Re: [?STABLE?] v.1.2r3 (Win 7/8, MAC OS 64 bit) [OnCheck now]
good day,
K a lot of times I am talking out loud so, it not only helps me think but it might make you think of something to fix the issue ... just part of my process ...in issue resolution...
captbullettgpb500 wrote:Java is not needed as far as I can tell. Never had it installed on this computer. Everything runs fine including all the built in failures.
Whatever. I checked Java and Microsoft Visual C++ Redistributable 2010 now and all is up to date.
I started XP with the A330. Sounds are ok. Reload again, sounds are gone. Load another aircraft. Sounds are ok. Load A330, again no sound. Any ideas how to narrow the cause?
