226
Hello JA,
that' OK, i had can purchase XL yesterday. Very cool ! Very good !
I have several suggestions for ATC box:
- I think you could add an option for activate voice or not when pilot talk. (and not just when ATC talk)
- I think it's not very good to have sentences's suggestions when we are not on the good radio's channel
- So, I think the suggestions may appears when the "pilot" click on the good button (ground, tower, departure...) OR when he change the channel on his radio and he's on the good channel.
- I think ATC tell the channel to contact when we must conctact another service. Example: "Ground, authorize for Taxi B757XXX, contact tower on 134.25 when you are on hold point." Why ? Cause on the big airports, there are many channel for the same service and ATC must say to pilot witch channel he must contact.
Thank you, bye.
May be yes, i dont know. Sure, in real you can say wrong request to wrong channel too. I will think.
For this point, that's sure, but for others...
We don't know witch frequency we must call and the buttons don't change frequencies on radio. So, we don't know on witch frequency we are. Perhaps you could too color the active frequency (button).
And in reality, you can have several frequencies for each service. So, ATC must tell us witch Freq we must contact. And you set frequencies on radio.
Thank you for interest to my question.
Bye.
Real FREQ is, yes, our future task.
227
MH1212 wrote:
MH1212 wrote:
OK, I have tried everything to get it working reliable. I must admit that I am frustrated by now by the lack of information in the logs.
Some airports work, other half and others do nothing.
NB1: every airport I tried has basically the same layout -> if one works why not the others as well??
NB2: for he FM car is the same: sometimes it works, most of the time not...
I uploaded 2 examples:
EGJB: traffic loads, but no departures (sometimes arrivals) . Sometimes 1 line (DEP) just disappears and becomes blank. FM car does not work
EBBX: X-Life gives error: LFSJ airport (??) not compatible. FM car reports: EBBX not compatible??
For now I give up. I will try again with future releases... I really hope you can improve it, the concept is still great!
Good luck!
May be you are missed something.. This is a verified airports map - https://www.google.com/maps/d/edit?mid= … ecn3NB3GZ8
Other airports have a small chance to work well - they are may have not checked ATC-taxiroutes.
Perhaps you could give a look: I have included both apt.dat files -> I would be very glad if you could tell me what I missed! WED reports no errors and groundroutes tools for WorldTraffic work also fine for these airports. So what should I change to make them work with X-Life and Fm car??
This is easy to check. I try to describe all needed step-by-step at learning video and text notes. You can find it at product page. I am sure, not much airports/sceneries exist with really good-maked apt.dat, cause until now, there is no tool was to check and test its ATC-taxiroutes.
http://jardesign.org/forum/img/m/22/t/p1acf2h8ls7hb1d7i1ddfg8d15rc3.jpg
228
Trust me, I have viewed and read all of that stuff. I do have airports that work -> so why do some not work even if they are made the same way?? I have a .NET application that I wrote to make airports (see http://forums.x-plane.org/index.php?app … file=27582 -> so every airport I produce is technically the same. I don't consider myself an expert, but I do know a lot about apt.dat, airport layouts,  dsf files etc.
Plus I have also made ATC routes in WED + checked with WT tools. And still X-Life gives problems.
I am happy to assume that I do something wrong, but I need more information what goes wrong.
Dewald wrote:
Hi guys. I also don't get options when at TOD.
Approach and landed without ATC.
Maybe we are not setting up the flight plan properly.
Maybe you can just post a quick a to z on how to do the flight from gate to gate.
Sure, need use flightplan menu and prepare/send flightplan to ATC. This is only way how ATC will know about your arrival airport.
Another, what you need - check what you are reach cruize FL, what you are entered to flightplan
If both are Ok - Report TOD should be available.
In my case i'veimport FP from a320 fmc and, as show in bblog, i was at correct crz level when reach the TOD, i've tried to passet it to see what happend but nothing..
230 (edited by PM1970 2016-02-26 17:21:59)
Hi Romanov
Just create ATC routes for LPMA, but this time after start the x-life plugin I get a message saying that LPMA is not x-life compatible, besides this I have from my 6 gates 3 that are busy, for the moment any movement of aircraft. Do you have any idea why does this occur ?
Updated: Just reloaded the simulator, and now it seems ok, no message at all.
