326
bujablaster wrote:
The real reason what LKLT have not Proc file in NavData
I see, thank you very much. Can you help me a bit with that, please? What i can do make it better? I downloaded latest nav data now and i confirm there is no entry for Letnany sad. But i have absolutely no idea what i could do about that. Who or where i can ask? Or are those real world nav data so it means they don't exist at all?
Thank you for your help.
I think Mr. Jar can build a floder for customer navdata. This may help improve this situation.
327 (edited by cmckjodi 2016-05-05 11:52:14)
Flight form KSEA Seattle to KSFO San Fran perfect! All deluxe functions work as they should for me. I downloaded both airports from the WED scenery gateway as I do with all airports, customized them both for my liking and created the ATC taxi routes and .dat files. It took me awhile to learn exactly what to do to make everything work, but I will say this is a great traffic plugin. The amount of traffic is good and it was busy leaving KSEA! Had to wait in line for a bit. Nice realism. There are very few go arounds with landing traffic the AI code is nicely written. Planes stay nicely separated, and the taxi speeds are realistic. I have done many flights using different airports. All good here. It's amazing to think of the future potential for X-Life as it furthers development. Well done JAR! Looking forward to the future.
328
First thank you for this Great Plug-In! It gives so much life!
Did a Flight from LFMN (Nice) to LSZH (Zurich), did get BERSI1G Arrival for ILS Runway 32...
Well, Runway 32 in LSZH does not have any ILS sad
How can i correct this?
  Runway 10 (096°)   VISUAL
  Runway 28 (276°)   ILS/DME
  Runway 14 (137°)   ILS (CAT IIIb)
  Runway 32 (317°)   VISUAL
  Runway 16 (155°)   ILS (CAT IIIb)
  Runway 34 (335°)   ILS/DME
329
stenu wrote:
One question: Why X-Life does not utilize the 1204 parameter of apt.dat of ATC taxi routes indicating hold short points, but instead requires hold short point to be one line segment away from the runway? It makes possible to put hold short points further away from runway, which is often necessary. It can also limit the hold short for arrivals or departures only if required.
For example:
1202 41 40 twoway taxiway A
1204 departure 03,21
1204 arrival 03,21
Means that the line segment between points 41&40 denotes a "restricted" area which you can't enter before the tower gives you permission for it (runway 03/21 is free).
-J
This example may help http://jardesign.org/forum/viewtopic.ph … 094#p11094
330
Sorry, I am so busy with "BlueBell XL" AI pack. Done 80% of job, need complete positions fine-tuning, 3d logo lights and some parameters. Need several day to complete.
331
If you get ILS approach, but it not exist for this runway, sure you may use any other kind of approach for this runway you want.
332
Can some one help me with this? Please.
I keep getting crashes for some unknown reason and I am unsure what is causing it.
I have attached my log.txt and xlife.dmp
Thanks in advance. big_smile
333
I would start with removing Airport Navigator. It might interfere with X-Life's own Follow Me Car
334
Very strange.
XL always worked very good on my system.
Now for some reason there is no aircraft at EGLL.
Only when EGLL is destination.
All my other (XL approved) airports are working perfectly.
335
Hi Jar,
flying from EDDN to LOWW -> CTD while approaching -> see log
336 (edited by Mikee24 2016-05-07 09:28:19)
first of all I want to thank JARDesign for this great piece of software ! I really enjoy the simple way AI traffic can be injected
into x-plane and how easy it is to correct errors. It's really nice to see how everything is working the way it's supposed to be when 'finishing' a new airport.
The only thing that strikes me are same problems as mentioned above.
I have these problems with two german airfields:
EDCW is recognized as EDOP, EDAZ as ETSH and can not be edited with the Gates Editor.
Looking up EDAZ and EDCW in \default data\earth-nav.dat showed that these Airfields don't have any entries.
In contradiction to this KORS (Orcas Island, WA) does also not have an entry but was recognized By X-Life and could be edited with the Gates Editor.
So hopefully there will be a fix for this issue or at least an explanation.
So Thanks again for Your work and best regards,
Mike.
