I've made 4 flights now with B4:
ivota wrote:
- ND terrain -------------> NOT work (black screen), look at video 00:17:08
I can NOT confirm this. ND Terrain was working, tried in EDNY in LOWI, was working
including water.
ivota wrote:
- after landing BRAKES  NOT working , look at video 00:50:44 (landing)
I can NOT confirm this. Tried with brake=MAX & "Break fan" on, breakes were working good, got "Breakes HOT" light,
light switches off after a while.
best regards.
27 (edited by ivota 2016-01-08 19:30:07)
here is a new test flight (night).
http://www.twitch.tv/ivota_hr/v/34280331
+Compass Lt -----> confirm NOT working
thanks @thomas_99
+- ND terrain fixed (WORKING (JAR re-upload fix file))
+ BRAKES now work for me (possible my mistake)
Please, anyone more have any troubles with brakes?
29 (edited by simeg 2016-01-08 23:51:24)
Hi Guys
so i Fly at this Time IVAO World Tour 2016 with this Airbus JARV2.6B4
after the Secound Flight i can not complet shutdown the left or right Engine is a 50/50 chance witsh Engine still Running
When i Cut Off the Engine the N1 and the Rest go lower, but after a point 6.2 N1 he will start again and again but she is flicering up and down to 7,9 and fall  back to 6.2 N1.
i dont know waht is the Problem.
Here is a Video, Pls look Complete: http://www.twitch.tv/vitomcjackson/v/34339207
i have no troble with the Breakes
30 (edited by hdespres 2016-01-08 22:30:18)
Hello all...  the brake problem previously described is not new and I have had the same troubles in earlier version of the A320. I then re-installed the software with no issues....  X-plane problem vs JAR A320?
Wrong forum but I am still having troubles with the A330 engines spooling up after shutdown...
Hervé
Test flight...the improvements are excellent in that the plane tracks the ND path much better (or did I just get lucky).  Will test more.  The angle on the ND as mentioned is not fixed...at least not with a stiff crosswind.  Also didn't have any of those sudden 3K+ ft/min descent surprises.  Also like how the plane doesn't drop to 270K when starting descent.  Good stuff...but I didn't try anything fancy.  Get a few more things fixed and I'll buy the sound pack.  Thanks.
PS - Fix the engine shut down issue on the A330 please.  smile
32 (edited by jarisaizprua 2016-01-09 02:36:12)
I always have the same errors with ILS approaches, even with A330; the AIRAC is updated but the aircraft can't follow it. Please check SEQM ILS Z 36 procedure on the MCDU and ND. Thanks!!!
I will fix a330 fpln module (move 320's to 330) after a320 testing done.
Hervé
Hmm.. may be.. Did you mean.. Hmm.. some users not use brake pedals, but park brake only. In this situation, then autobrake happen (landing/rollout), if user not push brake pedal (as at real aircraft), airbus will not unbrake.
simeg wrote:
Hi Guys
That problem was with x-plane 10.35 may be. What version of X-Plane you use?
36 (edited by simeg 2016-01-09 08:59:52)
Hi Romanov
thx for you fast replay
i have the newest Version of X-Plane V10.42, look the picture pls
http://53950318.swh.strato-hosting.eu/pic/engine.png
37 (edited by kampfnudel85 2016-01-09 11:55:29)
simeg wrote:
Hi Guys
Hmmm i don't know if it will help you, but i have the same error when start the Engines and turn back the ignition switch to fast. The Engine works fine, but when i Shutdown the Engine i have the same error.
Regards / Grüße
Dirk
38 (edited by simeg 2016-01-09 16:17:01)
Hi Members,
i have a idea for this Issus,
I see when i Start the APU than go the Left or Right Engine of this Issuse and start. When the APU is OFF no Issus of Engine
But i test this exactly and set a Video from this Issuse here in my Thred later
Now the Video over the APU and Engine Issus! Running 4 Minutes
http://www.twitch.tv/vitomcjackson/v/34464331
I noticed a very slow decrease of speed when using max brakes after landing
40
First flight EDDF LEVC. No problems. SIDs and STARs works fine.
best regards
Gunter
41 (edited by thomas_99 2016-01-09 17:09:25)
Hi JAR,
Found a new <CLICK>  <CLICK>  <CLICK> :-)
Load plane, Press "HOT START", wait a little bit, press "RAD NAV", press "left".
Result: never stopping click :-)
Yes, BSS sounds installed.
42 (edited by john82088 2016-01-10 05:01:46)
I just purchased the sound pack found here (http://store.x-plane.org/JARDesign-A320 … p_428.html). When flying online (vatsim), I have tried to turn the sound down a little in the cockpit so I can hear the controller better and have not been able to do it through the MCDU or xplane itself. Since I just purchased it, I am not sure if this has anything to do with the beta or the sound plugin. I am using all the recommended settings.
By the way, I love the sound pack - absolutely amazing!
I agree With you John82088, I was thinking i am not leveling Correctly Airplane MCDU and Xplane Sound levels itself, After your post i saw it was not only me ) ! ' if it is not a bug ' . maybe someone can post an explanation to fix it correctly i assume ..
regards
44
@john82088 and @archuser01
https://vid.me/KivV
45
https://vid.me/KivV
Thank You
Flight LFML to LEMD :
-I find ND line path angle no perfect right (see photo); perhaps because of the wind ?
http://jardesign.org/forum/img/m/1125/t/p1a8lteoet1js7lpn1p1e1eg5rts3.jpg
-It seems that TCAS does not function (I had several other planes around me from Wordl xplanes ) but nothing appear on the ND or alarm:
mode TA/RA , All and on
-always 20 to 30 NM difference for the Top of Climb between the ND and the perf page indication
Thanks a lot
Thank you - that was what I was looking for.
48
Possible GoAround bug ?? Maybe someone can comment....
Short before ILS landing, I set new height (5000 ft), which was confirmed with "Go Around Height Set".
30 feet before touchdown I set TOGA-Power, which was confirmed with "Go Around".
The plane set ToGa Power and start to climb. AutoPilot 1+2  was on, plane goes to to HDS.
After HDS, I expect the plane to turn to HAM automatically, but the plane goes straight ahead.
http://jardesign.org/forum/img/m/552/t/p1a8ltj8kfib3n803r41lukhhs3.jpg
Should the plane turn to HAM ?? I think yes, but I'm not sure.
to understand what happen need check
log.txt
bbox_log.txt
tmpfpln.txt
Sorry, but one picture may be cant help.
50
Thanks a lot
So.. you want to say what green line should be always straight ahead? Are you sure? smile
https://youtu.be/9VfI4Pyam1E?t=35s
https://youtu.be/TEi-WX08ov8?t=2m48s
