51 (edited by thomas_99 2015-06-18 15:32:17)
Re: [STABLE] v1.1r1 (Windows 7/8) posted
Well, the bug here is only about differences between AirFMC (pictures on the left) and xplane (pictures on the right).
So you can see that the FMC on the left side differs from the right side.
Both pictures should (or must) display exactly the same information, but that isn't. So AirFMC is not 100% usable
at the moment.
I got a fix for AirFMC, but with this updated version, not all problems are solved.
P.S. The pictures you are showing does not give me any information I can use I need the route info and SID and STAR used in the planning so i can fly the route to see if it is in the UFMC or something else... but i do not think it is the UFMC since, I have had many good flights.
Fresh version of a330 send to AirFMC all needed data and it is "AirFMC ready". I think AirFMC need to be updated to be possible to show all correct. Its author work on it, as I know. Not need any changes from JARDesign side.
Well, I talked to haversine support and got a new plugin for AirFMC, but not all problems are solved with the new plugin. They said that there is also a bug in the current v1.1r1 release and the A330 needs an update...
best regards, Thomas
This version (v1.1r1) is the latest or version  v1r2 is latest?
53
Version 1.1r1
v1.1r1 distributive (Windows 7/8)
My first CTD Windows 7
After 7 hours flight adding way point to FMC lock up then after me pressing buttons to get fmc working CTD.
Mike
hmm
The log states you ran out of memory.
it did a long way after the fault with sal not cleaning up. lol
Mike
hmm
57 (edited by Mad Mat 2015-07-09 22:00:09)
v1.1r1 bug report.
Hi, I tried 4 times to do a flight from VTBS to RJAA. The flight went well until i lost all displays in the cockpit, no numbers, no PFD, no MFD, no FMC, all become blank. But the aircraft was still flying correctly on autopilot.
I use windows 8.1 with X-Plane 10.40b5. Is there a specific place to post the bugs or is ok here?
I attach the files but the aircraft is still flying...
58
I just bought your great aircraft for my Imac on Xplane.org but the version available is v1r2
is this the latest version ?
thank you for your help
L
59
No the Version found in this topic First Post Version 1.1r1 is the lastest Version.
thanks !!!
61
Nice work, have been ocupied with work and such. finally back on forums!
The tow does not work in EDDM from Aerosoft - revolves around the A-pillar
I'm having to download a new copy of this aircraft after the 10.40B7 corrupted it ...
and I have had two CTD's from rolling back to 10.36
Redownloading the aircraft will not fix what 10.40b7 has caused.
65 (edited by Miguel Angel 2015-08-09 18:56:19)
I think He means his aircraft was corrupted by 10.40b7 and therefore He have to download  another fresh copy of the plane again as well as the official x-plane stable version.
captbullett miss the beta 6 and seems not to be very happy with the stable version nor the b7 either.
66 (edited by captbullett 2015-08-09 19:17:56)
almost right we had an unstable 10.36 for mac and 10.40 B6 was the sweet spot so I will be waiting for the up-date but what I do not like is people putting words in my mouth. I have plenty of other aircraft to play with and other thing to do i was passing along information so, I could help if someone else was having the same issues as I was I was not complaining.
Nevertheless, the aircraft "A330 file was corrupted by the version of XP 10.40B7 so, the only way to get a good aircraft to fly right is to download a fresh copy of the aircraft that way when i go to use it again it will be a clean copy and it should work the way it was intended to be flown. weather in 10.36 or 10.40B8 because it will not have the 10.40B7 Bug in it.
Karl I have been doing this just a little longer that you have my friend.
67
Is it suppose to ask to reactivate or did I do something wrong?
Rivera, J. M.
1334945, ZNY Controller
X-Plane 10.10
Intel Core i5-4690K | 2x Geforce GTX 970 (SLI) | Kingston HyperX FURY 16GB Kit