Anyway, got a crash with the last version yesterday after few minutes running the plugin and seeing the aircrafts running in and out.
231
I just tried X-Life beta 8 for the first time and below (from log.txt) is what I get after starting x-life. I'm on a Mac running 10.11.3 X-Plane 10.45r2.
X-Life plugin by JARDesign Ver.beta 8 250216
OpenSceneryXpath NOT find
JARDesign plugin: /Users/xxxx/Desktop/X-Plane 10.45 Winter/Resources/plugins/X-Life/Metar/CYQM.TXT file updated.
232 (edited by thomas_99 2016-02-26 17:24:22)
Hmm.. seems like all have CTD with beta 8, but i have not. May be I am just unluckie.
I can help you getting lucky :-)
1) Start X-plane
2) start X-Life Traffic
3) goto bed.
4) In the morning you will have CTD, I'm sure.
It never has worked longer than 2 hours for me. And you don't need to do anything, just let it run.
Best regards,
233
Not good to see such (-) comments so when we can have the bbox.txt and the log.txt sent the right way and with data that can help the Beta program de-bug any issues which, is what this post is for then we can move from negative comments to actually solving the issues that people are having.
please this is a process and if you need help you have to do your part,
Thank-you for your help,
234 (edited by Sloboda 2016-02-26 18:46:32)
issue when change airport:
launch XP, choose airport with a plane (example for me: LFOP/B757). Traffic on. Airport (LFOP) is not available... So change airport to go on an airport wich XL know. (example LFMN )
X-Life ATIS informations stay on the old airport LFOP. You can make Traffic off and on. You can disable and enable XL... You can generate flight plan again and send it, XL ATIS give you the old airport informations.
So you must restart X-Plane.
235
I'm not sure if you are talking with me, but:
1) there is no bbox(_log).txt in x-life.
2) If you just start x-plane and start x-life traffic, it will crash after a while. Every time.
3) If you do not do anything, just watching the scene (free camera) you will not find any entries
    in the log.txt. Not a single line. So there is NO logfile.
4) At the moment I can't do a complete flight with x-life, because it crashes too fast.
So the best thing I can suggest is:
- start xplane
- start x-life traffic
- next morning you will find a CTD.
I have just updated to x-plane 10.45 release version (out now). Same behaviour. CTD.
Last flight: again CTD (with x-plane 10.45 release).
0:09:51.146 E/SCN: Failed to find resource 'Citation_X_C-GCUL.png', referenced from file 'D:\Spiele/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/lit/'.
JARDesign plugin: D:\Spiele\X-Plane 10\Resources\plugins\X-Life\Metar/EDNY.TXT file updated.
JARDesign plugin: D:\Spiele\X-Plane 10\Resources\plugins\X-Life\Metar/EDDL.TXT file updated.
---+++--- Pilot: FRIEDRICHSHAFEN Delivery ,USER123, Stand GA 203, A320, with information Alpha, QNH1022, request clearance
inRW=06
inSidPoint=ALAGO
---+++--- ATC: USER123, FRIEDRICHSHAFEN Delivery, Wrong ATIS Information
X-Life check atis info:Departure: EDNY information Tango. Runway in use: RW06 Transition Level 5000 ft. Weather: // Arrival: EDDL information Tango. Runway in use: RW05R RW05L Transition Level 5000 ft. Weather:
---+++--- Pilot: FRIEDRICHSHAFEN ATIS ,USER123, Stand GA 203, A320, with information Tango, QNH1022, request clearance
inRW=06
inSidPoint=ALAGO
---+++--- ATC: USER123, FRIEDRICHSHAFEN Delivery, Wrong QNH, set 1006
---+++--- ATC: USER123, Contact FRIEDRICHSHAFEN Delivery
---+++--- Pilot: Roger, USER123