337 (edited by jcdp 2016-05-08 16:29:09)
A fly from LFPO to LFBO ... everything went well but  ...
with ATIS giving 14L or 14R rwy in use for landing at LFBO , X-life gave me RWY 32 R ...
X-life approach confirmed clearance for landing on RWY 32 R with wind coming from 140° ...
Strange isn't it ?
see pictures
Mike.
Great report so, to finish up please attach your log txt so we can get the data from your set-up this will help find any bugs or code errors and help fix your issues. also if you are using a jAR aircraft a box.txt which can be found in the JAR aircraft folder is a must this is why this plugin is so good because everyone is working well in sending the data into JAR in return JAR can fix the issues and  he is getting all the data therefore, the data is good data.
Thank-you for all your help,
Strange isn't it ?
see pictures
Good report but please send Log txt so we can keep up with the bug issue LFPO and LFBO can be an issue area depending on what SID and STAR you are using. also, if you are using a JAR aircraft please attach a box.txt and it is found in the JAR aircraft folder.
Thank-you for your help,
Good day:
XL: 4838 :
XL: 4838 : ATC LOG -----------------------------------
XL: 4838 : > Pilot: VIENNA ATIS ,JAR123, Stand B71, A330, with information Whiskey, QNH1013, request clearance
XL: 4838 : >
XL: 4838 : > ATC: JAR123, Contact VIENNA Delivery, 121.900
XL: 4838 : > Pilot: Roger, JAR123
XL: 4838 : >
XL: 4838 : > Pilot: VIENNA Delivery ,JAR123, Stand B71, A330, with information Whiskey, QNH1013, request clearance
XL: 4838 : > ATC: Initial Altitude 7000 feet, Squawk 1625
XL: 4838 : > ATC: JAR123, VIENNA Delivery, Cleared to MUNICH, Runway 29, via LUGI1C departure,
XL: 4838 : > Pilot: Cleared to MUNICH, Runway 29, via LUGI1C, Initial Alt 7000, Squawk 1625, JAR123
XL: 4838 : > Pilot: VIENNA Delivery ,JAR123, Stand B71, request push and start
XL: 4838 : > ATC: JAR123, Contact VIENNA Ground, 118.350
XL: 4838 : > Pilot: VIENNA Ground ,JAR123, Stand B71, request push and start
XL: 4838 : > ATC: JAR123, push and start approved
XL: 4838 : > Pilot: Push and start approved, JAR123
XL: 4838 : > Pilot: VIENNA Ground ,JAR123, Stand B71, request taxi
XL: 4838 : > ATC: JAR123, VIENNA Ground, taxi to holding short runway 29, via TL31,L,EX11,M,A1
XL: 4838 : > Pilot: Taxi to holding short runway 29, via TL31,L,EX11,M,A1, JAR123
XL: 4838 : > Pilot: VIENNA Ground ,JAR123, Stand B71, request FollowMe car
XL: 4838 : > ATC: JAR123, VIENNA Ground, expect FollomMe car 1 minute
XL: 4838 : > Pilot: VIENNA Ground ,JAR123, approaching holding short runway 29
XL: 4838 : > ATC: JAR123, Contact VIENNA Tower, 123.450
XL: 4838 : > Pilot: VIENNA Tower ,JAR123, approaching holding short runway 29
XL: 4838 : > ATC: JAR123, VIENNA Tower, line up runway 29, and wait
XL: 4838 : > Pilot: Lining up and wait runway 29, JAR123
XL: 4838 : > ATC: JAR123, runway 29 cleared for take-off, wind 355 degrees 0 knots
XL: 4838 : > Pilot: Cleared for take-off, Runway 29, JAR123
XL: 4838 : > ATC: JAR123, contact VIENNA Approach 123.625
XL: 4838 : > Pilot: Contact VIENNA Approach on 123.625, JAR123
XL: 4838 : > Pilot: VIENNA Approach ,JAR123, LUGI1C departure, passing 1900 feet, climbing to 7000 feet
XL: 4838 : > ATC: JAR123, VIENNA Approach, radar contact, climb to FL 70
XL: 4838 : > Pilot: Climbing to FL70, JAR123
XL: 4838 : > ATC: JAR123, Climb to FL 200
XL: 4838 : > Pilot: Climbing to FL200, JAR123
XL: 4838 : > Pilot: Ready for Descend, JAR123
XL: 4838 : > ATC: JAR123, Contact  Center,
XL: 4838 : > ATC: JAR123, Descend at Pilot's Discretion to FL 100, expect NAPS1A arrival, Runway 26R in use
XL: 4838 : > Pilot: Pilot's Discretion Descending to FL100, expect NAPS1A arrival, Runway 26R, JAR123
XL: 4838 : > ATC: JAR123, contact MUNICH Approach 123.625
XL: 4838 : > Pilot: Contact MUNICH Approach 123.625, JAR123
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL199, descending to FL100, information Whiskey on board
XL: 4838 : > ATC: JAR123, MUNICH Approach, Wrong ATIS Information
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL190, descending to FL100, information Whiskey on board
