Topic: ver 2.6 beta 4 WIN/MAC 64 bit
Please use it if you really want take part in beta-tests. It is a long way to test 2.6 in beta mode, cause a LOT of internal changes was made for this version. v.2.6 MCDU internal structure and internal data transfer code have huge difference compare with 2.5 and become like a330 now. For this reason a number of issue may happen for this beta stage.
2.6 Change list
+Incockpit lights inoperate fixed
+ND line path angle fixed
+some SID/STAR legs drawing fixed
+Arrow Up/Dn multiclick sound fixed
+News module add
+flight model improved, was a realpilots job this time (check on takeoff/landing)
+Dest EFOB at FUEL PRED Page fixed
+"blinking" displays fixed
+No TCAS alert sounds fixed
+Cockpit lights fixed (not sure about Compass Lt)
- AirFMC indication not fixed (cant fix on my side, will contact AirFMC developers)
-ailerons flickered not fixed
-3digit radio indication not fixed
-remove DISC after Takeoff RW not fixed
So, this is the next 320 MCDU/ND improvements - reworked flightplan path (add TMPY FPLN, GA FPLN, ND), new SASL v2.4 implemented (should fix CTD when exit X-Plane), add Saitek Throttle Quadrant support (for LG, Flaps, GSpoilers control)
——————————HOW TO INSTALL:——————————————
Download link http://jardesign.org/a320/download/inst … V2.6b4.zip
  - be sure, that you use X-Plane 10.42 (64 bit only)
Also, just after activation, please download and install actual hotfix for current beta
http://jardesign.org/forum/viewtopic.php?pid=8979#p8979
If your activations are over (activation error) - use contact official support http://www.jardesign.org/ticket/kb/faq.php?cid=1
——————————IMPORTANT NAVDATA NOTES:————————————
FMS NAVDATA Update:
v.2.6 use NavData from
if not find there - will try to read it from
——————       "BETA" is version for Beta-testers!!!    ———————————
This is beta version for X-Plane 10 64 bit. "Beta" mean what some may work wrong. Please report about wrong thing, but only thing what changed in this beta - Flightplan part, MCDU work, ND work
Of particular importance will be issues:
- Drawing (wrong, sure) SID/STARS on the Nav display (please attach a screenshot of true drawing from documents and wrong drawing from your ND, specify the SID/STAR, approach, runway, name of the airport, AIRAC cycle and provider)
- Displacement of characters on the MCDU screen (attach screenshots please)
About:
It works perfectly with 2.5r1 and AirFMC didn't update, so how could they fix it?
3 (edited by ivota 2016-01-06 20:55:23)
I just installed and activated a new beta 4.
First test leg.
- ND terrain -------------> NOT work (black screen), look at video 00:17:08
- after landing BRAKES  NOT working , look at video 00:50:44 (landing)
here is video :
http://www.twitch.tv/ivota_hr/v/33939670
Sorry poor English!!
EDIT:
I am going to do second test flight.
About:
2.6 have another internal structure of MCDU pages and 3 (not 3, like ver 2.5) colors for tittle string
First test leg.
here is video :
EDIT:
please change this file inside Custom Avionics/nd/ folder
I just reupload full pack, but you not need do this, need just 1 file replace.
6 (edited by ivota 2016-01-06 22:09:25)
BUG:
http://www.twitch.tv/ivota_hr/v/33954000
Check video at 00:44:20 till 00:50:33
ivota wrote:
BUG:
Cant open this video (dont know why). May be some text description?
8 (edited by ivota 2016-01-06 22:40:04)
After an intersection plane loose LNAV. (so, I press HDG then NAV to correct LNAV). this is a possible bug.
Also I see in test flight on ND  some hidden white point (AF1, AF2...AF7), that points not in CDU. This is not bug, but some strange for me.
Hello!
"+ND line path angle fixed" is not fixed or maybe I am missing something. Also, DIRECT messes up badly sad
regards
boomflare wrote:
Hello!
regards
screenshot please?
will include screenshots and maybe a video later when I return from work. thanks
12 (edited by dadez77 2016-01-07 19:10:10)
i've download this beta but when dowload airplane show me a pop up advise the beta4 is ready for download. I've activate the plane but tha version write in palne in still 2.6b3. I've download the beta again but same pop up with beta 4 advise but now i've an error during activation. Ho can i solve?
I noticed that the plate.txt in the beta4 version still says B3, so I think that's what you're seeing.
14 (edited by dadez77 2016-01-07 19:18:27)
I've used the form on website to solve it.
thanks
15 (edited by dadez77 2016-01-07 19:20:55)
Ufff...after the second attempt (wiht download)now i cant activate the plane.
I've open a ticket to solve the problem...
I hope in fast solution, tomorrow i'll get my new pc
thanks
Here are the really good news:
First flight from EDDF to EDNY - all was ok, no problems. SID and STAR working, no drawing problems, good flight :-)
Will check other routes at the weekend...
best regards....
Good night from spain.
2 flights today.
LELN LERS and LEVC LEZL. No problems. SIDs and STARs ok.
Best regards.
18 (edited by petitmarseillais 2016-01-07 20:23:22)
Hello just to confirm little issue.
flight plan simple tinot sid and star : LFML TINOT LFKJ
ILS Z 02 TINOT 3H for arrival
I can see IS LIBLO BTA those ndb fix or vor are not in star or approach. BTA is LFKB vor.
I haven t that issue using FF plane who uses same airac
Kind regards
First test leg.
here is video :
EDIT:
Do you use track IR as your cockpit movements are very smooth?
Not sure whats going on here, but I have just downloaded the new plane and installed and done the serial number. I have tried twice now and its loading up b3 still?? Or should I say it says 2.6b3 on the dashboard...
Yes . I use TrackIR v5 with X-camera plugin.
JAR might not have updated the plate file... ?
Hervé
Hi!
Plate is a txt file. You can modify it with a plain text editor.
Hervé
Hervé
Yeah, just forget this
Possible to check version via MCDU if need
Just a small graphical bug:
From EDDL to EDLP, SID and STAR were OK, but a little graphical issue during flight:
http://jardesign.org/forum/img/m/552/t/p1a8h8pmhm1qj41cl6137p1qi617od3.jpg
http://jardesign.org/forum/img/m/552/t/p1a8h8pmhm1c27f9f1s5q1fp1lpq4.jpg
http://jardesign.org/forum/img/m/552/t/p1a8h8pmhmosn1edsusn10k5m4q5.jpg
http://jardesign.org/forum/img/m/552/t/p1a8h8pmhme9m9d520dsgu23m6.jpg