---+++--- Pilot: FRIEDRICHSHAFEN ATIS ,USER123, Stand GA 203, A320, with information Tango, QNH1008, request clearance
inRW=06
inSidPoint=ALAGO
---+++--- ATC: Initial Altitude 7000 feet, Squawk 1244
---+++--- ATC: USER123, FRIEDRICHSHAFEN Delivery, Cleared to DUSSELDORF, Runway 06, via ALAG5E departure,
---+++--- Pilot: FRIEDRICHSHAFEN Delivery ,USER123, Stand GA 203, A320, with information Tango, QNH1008, request clearance
inRW=06
inSidPoint=ALAGO
---+++--- Pilot: Cleared to DUSSELDORF, Runway 06, via ALAG5E, Initial Alt 7000, Squawk 1244, USER123
---+++--- Pilot: FRIEDRICHSHAFEN Delivery ,USER123, Stand GA 203, request start up, information Tango
---+++--- ATC: USER123, start up approved
---+++--- ATC: USER123, Contact FRIEDRICHSHAFEN Ground
---+++--- Pilot: FRIEDRICHSHAFEN Ground ,USER123, Stand GA 203, request start up, information Tango
---+++--- Pilot: Start up approved, USER123
---+++--- Pilot: FRIEDRICHSHAFEN Ground ,USER123, Stand GA 203, request taxi
---+++--- ATC: USER123, FRIEDRICHSHAFEN Ground, taxi to holding short runway 06, via N4,N,F
---+++--- Pilot: Taxi to holding short runway 06, via N4,N,F, USER123
---+++--- Pilot: FRIEDRICHSHAFEN Ground ,USER123, Stand GA 203, request FollowMe car
---+++--- ATC: USER123, FRIEDRICHSHAFEN Ground, expect FollomMe car 1 minute
D:\Spiele\X-Plane 10\Resources\plugins\X-Life\fmpath.txt
Find FMCar route file at D:\Spiele\X-Plane 10\Resources\plugins\X-Life\fmpath.txt
---+++--- Pilot: FRIEDRICHSHAFEN Ground ,USER123, approaching holding short runway 06
---+++--- ATC: USER123, FRIEDRICHSHAFEN Tower, hold short runway 06
---+++--- ATC: USER123, Contact FRIEDRICHSHAFEN Tower
---+++--- Pilot: FRIEDRICHSHAFEN Tower ,USER123, approaching holding short runway 06
---+++--- Pilot: Holding short runway 06, USER123
---+++--- ATC: USER123, FRIEDRICHSHAFEN Tower, line up  and wait runway 06
---+++--- Pilot: Lining up and wait runway 06, USER123
---+++--- ATC: USER123, runway 06 cleared for take-off, wind 6 degrees 6 knots
---+++--- Pilot: Cleared for take-off, Runway 06, USER123
---+++--- ATC: USER123, contact FRIEDRICHSHAFEN Approach 124.6
---+++--- Pilot: Contact FRIEDRICHSHAFEN Approach on 124.6, USER123
---+++--- Pilot: FRIEDRICHSHAFEN Approach ,USER123, ALAG5E departure, passing 2400 feet, climbing to 7000 feet
---+++--- ATC: USER123, FRIEDRICHSHAFEN Approach, radar contact, climb to FL 70
---+++--- Pilot: Climbing to FL70, USER123
---+++--- ATC: USER123, Climb to FL 320
---+++--- Pilot: Climbing to FL320, USER123
236
- start xplane
inRW=06
inSidPoint=ALAGO
inRW=06
inSidPoint=ALAGO
inRW=06
inSidPoint=ALAGO
inRW=06
inSidPoint=ALAGO
EDNY airport is not checked and no guarantee what it may work well with X-Life
Also, if you have CTD any time when you start X-Life - please contact me skype j.a.romanov - this will be much helpful.
237
1) Start X-plane
3) goto bed.
Best regards,
Last night - EPWA. Morning - still Ok. So, unluck too.
238
This is a reason
239
PM1970 wrote:
Hi Romanov
I am not have an idea as nobody (but you) know how you build ATC-taxiroutes. May be some more info may help.
So, this info may be useful for you http://jardesign.org/x-life/www/how-to- … ompatible/
240
Ok, lets try to make flight together via skype. My skype is j.a.romanov
241
I don't use Skype. Sorry but our lines are quite inconsistent with Skype.
My flight plan is:
EDDL SID MODRU Z717 GOBNO UZ717 MAS UM617 SOGRI UL608 DENUT UL610 RAPIX L610 LAM STAR EGLL
CRZ @ FL200 --- I made sure I was cruising at correct altitude
Both airports correct (Aerosoft).
