Re: [STABLE] v.1.2r2 (Win 7/8, MAC OS 64 bit)
Hi! Nice update! Until now, nothing wrong.
Just want ask if are possible to make a update on the MCP, like in the picture, on A320 we can chose more than one button. But on A330, just one. It's normal in real? Or you plan make this?
http://jardesign.org/forum/img/m/1040/t … ncjta3.png
27 (edited by Igor96 2015-08-26 05:53:51)
В десятой бета версии Х-плэйна самолет первый раз вылетел в момент запуска двигателей, второй раз на подлете к аэропорту назначения. В релизе 10.36 полет нормальный. Опять что то в бете сломали)))
This is the correct behaviour. In r/l Airbus aircraft you can only select one display mode (CSTR, VOR, WPT, etc.) at a time. So it's actually the other way around, the A320 needs fixing.
Personally, I'd love to see the following issue fixed in future versions.
Climb Energy Sharing:
http://jardesign.org/forum/viewtopic.php?id=1158
Waypoint constrains on F-PLN page:
http://jardesign.org/forum/viewtopic.php?id=1157
ECAM Auto Mode:
http://jardesign.org/forum/viewtopic.php?id=1156
And a tricky, but important toppic
Roll command, Yaw Dampers, Flare law:
http://jardesign.org/forum/viewtopic.php?id=1159
2nd flight was ok, no problems, but I noticed a really small bug:
After landing and parking the airplane, I switched all electrical power off. No batteries, no external power...
The cockpit was completely dark.... except one button: "break fan". I forgot to switch it off.....
Pressing on the button can switch it on and off and the lamp was going on and off also there was no
electrical power...
best regards, Thomas
30
If you have always installed 1.2r1, not need reinstall all to have r2, but need just update a330 set from link
http://jardesign.org/forum/viewtopic.php?id=1221
I'm having a similar issue but with X-plane ATC. After installing the ground handling folder I loose all radio communications with all my installed planes, not just the A330. The text messages between the cockpit and ATC still appears, just no voice sound. If I remove the plugin the issue goes away.
midi48 wrote:
I have a strange problem.  i downloaded A330 last evening and placed the Ground services in plugins folder. Loaded up A330 and activated it ALL OK works fine and GND services No Problem.
Later that evening i loaded up X- aviation DC3 No engine sounds Strange i thought.
I tried my 2nd copy of x plane and dc3 is ok. I re installed DC3 to my main copy of x plane again still no engine sound. I removed GND service plugin from plugins and DC3 sound all ok.
I placed GND services plugin into my second copy of X plane and DC3 had no sound.
All other Aircraft seem ok, so im not sure whats going on.
Thanks! I didn't know about that, so because this I asked here.
Nice to know.
ECAM Auto Mode:
33 (edited by flightime56 2015-08-27 03:49:47)
v1.2r1 Mac
Works really well, only one issue...  Route line (green) on Nav display is off by 0.5º, does not affect the heading or the aircraft's position, it is just showing wrong in the display?
I feel the vehicle line up is the wrong place at the rear of the aircraft? you can't pushback unless you hide them, and they are too good to hide?
The pallet loaders are brilliant, but could there be more pallets to be loaded? and could there be a reverse unloading option?
Trucks with pallets would be great as well, but simply brilliant.
SD
Hi, excuse this approximate translation.
Problem FCU all buttons are inactive: no form of circles and arrows no hand
It's the new mouse wheel scroll function. Place your mouse over the knob and scroll with your mouse wheel up or down. I love it personally! smile
A little side note to JAR, the engine throttling up after shutdown is still an issue sadly sad The only way to shut the engine down is to remove all the fuel with the fuel truck, after it's gone crazy.
And by the way, it will throttle up way beyond the engine's limits, which is normally impossible with a FADEC...
36 (edited by alessandro61 2015-08-27 11:33:53)
I have same problems.
if I remove Ground Plugin, all sound correctly.
37
To check this sound issues i need check it on user-side. Please contact me direct skype j.a.romanov
I installed again and everything is ok. Thank you so much!!
Hmmmm... But sure i need someone with this bug smile
40
Hi.
Have done four flights with this version, two of them, the speed brakes did not activated at all, in the air nor at landing.
Happened not with the last beta.
(love the scroll function, so I do not want go back to an earlier version)
Windows 8.1
XP 10.40b5
41
Today I had a problem which I did not have a long time... loss of flight plan....
please have a look at the 2 images... 2nd image after pressing the "F-Plan" button...
http://jardesign.org/forum/img/m/552/t/p19toep40q1qnp1bbb1lvi1gdhc095.jpg
http://jardesign.org/forum/img/m/552/t/p19toepbkjj55mu1vdu1pbdm847.jpg
Need just use AIRPORT button or scroll with arrows UP and DN may be
Some problems with the CDU behaving erratically and SASL errors.
