TurboGigi wrote:Good day,
I have the same problem. I have repeated many times the flight.
- This procedure because the plane at some point no longer meets the correct route.
- During descent, at some point, the plane loses course, change direction or go straight when it should turn.
- At this point, I tried to enable to "PERF" Approach Phase.
- Next, I clicked the "DIR" and I selected the next point, but continued on his way (the wrong one), so I pressed the button "APPR" (although I was not very close) and the 330 has taken the right route, but in the end it remained high thus are not able to land.
Taking the same route with the 320neo I have no problem (everything works perfectly)
So.. from TOGA to 5000 ft you have this
>>> zulu 12:13:24
baro alt=-158 / rad alt=1
air spd=33 / gnd spd=23 / mach=0.05
vert mode = SRS
lat mode = RWY
thr mode = MAN FLX
thr mode = MAN TOGA
>>> zulu 12:13:27
baro alt=-159 / rad alt=1
air spd=46 / gnd spd=35 / mach=0.07
active wpt = 3 EO603
>>> zulu 12:13:49
baro alt=-135 / rad alt=30
air spd=134 / gnd spd=128 / mach=0.2
lat mode = RWY TRK
>>> zulu 12:13:50
baro alt=-114 / rad alt=50
air spd=137 / gnd spd=130 / mach=0.21
lat wait = non
lat mode = NAV
>>> zulu 12:14:2
baro alt=264 / rad alt=434
air spd=152 / gnd spd=146 / mach=0.23
thr mode = A.FLOOR
>>> zulu 12:14:4
baro alt=314 / rad alt=488
air spd=156 / gnd spd=151 / mach=0.24
thr mode = TOGALK
>>> zulu 12:14:36
baro alt=1900 / rad alt=2090
air spd=190 / gnd spd=189 / mach=0.29
vert mode = V/S
>>> zulu 12:15:0
baro alt=3192 / rad alt=3380
air spd=212 / gnd spd=215 / mach=0.34
vert mode = CLB
>>> zulu 12:15:23
baro alt=4140 / rad alt=4331
air spd=257 / gnd spd=265 / mach=0.41
vert wait = non
vert mode = ALT*
>>> zulu 12:15:30
baro alt=4950 / rad alt=4929
air spd=261 / gnd spd=271 / mach=0.42
vert mode = ALT
And TOGA LOCK say me that that was not correct pilotage on the first stage of flight.
Next I see >>> zulu 17:21:54
baro alt=28031 / rad alt=28220
air spd=316 / gnd spd=499 / mach=0.79
thr mode = MAN TOGA
thr mode = MAN THR
Seems like joystick (thr lever) have noise and move itself.
>>> zulu 17:34:3
baro alt=28001 / rad alt=28160
air spd=314 / gnd spd=489 / mach=0.79
active wpt = 9 (T/D)
>>> zulu 17:41:48
baro alt=27957 / rad alt=28116
air spd=282 / gnd spd=456 / mach=0.71
thr mode = non non
But when I read that, seems like boeing pilot in cockpit OR joystick (thr lever) have noise and move itself again!
I think need make more correct flight with the same route and will se what happen with log.
Please read a FAQ before you post a bug
http://support.jardesign.org
