126
I just wanted to state that I'm in love with the plane. However, if the DIRECT option was fixed it would be just great :-)
The master warning still not working with the aircraft in the ground. If you make a mistake there is no way to stop the alarm.
128
This does not work because it is the ATC main window.
Even if you remove x-live completely it won't change anything.
As other planes do have smaller windows and more in the middle, it's an A320 config issue or it
is hardcoded in A320.
If it's hardcoded, please make it a little bit smaller and more in the middle :-)
joomie wrote:
I'm just started trying ATC (or x-life) on A320, and I could not move the main ATC window more to the right....
As I have a 3 monitor setup, I can't read the beginning of all messages in the standard ATC window.
On other planes, the ATC window is quite well positioned.
A320: http://jardesign.org/forum/img/m/552/t/p1aaerh573fbc7r01m9o1f8lvn33.jpg
Chessna 172: http://jardesign.org/forum/img/m/552/t/p1aaes0h4m1eoc1r1d64uk9j1kol6.jpg
How can I move the window more to the right ??
Or is this hardcoded and plane-dependant ?
Create a file X-Plane 10/Resources/plugins/X-Life/settings.txt having the following content and containing 43 lines (last two are empty) and play around with the values in lines 3-13:
JAR5878
1364
580
1320
900
1539
851
0
0
912
I assume this values to store the panel position. Might help. The settings are hopefully reloaded each time you switch traffic on/off/ on via the screen-menu. if not, you need to reopen your current aircraft.
129 (edited by ariel.walker 2016-02-03 15:49:35)
Hi Guys!
I'm not sure if this issue was reported before, but VHF display is not working.
Thanks JAR for make sumulations so real!
Best regards,
Ariel W.
130
ariel.walker wrote:
Hi Guys!
Best regards,
Ariel W.
Have you turned it on? :-) There is a switch for that on the VHF panel.
Cheers
JAR5878
1364
580
1320
900
1539
851
0
0
912
The built in ATC panel of x-plane can be disabled via the settings of x-plane.
132
Well, it should not be disabled :-) It should be some more to right.....  just like other planes, to that it is in the
middle of the monitor.
Yes, you are probably right that the main ATC window is not very useful when using x-life.
I have a problem when flying on IVAO if i get a Direct to from ATC sometimes i loos everything in mcdu and pfd  ( both go blank but aircraft still flyes FP). i have to re enter dep and Arival icao back into MCDU.
I wonder if this is the same problem you have?
134
Haven't got that one yet, in my case, when entering DIRECT that is after T/C or T/D will cause plane not to fly on the path. (here is my yt video I've posted earlier https://www.youtube.com/watch?v=U040LzVfk4M). THe solution for flying on IVAO is to use HDG instead wink
135
Hi and thanks for a great plane!
I downloaded your 2.6b4 and seem to have found the same click-loop as Thomas_99 previously mentioned. Although I did not do a hot start.
I turned on the batteries. APU, bleed and packs. GNADIRS and ELEC pump.
Then I looked at the MCDU and was going to check the a320 settings.
I looked at all entries in order. First FMGS, then NAV data, clicked Show Prof ON then OFF to get it to ON again. Changed the winglets and looked at them. Went into sounds and set them according to the manual of BSS 100,100,30,30,100, ON.
Then came the problem, when I wanted to see the next page clicking the right arrow, there was a click loop started. Still running 5 min later. I have no idea how to turn it off.
I also wonder if it is possible for you to publish incremental patches for these bugfixes, at least on the beta? As there are no versions more of b4 it is hard to know if I have the latest fixes, and downloading the full plane seems like a unnecessary use of bandwidth.
Should I as a customer of X-plane.org worry about number of activations? I used one for the stable version and one for the beta. Will my serial still work when there is a new version or or new beta or will I have to contact support to ask for new ones, and in that case should I contact X-plane.org or you guys here?
Attaching my log.txt and maybe the superfluous bbox_log.txt
Sincerely Jimmy
Attachment icon bbox_log.txt 102 b, 207 downloads since 2016-02-06
136
OK, here is more of the same. But now there is not just a clicking sound but something is triggering a real button click. This is after I reloaded the plane and a new startup from cold and dark.
