276
Hello! This time X-Life plugin was reworked again. We use X-Plane fresh API now and make this plugin VR-compatible. About 2300 strings of c++ code added.
Download link to Actual build
http://www.jardesign.org/x-life/downloa … 090219.zip
What New:
v.4_050718 (first test build of v.4)
+ new ATC panel design
(movable, auto-hideable, resizable with mousewheel)
+ add VR-support for ATC-panel
+ add "Set Baro readback"
+ add "Set Squawk readback"
+ many CTDs fixed
+ framerate optimisation
+ pdf manual included
v.4_070718 (updated build of v.4)
+ flightplan import/export buttons for JD320/330 fixed
v.4_090718 (updated build of v.4)
+ landing performance for AI aircraft(s) updated
v.4_210718 (updated build of v.4)
+ long Callsign is possible now
+ "cant close" ATC Panel issue fixed
+ takeoff without clearance issue fixed
+ any Departure Airport may be entered at FPLN page
v.4_090219 (updated build of v.4)
+ METAR issue fixed
Installation:
Please unzip pack and follow .PDF manual.
If you prefer use HD “Bluebell XL” traffic AI library, please download 3 files from
http://jardesign.org/downloads/BBXL/BBXL-1.zip
http://jardesign.org/downloads/BBXL/BBXL-2.zip
http://jardesign.org/downloads/BBXL/BBXL-3.zip
Next unZIP and put “Bluebell XL” folder to ../X-PLANE 10/Custom Data/ folder
and install folders “PackA”, “PackB”, “PackG”, “PackJ”, “PackP” to
../X-PLANE 10/Custom Data/Bluebell XL/ folder
X-Life use NavData (old) cycle by Aerosoft from own /navdata/ subfolder
or from ../X-PLANE/Custom Data/GNS430/navdata/ folder if exist
and put new cycle to ../X-PLANE/Custom Data/GNS430/navdata/ folder
Airport Editor manual by Philip Walchester posted here
http://jardesign.org/forum/viewtopic.php?id=3261
FMCar update
Please use this files to update FMCar and make it compatible with new .xlf files format
http://jardesign.org/forum/viewtopic.ph … 877#p17877
All remain the same
- please post you opinion about this version, post what you like/unlike
- post your log.txt + x-life.dmp if Crash happen and you are on Windows.
Where is version 3? Why v.4 just after v.2? Hmm.. v.3 was build but without VR-support. So - v.4 with VR-support  is come.
http://jardesign.org/forum/img/m/22/t/p1chnfe1eg1sicshjbs58qlim3.png
277
rafgath wrote:
MrTee wrote:
rafgath wrote:
JAR - Any chance to fix METAR ?
http://jardesign.org/forum/viewtopic.php?id=11426 <- quickfix for metar. Did you try that one?
Have you seen my last posts ? Is this fix working for you ?
No, sorry.  Xlife 4 completly kills the FPS in Rift VR so it is impossible to use Xlife in VR right now.
278 (edited by cmckjodi 2019-03-03 12:47:35)
My frame rates still drop into the 20's and below with this new build and there is lots of stuttering of frames making the sim unusable. When I disable X-Life my FPS immediately returns to 50 and above. I'm running XPlane 11.30 on a PC 4.0 ghz  32 RAM NVidia 970 Newest X-Life version 090219  Not using VR
279
I still have an issue with the "disappearing" ATC panel. I am starting to think that this is not a random event.
If I am flying to EHAM, when I report Top of Descent, the ATC panel slides off my screen and is not recoverable. This happens EVERY time.
Does anyone else have the problem at a particular arrival airport?
Intel i7-7700 @3.6GHz, GTX 1060 6Gb, 16Gb RAM. Saitek Pro yoke and 2nd quadrant, Saitek Multi panel, TM rudder.
X Plane 11.31, Jar A330, BSS sound pack, X LIfe, FM Car, ATC Chatter, XEnviro, Better pushback
280 (edited by theduusK 2019-03-06 16:26:01)
Same issue on my side.
Without active X Life I have between 40-60 FPS. As soon as I activate X Life the frames go down to 15-20 fps.
- X-Plane 11.32r2 (Beta build)
- X-Life Ver.v.4_090219
- i7-7700 @ 4.6 GHz (OC)
- 32 GB DDR4 RAM
- GTX 1080 (no VR)
And somehow I also expcect sound issues.
I can't hear most of the ATC communication although all volume settings are set to highest option.
281 (edited by yamahar1 2019-03-06 16:57:26)
Hi J.A.Romanov a suggestion on the next update can be add the communication emergency landing, and varie other request that can be done during the flight. Will be nice.
Thanls
282
About framerate..
