Romanov, are you planning to increase the taxi speed slightly? It feels like the aircraft is so slow, but I am not sure if others thinks that too...
Also, approaching aircraft seems to be too close to each other, as almost always the second aircraft aborts landing.
And at last, is it planned for aircraft to line up runway and wait after an other aircraft have landed, or departing?
Hi Eugeny,
just complete a test flight from LIRF to LFMN, all works like a charm execptfor the departure SID, the delivery not assign any SID.
Do you remember our flight with skype desktop sharing? In that flight i have had the same problem, deliver give the clereance but without SID.
For the rest all works fine
thanks for all
78 (edited by escapem 2016-04-08 17:08:34)
Hi Eugeny.
First of all, i want to thank you for your job!
I've bought X-Life a few days ago, and i think it's awesome!
However, i have some questions about the current features, and, maybe about further developing:
1. If my departure or arrival airport is not compatible with X-life, so, no traffic in this airports. And what about traffic from compatible enroute airports?
2. Is there any way to create ground routes for standard airports, which don't have a custom scenery?
3. What should i do, if my custom scenery contains many airports with ATC taxiways, what file i need to place in airports folder, and how do i name it?
Thank you!
will give you 50% discount from list price, if you buy product at this development stage and from official product page.
I think the official page is :
http://jardesign.org/x-life/www/
But where i can buy this product?
Does X-Life use Airport Flows as defined in WED. or does it just ignore any entries about that?
81 (edited by marvel_master 2016-04-08 14:13:55)
Update : I have found the answer for my question.
I  have to activate side panel:
Plugins/x-life/Deluxe/Deluxe Menu on/off
another question.
In the past, x-life show some interest information . I mean departure times etc. from other aircrafts and what they do.
You can see it in this video:
https://www.youtube.com/watch?v=vYgP0Wv1C_U
At minute 27:00.
They you can see :
Aircraft 1 : GATe : Taxi to ..
Aircraft 2 : Gate  : Fly ....
etc.
How i can show this information?
And it was possible to see a map of all other KI Software. I cannot activate this map anymore. How is that possible?
You can buy X-Life here: http://jardesign.org/x-life/www/shop/
Click on the link, showed on screenshot to enter discount code.
http://savepic.net/7968285m.png
83 (edited by Blackcat 2016-04-08 16:26:20)
hello,
Blue plane was not cleared for take off if the yellow plane (landing) is on the  red taxiway . Why?
(There is no aircraft on approach)
What is the solution to this problem.
http://img15.hostingpics.net/pics/392444lfmd.jpg
84 (edited by ilankrt 2016-04-08 16:35:41)
hello,
Have you told TOWER about your holding short near runway?
hello,
You should check airport information and will see is any (and what) aircraft busy that runway or not.
So, working week is done, back to X-Life wink
What I've seen: ATC is not yelling at me, when I'm overspeeded under 10'000 feet, and have more then 250kts GS. I don't know why, but in my Epic E1000 I had around 300kts at 8'000 feet. And ATC let me go wink Not good wink
Cheers
87 (edited by laohu314 2016-04-08 19:58:58)
Test flight EGCCEGLL
XL is absolutely awesome!
Went perfectly. The only thing that bugs me on approach is the one needs to open ATIS (because the plane METAR data differ), switch to manual Baro, set the  Baro and  then turn back on STD Baro before contacting Approach.
At least the A320 METAR data and XL ATIS should agree so that one can use these data.
Saitek X52,  Radio, Switch and Multi Panel, TM Cougar, XP 10.45, JAR A320neo 2.6.1, XL 1.1b1
flying from lowi to lzib -> while approach CTD -> see log
iMac, latest x-life
89 (edited by laohu314 2016-04-09 05:44:18)
@SirOTheOne
In your log I see SMP3 and XFMC are loaded. SMP3 generated some errors and I believe that XFMC may cause trouble too. I'd try to remove them
Here's the problem with the image. 2 planes are "AI"
http://img15.hostingpics.net/pics/934952AB1153.png
91 (edited by SirOTheOne 2016-04-09 10:51:38)
@Eugeny
if you fly from one destination to another - land (pax out) - start and fly to another dest, x-life settings (ATC and atis) will not be resetted (old values) - see pic (i´m standing on RW 31 for dep to LOWS !!!!
Another bug: aircraft has landed, while i was standing on rwy for departure - next pic
Ok, thanks for report. Next improvement will be crossing Runway by user aircraft and and get Hold if runway busy. But I am not sure about phraseology - please look at screenshot:
http://jardesign.org/forum/img/m/22/t/p1aftbdlf31mbs1i8g1a471rpc2jo3.jpg
another CTD - flying from LZIB to LOWS while approaching in LOWS via RNAV (x-life said ILS -> bug)
see logs - many many messages: "!!! Unknown Check Ai Brake case" whatever it means
ok, please publish true approved speed values for taxi for different aircraft types. Please post it here with link to docs - i will check and compare with my speeds datas. If you have this, sure.
95
Suggestion
1  "hold short, runway xx-xx busy"
2  clear to cross runway xx-xx, continue taxi"
96 (edited by ThommiTechnik 2016-04-09 13:04:56)
e.g. (in EDDF): "Lufthansa 123, taxi to holding point runway 18 via Mike 1 and November, hold short of Quebec, traffic will be a Cargo Lux Boeing 747 moving right to left."
or
"Lufthansa 123, taxi to holding point runway 18 via Mike 1 and November, hold short of Quebec, because of departing Cargo Lux 747" (so that you know, what blasts you have to expect)
or
"Lufthansa 123, taxi to holding point runway 18 via Mike 1 and November, hold short of Quebec, because of arriving Cargo Lux 747"
Since it's not clearly defined by the FAA, I assume that most airlines limit taxi speeds via their SOPs, also due to the variety of equipment, it might be unfeasible for the FAA to mandate a specific speed.
Roughly:
Max 30 kts: straight line with no close obstacles (for example: back-tracking on the runway)
Max 20 kts: straight line with obstacles (for example: on the taxiway, or close to other aircraft/stands/ground vehicles)
Max 10 kts: turns and entry onto ramp area
FollowMe car average speed is 22kts . It is at safety range for every aircraft and  do not need any change!
Also landing speed and roll out on runway seems to be OK
The distance of landing AI aircraft should indeed be longer
Line up on RWY after an aircraft was landing can save fuel and time in the real world. The X-Life procedure to line up and get clearance to take-off without delay after runway was cleared is a satisfyingly solution....
or
or
Far too long sentences! until it is pronounced the next plane is already landed and the RWY new occupied....
FAA example:
March 02, 2016
N JO 7110.704
EXAMPLE−
“hold short of Runway One−Six traffic......”
“Cross Runway One-Six continue Taxiway ......”
99 (edited by ThommiTechnik 2016-04-09 15:00:54)
@ilankrt: did you ever sit on a large, busy airport, while taxiing, on an airport like EDDF, EHAM, LSZH, LFPG? We in the cockpit want to know everything, every detail, on such airports. Too much traffic, too less windows wink And yes, you're right if you have a look on FAA. But there's a big, a very big difference between Europe and the rest of the world in phraseology. And for us it's much more easier to go to Asia or to the Arabs, than to the US.
Hi Jar
CTD just now.
Here are my files.