44
Not good idea to install X-Plane to /Users/@@/Desktop/X-Plane 10/...
this "@@" may give error also.
Better - move X-Plane folder to Application folder for MAC or C:/ drive for Windows
45
The guys at the Org Forums really stress the fact to not put the X-Plane folder in a system owned location ...
46 (edited by TurboGigi 2015-08-28 13:56:58)
I have the same problem. I have repeated many times the flight.
- This procedure because the plane at some point no longer meets the correct route.
- During descent, at some point, the plane loses course, change direction or go straight when it should turn.
- At this point, I tried to enable to "PERF" Approach Phase.
- Next, I clicked the "DIR" and I selected the next point, but continued on his way (the wrong one), so I pressed the button "APPR" (although I was not very close) and the 330 has taken the right route, but in the end it remained high thus are not able to land.
Taking the same route with the 320neo I have no problem (everything works perfectly)
So.. from TOGA to 5000 ft you have this
>>> zulu 12:13:24
    baro alt=-158 / rad alt=1
    air spd=33 / gnd spd=23 / mach=0.05
vert mode = SRS
lat  mode = RWY
thr  mode = MAN FLX
thr  mode = MAN TOGA
>>> zulu 12:13:27
    baro alt=-159 / rad alt=1
    air spd=46 / gnd spd=35 / mach=0.07
active wpt = 3 EO603
>>> zulu 12:13:49
    baro alt=-135 / rad alt=30
    air spd=134 / gnd spd=128 / mach=0.2
lat  mode = RWY TRK
>>> zulu 12:13:50
    baro alt=-114 / rad alt=50
    air spd=137 / gnd spd=130 / mach=0.21
lat  wait = non
lat  mode = NAV
>>> zulu 12:14:2
    baro alt=264 / rad alt=434
    air spd=152 / gnd spd=146 / mach=0.23
thr  mode = A.FLOOR
>>> zulu 12:14:4
    baro alt=314 / rad alt=488
    air spd=156 / gnd spd=151 / mach=0.24
thr  mode = TOGALK
>>> zulu 12:14:36
    baro alt=1900 / rad alt=2090
    air spd=190 / gnd spd=189 / mach=0.29
vert mode = V/S
>>> zulu 12:15:0
    baro alt=3192 / rad alt=3380
    air spd=212 / gnd spd=215 / mach=0.34
vert mode = CLB
>>> zulu 12:15:23
    baro alt=4140 / rad alt=4331
    air spd=257 / gnd spd=265 / mach=0.41
vert wait = non
vert mode = ALT*
>>> zulu 12:15:30
    baro alt=4950 / rad alt=4929
    air spd=261 / gnd spd=271 / mach=0.42
vert mode = ALT
And TOGA LOCK say me that that was not correct pilotage on the first stage of flight.
Next I see >>> zulu 17:21:54
    baro alt=28031 / rad alt=28220
    air spd=316 / gnd spd=499 / mach=0.79
thr  mode = MAN TOGA
thr  mode = MAN THR
Seems like joystick (thr lever) have noise and move itself.
>>> zulu 17:34:3
    baro alt=28001 / rad alt=28160
    air spd=314 / gnd spd=489 / mach=0.79
active wpt = 9 (T/D)
>>> zulu 17:41:48
    baro alt=27957 / rad alt=28116
    air spd=282 / gnd spd=456 / mach=0.71
thr  mode = non non
But when I read that, seems like boeing pilot in cockpit OR joystick (thr lever) have noise and move itself again!
I think need make more correct flight with the same route and will se what happen with log.
48 (edited by TurboGigi 2015-08-28 15:13:13)
smile
That's right, I was late for work, and then I made a high-speed flight, and not at 250 ... I'm testing the approach (I have the problem in approach, does not maintain the route), not on cruise. wink
49 (edited by flydav 2015-08-28 15:42:40)
Thanks Jar but that is not the problem I always remove my name and place @@ before posting the logs here wink
My installation is X-Plane 10 /Users/(@@my name) /Desktop/X-Plane 10/ I know for sure that MAC users, unlike windows users, should NOT install X plane in the application folder.
50 (edited by captbullett 2015-08-28 15:42:15)
yes I think you have it right I would like the line up of the vehicle to be, off to the side so, that you can push-back or, move the aircraft after the start-up sequence has been achieved.
(+1)
flightime56 wrote:
v1.2r1 Mac
SD