If you use Nvidia, you need try to set Off Multithreaded optimisation at Nvidia control panel.
About sound..
Need check is your X-Plane ATC sound work at all, cause X-Life just use default X-Plane text-to-speech function. Sure, ATC volume should be set non-zero
283
About framerate..
About sound..
Turning off Threaded-Optimisation fixed the FPS drops for me. Just had a test flight and FPS were between 40-60 FPS.
My sound issue also seems to be gone after a quick re-install of the plugin.
Thanks a lot!
284 (edited by theduusK 2019-03-10 10:07:09)
Just encountered another issue while flying from LFMN -> EDDH
http://jardesign.org/forum/img/m/8169/t/p1d5jh3mic1e9f119f1pgv1bk6ipd3.png
As you can see, ATC told me to decent to FL120 when I was ready for decend.
When I contacted Approach, X-Life tells ATC I'm decending to FL40 (whats wrong).
285
Nothing wrong. The Center cleared you to FL120 and then Approach cleared you through to FL40 (which the Center cannot do).
286
Thats basically true, but if you look into the sequence, you may see, that my first contact to approach already contains FL40,
which I can't know at that point because my last order was FL120 from Center.
So I cannot now about FL40 before contacting Approach.
I mean its no critical issue, I was just wondering about.
287
Are there no Way to reset the atc so that a new flightplan Can be made/filed after landing at airport?
Or do i have to restart the game every time?
288
Ok, I NEED HELP!
1. the ATC ask for me to uso LIXEP1 SID to leave SBGL using the rw15, but the lixep1 its not for this rw.
2. on other flight, http://prntscr.com/mz90bb, what should i do? even putting manually on radio, nothing happens! so i cannot approach anywhere.
3. if i click on the TOWER icon, the game suddenly crashes.
289 (edited by theduusK 2019-03-18 19:57:31)
I think you should be able to put in a new flight plan or to disable and re-enable the plugin / traffic in the plugins UI with the power-icon. I already had two flights in a row like that.
A few days ago I encountered a crash at that point, I asked for another Runway for takeoff - after I got the clearance.
I got clearance for EDDF RWY25R, and I asked for 25C . As soon as I clicked the button, the game crashed.
Unfortunately there was no info in the logs about the crash and also no x-life dump file :-/
290
if i put in another flight plan by simply using the turn off power button i am able to make a new flight plan, but the atc still refers to the starting airport from the trip before, i have not however tried turning it off and then disabled and reenabled via plugins ui, will try that the next time smile..
thx for the anwer
291 (edited by joo2se 2019-03-20 09:17:20)
http://jardesign.org/forum/img/m/8287/t/p1d6d670a8ckk1ep81cvh12potd73.jpg
Only the red square part of the voice comes out.
Does the rest of the section have no ATC voice?
What is the problem?
292
Hallo, i have the same Problem with the ATC. After the call sign the Madam don't talk with me!
293
There is a problem with sound when you used B737-300 from X-Aviation. You need to reinstall X-life to work properly.
294 (edited by klausn21 2019-03-23 06:03:30)
don't know why, but if I try to start X-Life, XP crashes. I also did a fresh install new partition and added one by one plugin....but could not find any other than X-Life causing problem.
Attach x-life.dmp and log.txt not allowed
Downloaded and replaced x-life with the latest update >> same issue.
Installed everything on my new box one by one and the same behaviour at that time x-life is there, Backup of the old XP (updated from 11.25 until 11.32 in all steps) on C Drive, fresh install on D Drive, both with thesame issue. Without loading x-Life everything works great.
i9 9900 GHz, 64GB RAM, NVIDIA Geforce RTX 2080, 2x 981GB SSD, Windows 10-1809
295
I don't use 737-300 from X-Aviation. The Error occurs on all my Planes!
296
I have exactly the same issue and can therefore confirm this is not a "random" event.
I tried 3 consecutive approaches to EHAM and every time the ATC panel slides down off the screen after reporting TOD.
After that X-Life traffic is still around but there is no ATC vectoring/comms anymore and the panel is not recoverable.
I have no solution either I'm afraid. Just able to reproduce your issue.
I am going to try some other approaches to different airports to verify.
X-Life is great by the way. Thanks for all the great work JARDesign. Yes I got the paid version.
297
@J.A.Romanov, in the latest X-life version I get no METAR information. Could you fix that problem?
298
First you input flight plan than you can see ATIS
299
Negative Darko24.
Flight plan was sent, but no ATIS is showing. Using ASXP. But with default XP real weather it also shows no ATIS. This only happend after installing the latest Xlife version from 12.03.19.
300
Negative Darko24.
Sorry, I have the same version working fine. Try to fresh install X-life.
