Topic: XP10 v.1.3r3 250916 (Windows 7/8/10, MAC OS Maverick..Sierra)
Release!
v.1.3r3 distributive (Windows 7/8/10, MAC OS Maverick..Sierra)
New:
- 10.50 ready
- X-Life ready
- FMGS improved
- Cockpit textures and details improved
- OSX Sierra ready
Please install it as CLEAR!!! installation, not mix files with other version.
Download link http://jardesign.org/a330/download/install/JD330.zip
r2 is a repack of r1 with new (more fresh) SASL base plugin
r3 is a repack of r2 with new sound 3D plugin (OSX Sierra support)
!!! If you use BSS custom sound pack with Sierra OSX, you need wait "Sierra-compatoble" update from BSS.
  - be sure, that you use X-Plane 10.36+
  - Download more fresh version of «GndHandling» plugin from official
    board http://jardesign.org/forum/viewforum.php?id=29
a330 use NavData from
If your activations are over - contact SUPPORT http://support.jardesign.org/
Thank you!!!!
Thank you for the update! Can't wait to get her up in the skies!
Using X-Plane 10.50b5 I'm getting CTD with the following message:
"Ref count never went positive. (TEX_obj.cpp:285) X-Plane 10.50b5 (64-bit). The current beta version of X-Plane is now X-Plane 10.50b5a."
Report's been already sent and I suppose this's an X-Plane devs problem.
same as Dee. Crashed due to "Ref count never went positive".
Using X-Plane Installer and surprisingly it says the newest beta is "10.50b4" (strange because my version was 10.50b5a when running 330v1.3r1). After I rolled "back" to 10.50b4 I can start flying the A330.
Unfortunately the FMGS still requires me to enter TMPY waypoints one at a time. BTW active f-pln in selected mode doesn't change in green dashed line. Hope JAR can fix it soon.
Anyway 1.3r1 is a great update.
Please use it with stable 10.45 cause a lot of troubles with beta 1050 now.
I know about these problems but I'm staying patient smile
Thanks for the updates smile
7 (edited by Franz007 2016-07-08 10:37:01)
Hi J.A.
Thanks a lot for this update! Is this version the same as the previous 1.3b1? Because i read a post you wrote saying we dont need to update to this version if we already had the beta version? Is that correct?
Cheers
Franz
8 (edited by laohu314 2016-07-08 11:18:54)
It is stated on the release page that it is the same as 1.3b1, however, 1.3b1 runs with X-Plane 10.50b5 whereas 1.3r1 results in a CTD at start-up.
So NOT the same?
Thanks laohu!
My pleasure Franz!
Maybe Eugeny can figure out why this difference exists.
Anyway, new version was repacked (with .lua code secure procedure) - this is just a difference. Anyway code is the same. I have CTD with 1050beta5 for all versions.
So, if you are Laminar Research beta-tester (like me) i just sure - you need have at least 2 X-Plane installation
- more fresh release (for regular use)
- more fresh beta (for tests)
For example I have separate installation of
- 1036 (use it for work with PlaneMaker)
- 1042 (Use it for flight)
- 1045 (not use it)
- 1050 beta (for beta-tests and reports)
But I just test it with 1050 beta 6 (prebuild). Loaded well. No CTD.
I also get this error on loading with 10.50B5, but you can resolve this problem by copying the panel.png from the  -panel- folder in the root directory of the Aircraft.
Can you PLEASE allow us to input values into the loadsheet rather than pressing the pax/cargo numbers 100 times. Another nice addition is to simplify the menus for the A330, why wasn't the same nice menu added from the A320?
Hello together, yes its a problem of Beta 5a, that a330 not work!!!
best regards
Volker
Great workaround! Thanks.
I think the A330 is too sensitive to turbulence. The A320 even more.
Dieter
Just flew her from VTBS to WSSS and everything went to plan! Thanks for the update
19 (edited by Franz007 2016-07-09 20:08:23)
I just observed that with XP10.50 beta 6, the green shapes showing rain on the weather radar are placed on the wrong distance on the Navigation Display. I'm not sure about the size of the shapes but the distance is wrong.
In my example (see below): On the weather map of X-Plane the bad weather is around 40 miles from the aircraft and on the navigation Display it will show it at around 10 miles (!).
I just tried the latest release in 10.50b6 and had no clickpoints for the APU master and the APU start buttons.
I'm curious to see what has been done to the texture updates. Can you please post screenshots. I would like to see what's new. Thanks.
I wish there was a pop up MCDU, like on most planes.
Is someone have the same issue or it is Ok? For me - i have it worked well..
To me in 10.50b6 all goes fine
Sorry, yes, i cant start APU too at one of my test computer (MAC OS)
I'm not hearing runway sound or ground contact on landing using BSS sound pack for A330. Other than that all seem to be working fine in 10.50b6.
