Re: [STABLE] v1.1r1 (Windows 7/8) posted
Well, the bug here is only about differences between AirFMC (pictures on the left) and xplane (pictures on the right).
So you can see that the FMC on the left side differs from the right side.
Both pictures should (or must) display exactly the same information, but that isn't. So AirFMC is not 100% usable
at the moment.
I got a fix for AirFMC, but with this updated version, not all problems are solved.
P.S. The pictures you are showing does not give me any information I can use I need the route info and SID and STAR used in the planning so i can fly the route to see if it is in the UFMC or something else... but i do not think it is the UFMC since, I have had many good flights.
thomas_99 wrote:Hi !
J.A.Romanov wrote:Fresh version of a330 send to AirFMC all needed data and it is "AirFMC ready". I think AirFMC need to be updated to be possible to show all correct. Its author work on it, as I know. Not need any changes from JARDesign side.
Well, I talked to haversine support and got a new plugin for AirFMC, but not all problems are solved with the new plugin. They said that there is also a bug in the current v1.1r1 release and the A330 needs an update...
best regards, Thomas
