Topic: ver 2.6 beta 4 WIN/MAC 64 bit
Please use it if you really want take part in beta-tests. It is a long way to test 2.6 in beta mode, cause a LOT of internal changes was made for this version. v.2.6 MCDU internal structure and internal data transfer code have huge difference compare with 2.5 and become like a330 now. For this reason a number of issue may happen for this beta stage.
2.6 Change list
+Incockpit lights inoperate fixed
+ND line path angle fixed
+some SID/STAR legs drawing fixed
+Arrow Up/Dn multiclick sound fixed
+News module add
+flight model improved, was a realpilots job this time (check on takeoff/landing)
+Dest EFOB at FUEL PRED Page fixed
+"blinking" displays fixed
+No TCAS alert sounds fixed
+Cockpit lights fixed (not sure about Compass Lt)
- AirFMC indication not fixed (cant fix on my side, will contact AirFMC developers)
-ailerons flickered not fixed
-3digit radio indication not fixed
-remove DISC after Takeoff RW not fixed
So, this is the next 320 MCDU/ND improvements - reworked flightplan path (add TMPY FPLN, GA FPLN, ND), new SASL v2.4 implemented (should fix CTD when exit X-Plane), add Saitek Throttle Quadrant support (for LG, Flaps, GSpoilers control)
——————————HOW TO INSTALL:——————————————
Download link http://jardesign.org/a320/download/inst … V2.6b4.zip
- be sure, that you use X-Plane 10.42 (64 bit only)
Also, just after activation, please download and install actual hotfix for current beta
http://jardesign.org/forum/viewtopic.php?pid=8979#p8979
If your activations are over (activation error) - use contact official support http://www.jardesign.org/ticket/kb/faq.php?cid=1
——————————IMPORTANT NAVDATA NOTES:————————————
FMS NAVDATA Update:
v.2.6 use NavData from
if not find there - will try to read it from
—————— "BETA" is version for Beta-testers!!! ———————————
This is beta version for X-Plane 10 64 bit. "Beta" mean what some may work wrong. Please report about wrong thing, but only thing what changed in this beta - Flightplan part, MCDU work, ND work
Of particular importance will be issues:
- Drawing (wrong, sure) SID/STARS on the Nav display (please attach a screenshot of true drawing from documents and wrong drawing from your ND, specify the SID/STAR, approach, runway, name of the airport, AIRAC cycle and provider)
- Displacement of characters on the MCDU screen (attach screenshots please)
