Topic: [STABLE] v1.1r1 (Windows 7/8) posted
This is a330 by JARDesign v1.1r1 distributive (Windows 7/8)
Download link http://jardesign.org/a330/download/inst … _1.1r1.zip
  - be sure, what you use Windows 64 bit X-Plane 10.36 (no beta, please) for Windows 7/8
This is Windows version for X-Plane 10 64 bit.
Yes, it is included all needed files to work with X-Plane 64 bit for MAC OS, but it is "Windows version", course this version is not stable on MAC. Sure, you can try and report.
Whats new: Please use v1r2 tag like this http://jardesign.org/forum/search.php?a … ;tag_id=52
+AirFMC ready (please update your AirFMC plugin and AirFMC application)
+Custom soundpack ready (you can install and use custom sound packs from another developers)
+Glideslope engage softened
+RNAV arrival Transition wrong reading and drawing fixed
+Double/triple/multiply saying "Checklist ... completed" fixed
+Doors auto open when ground staff come after landing
+ «TA only» indication add when takeoff
+GPWS front panel button add
+HYD SYS identification numbers fixed
+FUEL PRED & Time checked and fixed
+Strobe pattern after Place The Aircraft via The X-Planes Location Menu fixed
+Table Checklist add
+some External light improvements
+ND Wind indication fixed according FCOM
+Minor 3D cockpit errors fixed
+Waypoint delete error in MCDU fixed
Please contact me to add activations if you have activation error - please use contact form here:
Please discuss all about releases at "Pilots forum, general discussion, support" only.
2 (edited by flavio58 2015-06-05 16:56:41)
Re: [STABLE] v1.1r1 (Windows 7/8) posted
Wonderful, thanks a lot smile
Thank you for the hard work !!!
Very much appreciated, thanks !
Is it stable on Mac?
smile please read first post!
I did. Just wondering ...
8 (edited by captbullett 2015-06-06 22:23:05)
I hope you can now make the decision whether to try this or not, I have installed the version and have one flight with no issue and it worked well but, that is not enough to say it is good so I will leave the rest up to you.
have a good day.
Note: second flight All a OK ... no CTD ...
I also had one flight yesterday with the 1.1r1, from KMSP to KDEN. No CTD's.
I flew from LEMD to LFPO at FL390 and no CTD. But still getting the violent left or right bank when I open the x-plane menu... It's so violent and quick that if I let the autopilot take care of it, the plane will go inverted before the autopilot has time to correct it.
on gnd crash.
happy to see you are trying this aircraft this version seem to be very good but i do not want to ...
have a good day
13 (edited by captbullett 2015-06-08 14:24:24)
Just after Three flights the CDT's start and this is the pattern that is with all aircraft it does not matter what aircraft you are flying i have pulled the plugins out and yet the Sasl issue is to blame and no other issue"." here is the list of Flight plans I ran but it does not matter which routes you fly only that you flew 3 flights on my computer.
1)KMID/KLAX
2)KLAX/KATL
3)KATL/KPHX
4)KPHX/BOS
When setting up to run the fourth flight the computer CTD and I am sending the log.txt and all the other information as per the usual... these were run in succession and there were breaks taken I have screen shots of VRAM and CPU usage
Screen shot #3=is an error message of the computer crashing or a CTD error message in the Apple console.
Screen shot #5=  is a screenshot of the Activity Monitor and the Active Processes running one of which is X-Plane as you can see the registered CPU usage and the threads used.
Screen shot #6 Is my rendering settings.
Screen shot#7 shows my plugins and what the state is from the plugin manager,
Screen shot#8 the same as #7 plugin manager
the other screenshots are duplicates and i did not mean to down load
I hope this helps  on the Sasl issue.
Attachment icon bbox_log.txt 118 b, 388 downloads since 2015-06-08
Attachment icon Screen Shot 2015-06-04_#3_10.34.51 AM.jpg 44.83 kb, 187 downloads since 2015-06-08
Attachment icon Screen Shot 2015-06-04_#3_10.34.51 AM.jpg 44.83 kb, 182 downloads since 2015-06-08
Attachment icon Screen Shot 2015-06-06_#6_2.25.37 PM.png 174.83 kb, 203 downloads since 2015-06-08
Attachment icon Screen Shot 2015-06-07 at 1.17.32 PM.jpg 30.5 kb, 239 downloads since 2015-06-08
Attachment icon Screen Shot 2015-06-07_#5_1.17.42 PM.png 33.18 kb, 166 downloads since 2015-06-08
Full flight tested and fully functional. I am really happy. Many thanks to JAR and BSS Simulations for the great work done.
Just did my second flight. A short one, e.g. KSAN27-KPHX08 at FL290. Warm & Light - On The Numbers - Managed Flight - CT 30. CAVOK - 1013. Ideal circumstances.
No CTD ...
Following the Captain's Logic, I'm in for a treat right after the next flight?
I really hope it does not happen so the cycle is broken.
No CTD ...
The next version of OS X (i.e. the one after Yosemite) will be called .... [drum roll] ... El Capitan. This one is for you Brian!
I did LFPO - LZIB and LFPO - LTBA and no CTD
No CTD ...
There was one strange thing. I've mentioned this before in older versions:
When I tried to insert an altitude restriction or a new waypoint, the corresponding Select Key lit up in yellow and kept being yellow for 10 seconds or longer. At that time the FPS tumbled all the way down from 20-25 to 3 or 4.
I guess the Captain is right. After a few successful flights, I got a CTD, right after take off and before putting the throttle back to Climb Mode. Autopilot was still off.
Bummer ...
Attachment icon X-Plane_2015-06-09-171819_iMacIVYBridge.crash.zip 16.58 kb, 322 downloads since 2015-06-09
good day,
what one for me, LOL
then this is the issue we need to reproduce... so it can be de-buged and fixed and bingo ... Issue resolved ...
Bummer ...
yes there is a delay when changing in-flight, using the UFMC and entering data or changing data. Could it be to warn you of the change?
TDPlane wrote:
No CTD ...
BSS Simulations?!
Short flights with MAC OSX Yosemite from LSZH to LSGG and EDDF to LSZH. Everything ok except AirFMC. Could not choose SID and STAR on the Ipad. On the FMC of the Plane everything was ok.
