126
Re: [STABLE] v.1.2r2 (Win 7/8, MAC OS 64 bit)
I never used that option so I don't know if you can reenable it again.
dima21m wrote:
I forgot to turn on the fuel pumps and the entire flight without fuel pumps. Is that possible on the A332? Add the switch on fuel pumps in the checklist please.
Yup, It's possible. It's called gravity feed. Most if not all Airbus Aircraft have this.
128
I bought the Update sounds 3D package for the A330-243. Now I do'nt know how to install the update (ENGINES) - see attached photo. Can you help me, please? Thank you.
Manuel
mjcorreiax@gmail.com
129 (edited by flydav 2015-11-18 20:05:40)
Manuel
Yo can only have 1 "engines" folder at the same time so the one you don;t use should be renamed. Depending on the one that you intend to use so if you want to have RR you will have the "engines" folder and the "enginesPW" folder if you want to have PW you will have "engines" and enginesRR" does it help?
130
when you disable rain window effect, you can't enable it later.
Manuel
Hello, where are you find sound update ?
thanks
132 (edited by captbullett 2015-11-20 14:09:19)
here is the link to the FB page... https://www.facebook.com/BlueSkyStarSim … s/?fref=ts
Manuel
thanks
133
Thanks. I have buy it. I wait the mail for download.
134
thanks, you are right. I have buy the sounds of Blue Sky Star and i have not the tic tic tic...
Bye
135
To reactivate, i have to install the aircraft again? Or how i can enable it?
Sorry for the confusion but you just have to load it again from x-Plane Aircraft menu to enable it again.
137
And where do i load it? ;-)
The A330 Menu has only a "Rain Windows Disable" Button. But no enable Button.
138 (edited by captbullett 2015-12-05 02:55:22)
click button , re-load aircraft
Not in A330 Menu. Do it in x-planes Menu Aircraft/ Open Aircraft/
select the a330.acf and click open aircraft
Thanks for answer. But that didnt work for me. I testet it with 2 PCs. One with AMD and one with Nivida. Same
result. No rain drops. Any other ideas?
Hi, i have a problem wich i cant solve. Do not know if it is normal, dosen seem so.
In the 3D view in the cockpit (wehn i look forward) or the panel fwd view, i don't hear the engines  even if i full throtle for TO. I hear them if i turn backwards in 3D view but forwards i cant apreciate the sound or just very little. I just viewed some videos like  on youtube about the JAR 330 and an all of them i can see how during TO i can hear the negine very clear.  Not so so low as on my Windows. TRied this version and version R3.
Would apreciate some suggestion.
Greeting and thanks,
AnatolRohé. Spain, Palma de Mallorca
142
Just checked the problem. It was cause of 5.1 stereo. Tried it with 2.1 and works really great. Selfsolution
