Topic: v.1.3b1 distributive (Windows 7/8, MAC OS)
Beta
New:
- 10.50 ready
- X-Life ready
- FMGS improved
- Cockpit textures and details improved
Please install it as CLEAR!!! installation, not mix files with other version.
Download link http://jardesign.org/a330/download/inst … _1.3b1.zip
  - be sure, that you use X-Plane 10.36+
  - Download more fresh version of «GndHandling» plugin from official
    board http://jardesign.org/forum/viewforum.php?id=29
a330 use NavData from
Thank you!!!!
2 (edited by Metallist 2016-05-14 13:45:45)
Re: v.1.3b1 distributive (Windows 7/8, MAC OS)
In the cockpit do not work the sounds of the switches, not hear the engines. Work voice of the staff, confirm the position of flap, confirmation checklist, dialogue with the tug, sound GndHandling plugin.
Update: File A330JD_1.3b1.zip\330_JARDesign\plugins\sound3d\win._xpl
update2: don't work the sound keys on the overhead
The sounds didn't work at first, but when I renamed the file from win._xpl to win.xpl it works, the _ should not be there. Also The bulk door does not close when the ground handling drives away, and stays open, until I manually close it. Lastly the wipers do not function by themselves, so one wiper switch will activate both Captain and FO wipers.
4 (edited by Metallist 2016-05-14 19:58:42)
Not working mode T. O. switch "SW NOSE". Light remains as in the mode of TAXI.
NOSE SW
Operation of taxi and take-off lights.
T.O. - Both taxi and take-off lights are illuminated.
TAXI - Only taxi light is illuminated.
OFF - Taxi and take-off lights off.
http://jardesign.org/forum/img/m/2023/t/p1aiodhrnpm0c1enobuv1a1a1fav3.png
Also what I found was that I could not enter a cruising altitude, as every altitude was rejected with the reason of being too high, although I even entered an altitude of only 5000 feet, but it was rejected.
When testing the APU fire protection system, as highlighted in the scope of fire protection systems of engines.
http://jardesign.org/forum/img/m/2023/t/p1aiq1l2kob481r7e1uoh1jjl14l83.png
Not altitude, but FL. 5000 should be 50 as FL.
Not sure what understand what wrong exactly..
При нажатии кнопки проверки противопожарной системы APU начинают подсвечиваться рамки которые обозначены стрелками. Так и должно быть?
NOSE SW
Thanks for this issue!
Вижу. Спасибо! Нет, так не должно быть, проверим можно ли поправить..
Installed the beta.  When I activate, I get a CTD.  Try to reload the plane and get a CTD.  Seems to be an SASL issue.
Anyone any ideas?
Yes, that could work, but I also tried to enter 300 for 30000 ft and it also gave me the error of the altitude being too high, it was for every altitude I was trying to enter.
Thanks but the APU still doesn't burn fuel and there is still no Flaps-2 take off calculated in the MCDU. How long do we have to wait before you fix some minor issues that have been reported a long time ago?
First test flight with  this new version
1. cold start, over head panel light switch don't function
2. during normal descent 2 times AP disconnect alarm (didn't see any unusual occurrence )
3. seems to be more stable landing manually at 1000 feet (at crosswind 6).
16 (edited by captbullett 2016-05-15 22:57:42)
OK so again where is the log.txt and the box.txt so JAR can work on fixing the bugs if there are any,
and did you re-load the aircraft after the first download, install and activation.
So, after you activate the aircraft you should close the X-Plane app and re-start then re-start the A330
and yes I had the same issue as we are testing a new MCDU ... and all log's and box.txt are required for this and X-Life.
Anyone any ideas?
and Airport-Navigator v1.3.1 [INFO]: AptNav::pluginEnable
Airport-Navigator v1.3.1 [INFO]: loading hotkey CENTER
you really do not need the plugin above takes to long to load ..
But the last time i had the issue you have run your X-Plane installer and see if the installer will fix the SASL issue it should.
Anyone any ideas?
I'll give that a go Brian.  Thanks.
Made no difference, still getting a CTD.  I'm on the Steam version.  Is anyone else having CTD issues with Steam?
Tried everything at this stage.  Using the Steam version of XP.  Refreshed the install, removed all plugins and downloaded and reinstalled the A330.  Still getting a CTD and the following reason in the log file:
[SASL ERROR] can't load component    scratchpad
[SASL ERROR] Error loading panel: [string ".../scripts/init.sec"]:0: attempt to index a nil value
21 (edited by captbullett 2016-05-16 22:09:15)
you need to go to the Steam website tech support and see what their remedy is for you issue Wow, this is why I spend the $ for the disks I like to be able to fix it if possible but the Steam site should be able to get things sorted out right.
your friend,
I find it hard to believe that this is a Steam issue.  The previous version worked and still works when I reinstall it.  All other a/c also work fine.  I think Eugeny needs to take a look.  It would be interesting to know if anyone else with the Steam version has had this issue.
Well, you ran the Installer and I had an issue with SASL ran the installer
and I was able to fix the issue the only other thing is re-download the aircraft that the SASL issue is showing up on.
your friend,
So is the new version v.1.3b1 distributive (Windows 7/8, MAC OS) OK to download?
I'm confused ...
Anyone any ideas?
Seems like wrong installation (mix files, etc)