My ECAM? seems to have gone nuts. I recorded a video to show what is happening. I am afraid I could not record sound with the X-plane recorder so you have to imaging loud clicks on every change :-)
Is this some kind of clash with Gizmo too? I also use SMP v3. I checked the logs and there is nothing there indicating clicks but there is an error, a problem with SASL:
SkyMaxx Pro: Memory Check: 416832 KB GPU, 8568280 KB CPU
[SASL ERROR] Error updating avionics: [string "C:\Program Files (x86)\Steam\steamapps\common..."]:0: attempt to perform arithmetic on a string value
Here is a video:
https://youtu.be/nzIQGX1MGJ4
I made it somewhat anonymous to not pollute.
137
This pack include Hotfix 1 for a320neo by JARDesign ver2.6 beta 4:
WHAT NEW:
+ track lost after apply DIRTO fixed
+ improve blackbox info functions
+ minor bugs fixed
+ Cost Index not affect to CLB/DES spd, fixed
- copy bbox.sec file from this pack to 320neo/Custom Avionics/ (instead of exist file)
- copy mcdu_fpln.sec file from this pack to 320neo/Custom Avionics/sys_mcdu/ (instead of exist file)
138
<3<3<3<3
after first test it seems to be resolved!! great job JAR!
139
Спасибо JAR, КИ теперь работает нормально. CI is working fine now!
Great job Sir Jar
Hi, why doesn't appear speed bar limitation on cruise? Thanks for all http://jardesign.org/forum/img/m/1072/t … 71l4c3.png
142
Sincerely Jimmy
I don't know the exact number of activations (probably 5), but if you run out of activations, contact JarDesign using the official contact form: http://airbus320neo.com/contact/
(I also bought the plane from x-plane.org, apparently it makes no difference)
143
Great! It's a bit scary using up activations. The term seems so final, good to know I won't need to buy the plane again smile
And thanks Eвгений for the accumulated hotfix! smile
144
Here is a video:
You must have clicked on the "All" button. To stop the ECAM from changing pages on its own just click it again. Look at the picture I have attached to locate it.
145
Hello Jardesign!
It seems that hydraulics on the main landing gear aren't working properly. On the real a320 as it touches down, the gear hydraulics get affected right away, as on this video https://www.youtube.com/watch?v=tNhRtkgNV8E , whereas on your a320, main gear stays in the same position as there were no hydraulics, which explains everstalker's appointment of "nose being too low", as if it was overloaded in the front. I hope it gets fixed/added soon wink
Matevž Kramar
146
Thank you. I might very well have pressed that the second time it happened. But the first time it started when I was working on the MCDU. I didn't know one of the buttons did that, but does the real thing really click when going through the pages automatically?
The real thing actually needs to load these ECAM pages for 5+ seconds smile "Please wait, please wait, please wait..."
And yes, there is a quiet clicking sound if I remember correctly.
148 (edited by Anterialis 2016-02-08 16:41:34)
Hello! Just took this bird out on a flight after flying other aircrafts for a while. I immediately got an error during climb online with controllers. Just after takeoff I was asked to go DIRECT TO the last waypoint of the SID. The last point of the SID was _after_ the T/C pseudo waypoint. This immediately resulted in the plane not following the LNAV route at all, rather deviating on a 30-45 degree off set to the left.
This has happened to me many times before. If I shuffle around on the waypoints around a pseudo waypoint (T/D, T/C, 250/lim etc.) I often get into trouble and the plane won't follow the LNAV. Yesterday I fixed this by going DCT to the waypoint just before the T/C, so that the plane would "go through" the T/C. This fixed it and the plane followed the LNAV as intended from there out.
Is this an acknowledged error? Any plans to fix this, if it is possible to fix?
Thank you for a great airplane! Its still my favorite smile But it is quite often messing up my online flying as I often get "DCT TO" commands from traffic controllers...
Are you install hotfix?
http://jardesign.org/forum/viewtopic.php?pid=8979#p8979
150
WHAT NEW:
+ minor bugs fixed
Thank you, i think that has fixed the problem.
I did a flight on sunday eve on line IVAO atc gave me directs and no problems at all.
