Hi Team,
I am having a unique problem here, every third or fourth time I start my A330 it asks for Activation code and instead of entering the code I go to the top menu> Aircraft > Open Aircraft and select my A330 again, it does not require the Activation code and start up normally.
I recently started my sim at LTBA where the aircraft opened up as usual, I then closed the sim, made some changes to my LTBA and LTFJ scenery and opened up the sim again with A330 at LTFJ. This time A330 requested Activation code. I then re-loaded A330 within the same session and it opened up normally. The attached log.txt is the one currently in the x-plane main folder and my sim is currently running with A330 in cold and dark state. I hope you can explain why this is happening.
HB
Edit: I just realised that I should have posted this under the other heading, sorry about this. I'll be careful next time.
