Topic: First of all..
As you know, I do not often appear on the forum. Why is that? I prefer to work more and I apologize if the communication is not enough. I know what users think that everything happens for too long. It really is. But our developments are carried out with the speed at which we have enough of our hands and brains. This little information about a prospective plug. At first glance, it is made on the basis of airport equipment of a330, but actually had a 90% re-write the code, add "Set editor", add more 3D. What you see now - is not all. And we are continue.
http://jardesign.org/forum/img/m/22/t/p19r0a3n5i1ffpf1c1g511oto14kt3.jpg
some Video http://www.youtube.com/watch?v=PpT3VmmaQi8
Re: First of all..
more
http://jardesign.org/forum/img/m/22/t/p19r0a4dv3efo1pl38a512fbc4f3.jpg
Re: First of all..
http://jardesign.org/forum/img/m/22/t/p19r0a52hu8rgppfee0ls71ff3.jpg
Re: First of all..
http://jardesign.org/forum/img/m/22/t/p19r0a5ibr4ic1vd7p1qmtrm9q3.jpg
Re: First of all..
Cool work! Looks Amazing. So it will be possible to set the way for each ground Equipment? Wow
Re: First of all..
Yes, Possible to set coord for every path point of every car in set, also speed, time delay, animation parameters. I will prepare some video tutorial later.
Re: First of all..
Looks really Amazing
Re: First of all..
Really great idea! What about cargo and belt loader?
Re: First of all..
workon loaders now
Re: First of all..
Nice job!
Will be this plugin looks like GSX for FSX?
because from now, for me, look the best plugin I have big_smile
Re: First of all..
I don't know about GFX.. really, we build just own smile
Re: First of all..
Anyway to make possible test the plugin with others aircraft? Because I know that we can test, setup, but don't work with.
Or maybe pay for it work?
Nice job guys!
Re: First of all..
We plan to post it with near a330 release (need add small loader for it too). After this will be possible to make GS registered.
Sure, on this stage Editor should work with other planes, but not possible call all together cars.
Re: First of all..
This is a fantastic immersion idea!
You guys are making XPlane better and better as the months tick on.
Are you looking into adding people too?
Cheers,
Tedd
Re: First of all..
Understood. It is possible to make a marshallers like in GSX??
Re: First of all..
Great plugin, used it on my last A330 flights.
One suggestion I have: It is not plausible at all which stairway or catering truck is 1, 2 or 3. Would it be more useful to name multiple names the same way it is done with the doors? Means FWD, MID, AFT.
For example "Catering FWD" instead of "Catering 1". I always disable or call the wrong one :-)
Re: First of all..
Cars have not special names, but just count from 1 to ...
Re: First of all..
HI J.A. Romanov,
Great addition to Xplane!
You are pushing the boundaries everyday!
Question to you:  "How do we utilise this mod across other ACF?  I would like to create further sets!"
Are we required to purchase a registration key?
Look forward to your response.
Tedd
Re: First of all..
Teddit wrote:
HI J.A. Romanov,
Tedd
Check your PM please!
Re: First of all..
Teddit wrote:
HI J.A. Romanov,
Tedd
I would also like to be able to try it out with other aircraft! What point is there in posting layouts if we cant use them? tongue
Re: First of all..
Now this plugin not in stock. When it will be released as separate plugin, anyone who have it will have opportunity
to build own set.
Re: First of all..
Any plan to put humans on the others vehicles like in the picture below on left side:
http://jardesign.org/forum/img/m/1040/t/p19tjsgvpm1r081ucdjvi48iltq4.gif
Re: First of all..
Slava?
Re: First of all..
yes, it works well after you learn the how to's on working the plugin and setting up the system I am also, using the fallow-me car that JAR designed and when you have the Follow me car opened and the fuel truck opened the tabs over-lap on the bottom of the screen. Is there a way to move so, you can see the two tabs and they are not in the same position.
This is not a major issue more cosmetic issue I do believe. I noticed it i do not know how many people have the Follow-me car and the A330 on the same computer...
Thank-you for the good work everything does work this is one point I do want to make.
Re: First of all..
Slava?
Do you plan to design humans in the loaders or inside stairs, like in the picture above?