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL177, descending to FL100, information Whiskey on board
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL151, descending to FL100, information Whiskey on board
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL137, descending to FL100, information Whiskey on board
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL119, descending to FL100, information Whiskey on board
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL105, descending to FL100, information Whiskey on board
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL100, descending to FL50, information Whiskey on board
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL78, descending to FL50, information Whiskey on board
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL72, descending to FL50, information Whiskey on board
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL52, descending to FL50, information Whiskey on board
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL47, descending to FL27, information Whiskey on board
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL39, descending to FL27, information Whiskey on board
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL34, descending to FL27, information Whiskey on board
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL33, descending to FL27, information Whiskey on board
XL: 4838 : > Pilot: MUNICH Approach ,JAR123, FL27, descending to FL27, information Whiskey on board
XL: 4838 : ATC LOG END ----------------------------
XL: 4838 :
Anyone know because I can not connect to approach ?
I have tried several airports and always the same.
Any solution or idea?
regards
341 (edited by jcdp 2016-05-07 20:04:44)
Strange isn't it ?
see pictures
Effectively I  missed log.txt
PS
When I entered flight plan I planed to use RWY 14 L as mentionned from ATIS for landing... after TOD I modified it by RWY 32R
as required by X-life ATC.
fidelius wrote:
Good day:
XL: 4838 :
XL: 4838 : >
XL: 4838 : >
XL: 4838 :
regards
In the ATC window,  click the ATIS button and use the information to change your Barometer setting. Then call Approach.
Hope this helps.
343
fidelius wrote:
Good day:
XL: 4838 :
XL: 4838 : >
XL: 4838 : >
XL: 4838 :
regards
In real life a traffic controller would say for example "Altimeter 29.95" here in the US not "wrong ATIS information"
344
Good day:
Thank you very much for your responses.
Hope this helps.
I try and I will comment if it works ... ( I hope so )
So I thought it would work.
For example:
1204 arrival 03,21
-J
I don't understand what is the gain of your purpose?!....
346
Under X-Life/Gate Editor you can de/select runways..
347
Strange isn't it ?
see pictures
PS
Don't understand, about what ATIS are you talking?
348
fidelius wrote:
Good day:
Hope this helps.
Yes, I am hearing and seeing the same, I think it would be good if it would have the QnH so, you did not have to guess what the QnH is.
349 (edited by captbullett 2016-05-08 15:33:12)
cmckjodi wrote:
fidelius wrote:
Good day:
XL: 4838 :
XL: 4838 : >
XL: 4838 : >
XL: 4838 :
regards
Please, Please send the whole log.txt  we need all the data to help it's not just about one issue but about the big picture and correcting all the X-Life bugs. you might just see you issue but if you have the issue it will show up some where else. The whole log.txt and box.txt will help to track, and the portion of the log you posted does not show any issues so we needed the rest of the log.
The QnH is also an issue for me as I am working through the US airports right now you might have to go to the weather and make sure it(QnH) is set right (to in) also to the US  in. setting, then set the aircraft to in. then start the X-Life plugin.
350 (edited by jcdp 2016-05-09 15:04:58)
PS
To Ilankrt
In X-life ATC window you have Atis which gives you info on departure and arrival airports ...so
on arrival Airport it was written landing RWY in use 14L or 14 R and Wind 134° ...
see attached picture .
(see post 337)
