Re: First of all..
I was not able to create a new thread ( I guess I need to reply few times before you are allowed) so I am posting here.
I see how much work goes into development of that great plane and I really like it.
Today I installed the newest version withGround plugin.
Everything works great but I do have a little problem.
I wanted to assign the button on my yoke for autopilot 1 press button but when I go to Settings/Joystick & Equipment menu, there is no dataref for it .
Actually , nothing related to A332 shows up that could be selected.
Is that something I did wrong?
Please help.
Thank you for a great plane.
27
Re: First of all..
rus: Здравствуйте! После установки последнего обновления GndHandling, в модели A320Neo ver 2.4b4 пропал звук нажатия кнопок и переключения тумблеров в кокпите. Сделал откат на предыдущую версию GndService, которая шла с А330 и звук появился.
eng: Hello! After installing the latest upgrade GndHandling, model A320Neo ver 2.4b4 sound disappeared pressing buttons and toggle switch in the cockpit . Did rollbacking GndService, that came with the A330 and the sound came .
OS w7 64bit XPlane10.36 (Steam) I7 4770 RAM 16Gb VIDEO GTX770 2Gb
Aleksey Dekterev
28
Re: First of all..
Здравствуйте! Если есть возможность - свяжитесь со мной по скайпу j.a.romanov - проверим на Вашем компьютере, потому что проблема нетипичная.
29
Re: First of all..
Hi! This *looks* really cool, but IMO it would be even better if it could be used to actually load people and fuel, too.
Several of those third-party aircraft that come without any ground objects of their own, are also loaded via the Weight & Fuel panel, which does reduce immersion; having fuel and passenger loaders similar to your A320/A330 would be a real plus.
It would end up being incompatible with *some* addons, but even the FlyJSim aircraft can be loaded via Weight & Fuel nowadays, thanks to a new checkbox-controlled option (currently 732 only, but 727 update is in progress).
I guess the big issue would be handling the center of gravity correctly for each aircraft, but hopefully a satisfactory solution can be found?
30
Re: First of all..
GHD can set datarefs value and if some aircraft fuelpanel cam be called by dataref - this will work
Re: First of all..
Can you tell me whether this will be available through the org store in the near future?
Many thanks in advance
Re: First of all..
I hope yes, but cant say exact data. May be 2 week later, may be next month.
33
Re: First of all..
Thanks for the quick response, much appreciated!
Re: First of all..
FWIW, I meant for using it with planes that don't have a fuel panel, like the QPAC A320, RWDesigns A330 or even Carenado planes - having to go to X-Plane's "Weight & Fuel" is not as nice as having a dedicated fuel and passenger panel.
It would be nice if the ground handling plugin could provide its own fuel and passenger panels for those planes.
I can understand if it's a PITA to implement, it's just a feature request smile
Tim
