you have not seen the post I posted straight from the gismo plugin makers where I gave them a log.txt to look at and they replied, which states that it is an Sasl issue not Gismo I to have removed and replaced the plugin after I found out it did nothing for the issue.
Nevertheless, I am using the same version of XP as you are and 10.10.4 on the iMac also, I have gismo loaded. Since, it is the 10.40 version of XP that has help out not the other way around and since, I have started using 10.40 yes the reduction of CTD's is true the XP 10.35 was a very unstable version of XP and caused issue with many plugins and aircraft and third-party plugins and 10.40 also addressed the Mac issues therefore, you are having less issue as am I and everyone else which is what was suppose to happen.
thank-you for your post
I am using X-Plane 10.40b5 and latest Yosemite. I can confirm that removing Gizmo reduces CTD by 90%. I still get CTD once in a while after takeoff, but disabling Gizmo seems to be a good idea.
Thank you!
Tim
