captbullett wrote:Good day,
can we see log.txt or screen shot so we know what we are working with.
thank-you,
Hi, certainly,
The screenshots are at http://c3po.pclark.com/screens.zip (13MB file)
I took the screenshots with the snipping tool on my PC, and using the screenshot function on my iPad.
The first pair are initpage and initpage-ipad. The iPad capture is missing the title bar and the arrows.
The second pair (departure1, departure-ipad) are from the f-plan button. Go into EGLL, click departures and fill in the blanks. The bottom line has not refreshed and the lower case "tmpy" is missing above the F-PLN LSK.
The third pair (f-pln2, f-pln2-ipad) are after going back to F-PLN from filling in the departure. The title bar hasn't refreshed properly, the arrows are missing, and the 6L LSK hasn't refreshed.
The fourth pair (f-pln3, f-pln3-ipad) are after executing 6R from the previous page; the title bar hasn't refreshed, the colors haven't changed from temporary to executed, the SK6 line hasn't refreshed, and now going to any subsequent page is completely unreadable.
The last screenshot (img_0046) is from the iPad after going from the f-pln to perf section. This state of display corruption remains until the sim is restarted. I have exited and re-entered the app on the iPad. I'm running the latest (1.2) AirFMC and the latest (HSAIRXPL-4.3.1.zip) plugin. The AirFMC team said this was because the 330 isn't clearing the screen that is output to the plugin between each keypress. I can't say I know enough about the API to know if this is correct, but the screen corruption between the 330 and the AirFMC progressively gets worse as AirFMC is used, while the in-aircraft display is fine, so something appears to be amis between the 330 and the plugin rather than specifically with the 330.
Thanks,