I was flying the FJS Q400
242 (edited by ivota 2016-02-27 07:24:18)
Some users had problem.
Tip:
Make additional code to check presence Openscenery library (\Custom Scenery\OpenSceneryX)
(Check folder if exist)
If not, go to download ( link)
243 (edited by SirOTheOne 2016-02-27 08:36:06)
Flying from LIPZ to LOWS -> CTD, see log
244
Not working well should not mean: crash.
No, not when I start x-life. It usually takes 20 minutes to 2 hours to crash.
So if it's not crashing on your PC, but on mine this usually means that I have a library or plugin installed
which causes the crash.
As I'm not alone, others have installed additional libraries, too.
I'll make some tests removing libraries, we will see which one causes the crash.
HI,
test again and same problem again.
Flight LIRF to LFMN
FP prepared by simbrief
Open x-life, LIRF already set as departure, set LFMN as arrival and alternate
Inser manualy route point and sento to atc
Make manualy the FP for a320jar
Contact atc, atis, ground, p/b,s/e, taxy, line up, take off all perfect
Contact approach, say me climb to fl80, perfect
reach fl080 aproach say to climb to FL280 (my crz altitude) perfect
Stop comunication
I contact center and wait.....TOD distance 35NM-----25NM------10NM-----5NM (no option for comunicat wiht center)---0NM (No option to comunicat)
Shut down X-plane and say lot of bad words smile
246
You also have a huge number of additional libraries installed.
Could you remove all except OpenSceneryX lib and test again ?
Ok, you may get some errors about not working sceneries, but take 2 airports which do not use these
additional libraries.
At the moment I have removed all additional libraries and have x-life running for >6000 seconds,
this is no proof but unusually long :-)
I'm very sorry, CTD again.
What's interesting in the log:
0:08:57.503 E/SCN: Failed to find resource 'Citation_X_C-GCUL.png', referenced from file 'D:\Spiele/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/lit/'.
Failed to open D:\Spiele/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/heavy/b767-300/jal/object.obj: the file cannot be opened.
X-Life Object load error: D:\Spiele\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/heavy/b767-300/jal/object.obj
Who is referencing these files???
CurFlow: AUTOGEN: North NewFlow: AUTOGEN: East
1:03:05.761 I/ATC: Changing EDDS CabState from 0 to 1
1:03:05.761 I/ATC: All departures are done at EDDS. Advancing...
1:03:05.761 I/ATC: Changing EDDS CabState from 1 to 2
1:03:05.761 I/ATC: All arrivals are done at EDDS. Advancing...
1:03:05.761 I/ATC: Changing EDDS CabState from 2 to 0
1:03:05.761 I/ATC: Airport flow changed at XED6B!
1:03:05.761 I/ATC: Changing XED6B CabState from 0 to 1
1:03:05.761 I/ATC: All departures are done at XED6B. Advancing...
1:03:05.761 I/ATC: Changing XED6B CabState from 1 to 2
1:03:05.761 I/ATC: All arrivals are done at XED6B. Advancing...
1:03:05.761 I/ATC: Changing XED6B CabState from 2 to 0
248 (edited by letec 2016-02-27 12:18:55)
Hello. Very, very, very powerful plugin. For me in this moment unusable.
Thank you for your work.
Best Regards
M.H.
249
Finaly i've make a flight complete...thanks to Eugey for help via Skype.
My problem was that in flight plan of x-life i used the cruise leve in wrong format, i inserend 28000 but the correct format is 280
250
I AM STILL getting
X-Life plugin by JARDesign Ver.beta 7 200216
OpenSceneryXpath find
JARDesign plugin: E:\X-Plane 10\Resources\plugins\X-Life\Metar/EDDC.TXT file updated.
Failed to open E:\X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj: the file cannot be opened.
X-Life Object load error: E:\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj
I wonder why it shows the forward and backslash together in the folder name?
basically both files are available in E:\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x
but not in the subfolders "unlit" and "lit".. So I manually copied them there and no further issues in the log.
when I updaten openscenerX on windows.. it deletes the manual copied files.. so I think the x-life plugin should search for a object and a png file in the aircraft folder instead of looking in specific subfolders
also how do I purchase the deluxe version? I cant even demo the atc portion.
