Re: [STABLE] v.1.2r2 (Win 7/8, MAC OS 64 bit)
I never used that option so I don't know if you can reenable it again.
JARDesign Group Board → Downloads, Updates. → [STABLE] v.1.2r2 (Win 7/8, MAC OS 64 bit)
I forgot to turn on the fuel pumps and the entire flight without fuel pumps. Is that possible on the A332? Add the switch on fuel pumps in the checklist please.
Yup, It's possible. It's called gravity feed. Most if not all Airbus Aircraft have this.
I bought the Update sounds 3D package for the A330-243. Now I do'nt know how to install the update (ENGINES) - see attached photo. Can you help me, please? Thank you.
Manuel
mjcorreiax@gmail.com
Manuelmjcorreiax@gmail.com
Yo can only have 1 "engines" folder at the same time so the one you don;t use should be renamed. Depending on the one that you intend to use so if you want to have RR you will have the "engines" folder and the "enginesPW" folder if you want to have PW you will have "engines" and enginesRR" does it help?
when you disable rain window effect, you can't enable it later.
Hello, where are you find sound update ?
thanks
here is the link to the FB page... https://www.facebook.com/BlueSkyStarSim … s/?fref=ts
mjcorreiax wrote:I bought the Update sounds 3D package for the A330-243. Now I do'nt know how to install the update (ENGINES) - see attached photo. Can you help me, please? Thank you.
thanks
Thanks. I have buy it. I wait the mail for download.
thanks, you are right. I have buy the sounds of Blue Sky Star and i have not the tic tic tic...
Bye
when you disable rain window effect, you can't enable it later.Thanks
To reactivate, i have to install the aircraft again? Or how i can enable it?
Sorry for the confusion but you just have to load it again from x-Plane Aircraft menu to enable it again.
And where do i load it? ;-)
The A330 Menu has only a "Rain Windows Disable" Button. But no enable Button.
click button , re-load aircraft
Homer.Simpson wrote:Sorry for the confusion but you just have to load it again from x-Plane Aircraft menu to enable it again.
The A330 Menu has only a "Rain Windows Disable" Button. But no enable Button.Regards
Not in A330 Menu. Do it in x-planes Menu Aircraft/ Open Aircraft/
select the a330.acf and click open aircraft
Thanks for answer. But that didnt work for me. I testet it with 2 PCs. One with AMD and one with Nivida. Same
result. No rain drops. Any other ideas?
Hi, i have a problem wich i cant solve. Do not know if it is normal, dosen seem so.
In the 3D view in the cockpit (wehn i look forward) or the panel fwd view, i don't hear the engines even if i full throtle for TO. I hear them if i turn backwards in 3D view but forwards i cant apreciate the sound or just very little. I just viewed some videos like on youtube about the JAR 330 and an all of them i can see how during TO i can hear the negine very clear. Not so so low as on my Windows. TRied this version and version R3.
Would apreciate some suggestion.
Greeting and thanks,
AnatolRohé. Spain, Palma de Mallorca
Just checked the problem. It was cause of 5.1 stereo. Tried it with 2.1 and works really great. Selfsolution
