Re: [?STABLE?] v.1.2r3 (Win 7/8, MAC OS 64 bit) [OnCheck now]
good day,
K a lot of times I am talking out loud so, it not only helps me think but it might make you think of something to fix the issue ... just part of my process ...in issue resolution...
gpb500 wrote:
Java is not needed as far as I can tell.  Never had it installed on this computer.  Everything runs fine including all the built in failures.  wink
Whatever. I checked Java and Microsoft Visual C++ Redistributable 2010 now and all is up to date.
I started XP with the A330. Sounds are ok. Reload again, sounds are gone. Load another aircraft. Sounds are ok. Load A330, again no sound. Any ideas how to narrow the cause?
Yes: Open X-Plane, load A330 ONCE. Fly. Exit X-Plane. This usually works.
If it does not work after a reload, first exit xplane and reload the aircraft.
Just bought the plane from simmarket and curious whether this is the most released from JARDesign? It's A330JD_v1r2.zip file.
r3 is more fresh version
30
My win pc freezes every time with this version during flight, see attached log. The last message is always:
"Loadsheet!!!" - What does this mean?
I don't know about the loadsheet message but you're probably running out of physical memory, causing your computer to crash. I just bought 32 gigs of RAM to put this to rest.
This is no way to narrow the cause. Just a workaround. But as I found the same issue with the Airfoillabs C172, I hardly guess it is a bug in the SASL plugin.
After downloading the A330 update I was quite surprised, that the GndHandling Plugin was within the package. However, I didn't refuse to install it. But I found a bug with this plugin. It is interfering with default XP ATC sound when e.g. the default Baron B58 plane is loaded. There is no ATC sound anymore. Removing the GndHandling Plugin solves the problem. Would this patch solve it as well: http://jardesign.org/forum/viewtopic.php?pid=6126#p6126 ?
34 (edited by k922365 2016-01-03 09:26:55)
http://jardesign.org/forum/img/m/1346/t/p1a83cqcbsvgr6hcqcq10qv12eu3.pngTail lamp will not light
The Tail Light will go off if you are in the air, at a certain height.
36 (edited by Homer.Simpson 2016-01-03 14:27:14)
Logo light doesn't depend on height it depends on flap/slat setting and landing gear.
Logo light on if flaps are extended more than 15 degrees or landing gear is compressed.
37
I know this has been discussed before but I'm wonder if there is an r4 version coming out that will address the speedbrake problem....they don't work...makes descending with a tail wind very, very difficult.  I have the Saitek Pro Flight yolk and quadrant with one of the levers on the quadrant set for speed brakes.  The plane detects that I am deploying the brakes but they have absolutely no effect.  The Saitek lever works on other planes, including default planes and freeware planes.  Any updates on this would be greatly appreciated.  Otherwise, I really enjoy flying the plane.
Maybe this topic will help you: http://jardesign.org/forum/viewtopic.php?id=1489
Thanks, I'll have to give that a try after I land.
40
Just flew from Paris to Dakar and everything was fine until the engine shutdown, as usual... Engine number 2 just goes crazy. Normally I can shut it down by removing all the fuel but this time even that didn't shut it down. This has been a problem since the very first release so it would be nice to have a fix for it please smile
http://jardesign.org/forum/img/m/376/t/p1a8hli1uv1skv5i317qe1q6kq244.png
41
hello j.a.
since few days x plane crash with the a330 in flight, back to desktop. here is what it says:
SkyMaxx Pro: Memory Check: 3182340 KB GPU, 10981036 KB CPU
SkyMaxx Pro: Memory Check: 3180292 KB GPU, 10658676 KB CPU
[SASL ERROR] Error updating avionics: not enough memory
[SASL ERROR] Error drawing panel: not enough memory
anything to do with sasl ?
thanks
jj
shamanitou wrote:
hello j.a.
I rather think you're out of RAM. What is your system spec?
some another installed addons/plugins may eat a looot of memory
need check this first
44
There is a big chance what it is some special problem on user side, cause most users have not this problem. The reason may be an affect of some another installed plugin. There is simple solution. Sure, if you need help with this, you may contact me direct with skype j.a.romanov
How to get "clean" plugins folder to avoid addon conflict.
- Copy your ../X-Plane/Resources/Plugins folder to some place at your computer (just for reserve)
- Delete ../X-Plane/Resources/Plugins folder at all
- run X-Plane Installer and let him update you X-Plane
- now you have "clean" plugins folder
Run your addon and check if problem happen in this configuration.
If problem not happen more, you may return plugin back one-by-one to determinate what of them was a real problem
Sometimes, Gizmo (a plugin system installed with some aircrafts) take control / affect another plugins or aircrafts. In this case you may try to uninstall Gizmo to check is it was a source of problem.
45
Thanks, I'll try this
46 (edited by shamanitou 2016-01-15 21:23:39)
hello guys,
thank's for your concern and suggestions.
for information, i have a graphic card nvidia 970 4G and 16mo ram+I 7 . 60fps usually works fine with all addons.
I did what you said - to take off all plugins and back up one by one. but the problem of crashing is not constant, but aleatory, sometimes works fine, sometimes crash...
i use:
fly with lua
FM
gizmo64 for flywithlua -real terra haze
gndhandling
python interface
python script for noaa
weathermaxpro
silverlining
x ivap
xpuic
i will try again in case..
Do you have a second copy of XP, thats "clean"?  you can install a second copy so if not i'd put in the basic demo and try moving JUST the required files for the plane over to see if that changes anything.
48 (edited by captbullett 2016-01-17 02:44:07)
My guess X ivap causing the issue and xpuic others I am running other plugins listed and no issues on Mac Which is closed system and can isolate if there was issue with other plugins you have listed with JAR aircraft
do not have; gizmo64 for flywithlua -real terra haze
but have gizmo !
49 (edited by Zeke*Earl 2016-01-25 09:09:08)
Hi all,
Will activating v.1.2r3 use up my activation key? I currently have 4.
Also, can i install v.1.2r3 alongside v.1.2r2 in different folders? That way, i can test which version is best & delete the other.
Thank you in advance.
50
good day,
I do believe this can be done put a new folder on your desk-Top and label it 'Good Aircraft' do not put the '' in the label then you can put the old version 1.2v2 there but the WARNING  that I must give you is the SASL will be a different version and once you change versions the old aircraft might not work after the change. This is a security issue and it protects the copyrights of the developer. this is the long answer.
Zeke*Earl wrote:
Hi all,
