A FLOOR and put engines at max and nose down with no control. The PFD show a RED bar in the speed taper, even if the aircraft accelerates over 250 kts.
In this condition the aircraft is uncontrollable and there is no way to prevent it crashes in the ground.
108 (edited by j.w.muilwijk 2016-10-31 15:20:03)
I have a suagestion can we make a PW or a GE engine doe the A330-243 that Will be great
109 (edited by richardcarter 2016-10-31 20:20:23)
I have been flying the A330 over the weekend on 10.51 without any issues, today as soon as I try to load the aircraft I get a CTD. The log file says something about failing to load the scratch pad. I have tried re downloading the latest version, it loads but after activiation I get the same crash. I have attached the log file.
Hope someone can help
Richatrd
Attachment icon bbox_log.txt 119 b, 218 downloads since 2016-10-31
110
Release!
v.1.3r3 distributive (Windows 7/8/10, MAC OS Maverick..Sierra)
New:
- 10.50 ready
- X-Life ready
- FMGS improved
- Cockpit textures and details improved
- OSX Sierra ready
Please install it as CLEAR!!! installation, not mix files with other version.
Download link http://jardesign.org/a330/download/install/JD330.zip
r2 is a repack of r1 with new (more fresh) SASL base plugin
r3 is a repack of r2 with new sound 3D plugin (OSX Sierra support)
!!! If you use BSS custom sound pack with Sierra OSX, you need wait "Sierra-compatoble" update from BSS.
  - be sure, that you use X-Plane 10.36+
  - Download more fresh version of «GndHandling» plugin from official
    board http://jardesign.org/forum/viewforum.php?id=29
a330 use NavData from
If your activations are over - contact SUPPORT http://support.jardesign.org/
Thank you!!!!
Hello guys
How Can I obtain the fix version of the BBS sounds for the A330 compatible for OS Sierra. On BSS facebook page says that it is complatible with sierra already but I bought it fom the x-plana store. I downloaded it again and I still do not get engines sounds. Am I doing something wrong trying to install it again? Can someone help me please?
Will there be NEO engines for this aircraft like in the A320?
Anyone ?
Richatrd
113
I would like to know what keys are shortcuts for viewing the pedestal, overhead and front panels.
114
You can set the shortcuts on the numpad yourself. Set the view you want press ctrl plus the number on the numpad you want to assign the view to, to recall that just press the number again
115
gilcasique wrote:
Release!
New:
- 10.50 ready
- X-Life ready
- FMGS improved
- OSX Sierra ready
Thank you!!!!
Hello guys
BSS packs include own plugin. If you not get it worked you need contact BSS support.
116
Richatrd
The same here, trying to load the aircraft and getting CTD
117
Richatrd
It is somewhat disappointing that there has been no support with this issue. I have already spent a fair amount of money on addons from JAR and is certainly making me think about upgrading when I get X-Plane 11
118 (edited by jmeleanor 2016-11-24 21:14:09)
Hi mr Romanov.
I have the same problem that above but on ground when taxiing, there is alarm about altitude, the ATH goes on alone, red bar on pfd and the check list goes from before start checklist to after landing checklist.
i tried to take of but the plane become crazy.
Thanks for your help.
A330 v13.r3 x-plane 10.51
119
May be it is related with the radio altimeter. try not to engage the AP before the radio altimeter shows a GREEN number.
120
I have reported this problems years ago but never has been answered serioulsy. Sometimes it happens and sometimes not. It looks like the developer itself doesn't know why this happens.
Hi mr Romanov.
121
It has nothing to do with the Autopilot, since it happens BEFORE the Autopilot will be engaged.
122
Guys I have a PROBLEM!!
I bought a330jar today, and the product cames without a330 plugin tab and no response in the speed, heading knobs,... (MCU)
I have Microsoft C++ 2010.
PLUGINS I use:
- Headshake
- FJCC_FMC
- ArdSim
Please help me!
My log: (in bold)
[SASL INFO] loading    cab_text
[SASL INFO] loading    mech_text
[SASL INFO] loading    mcdu_res
[SASL INFO] loading    sys_dnd_lght
[SASL INFO] loading    sys_upd_lght
[SASL INFO] loading    last
[SASL INFO] Avionics loaded
0:05:34.861 E/SCN: Failed to find resource 'panel.png', referenced from file 'Aircraft/Heavy Metal/330_JARDesign/'.
C:\Users\joaov\Desktop\X-Plane 10\Custom Data\UFMC\ufmc_sid.dat
0:05:34.861 I/FLT: Init dat_p0 type:loc_ram apt:LPPR start at:Gate S34
3Dsound Engine by JARDesign v.1.4
2Dsound Engine by JARDesign v.1.0
1Dsound Engine by JARDesign v.1.3
Clean exit from threads.
JARDesign 1D Sound Engine Disable
JARDesign 2D Sound Engine Disable
JARDesign 3D Sound Engine Disable
0:06:12.532 D/HID: HID Bridge Shutdown
----- X-Plane has shut down -----
Looks like you're missing some files . Just download the "installer" from the 1st post in this topic, unzip it and then copy and paste the A330 folder in to XP10 Aircraft folder of  you choise.
124
But then i need another serial key... sad
I know the keys only work for 4x times give it or take. I don't wanna wasted them..
Anyone has any suggestion? Please!
125
What is your problem?!
Download and make a security copy on you disk...
