Topic: v1.1b5.2 distributive mostly the same b4 + new base SASL plugin
v1.1b5.2 distributive mostly the same b4, but with new base SASL plugin for Tests.
Please install it as clear installation, not use custom sound pack, not mix files with other version, but sure, install NavData update if need.
If you have a CTD at MAC, please place reports direct here (log.txt file and MAC crash report). This version build to understand how new mac os SASL base plugin stable on MAC.
Download link http://jardesign.org/a330/download/inst … .1b5.2.zip
Whats new: Please use v1.1 tag like this http://jardesign.org/forum/search.php?a … ;tag_id=52
Also, please check "whats new"with link above. Please not post old issue what always reporter but not done/fix at this version.
please check and inform
Crashed after activation and aircraft reload.  restarted x-plane; crashed when loading aircraft.  rebooted, started x-plane; crashed on aircraft load.
ctd crash report attached.
Fuel truck and displays are working now (i had no CTD after activation or reloading)... Will report further findings.
CTD after engine start while pushing back while in outside view.
3 CDTs
Attachment icon X-Plane_2015-05-19-190504_Mac-Pro.crash 78.92 kb, 340 downloads since 2015-05-19
Attachment icon X-Plane_2015-05-19-190853_Mac-Pro.crash 79.91 kb, 315 downloads since 2015-05-19
Attachment icon X-Plane_2015-05-19-195405_Mac-Pro.crash 79.48 kb, 301 downloads since 2015-05-19
Attachment icon X-Plane_2015-05-19-195405_Mac-Pro.crash 79.48 kb, 314 downloads since 2015-05-19
thanks! we need reports for statistic - will send all to SASL developers.
No Ground Equipment. When i call it, nothing will happen.
So i download the 1.1b5.2 again. Delete the a330 in the aircraft folder, unzip the downloaded file, put the a330 folder into the aircraft folder, start x-plane, activate again, load again the aircraft, and..?
Nothing, nothing happened, when i call the ground equipment.
So i delete the 1.1b5.2 and go back to the 1.1b4 ;-(
9 (edited by J.A.Romanov 2015-05-19 16:15:28)
one more
Hello! Test flight of LPRF retinues to EDDM without significant problems. Everything is wonderful! Now makes flying with this A330 a lot of fun! Maybe could improve the flight stability during cruising something man! Good landings - Klaus version 1b5.2 / X-Plane 10.35r Mac OS Yosemite 10.10.4
11 (edited by zek0 2015-05-19 19:23:18)
Ok ladies and gentlemens. After loading A330 plz wait about 5 minutes without any moves. If you have plugins (ex. NOAA weather, Skymax or other) try not touch anything about 7-10 min. Also if you was 1 full flight, dont reboot x-plane, you may fly all day without CTD. (all things about os x). And if you wanna see replay - all rules is crash (but need check this).
12 (edited by J.A.Romanov 2015-05-19 19:43:33)
one more..
xplane crashes everytime i try to load a330
Try load Cessna, after that try load a330
Yesterday did some nice flight EDDL->EDDH->EDDL.
Today same routing CTD while rotating after Vr.
Thanks for report. This is error in Lua Garbage Collector (part of SASL)
17 (edited by zek0 2015-05-20 08:53:31)
One CTD on ground (fast start)
Attachment icon X-Plane_2015-05-20-123439_Mac-Pro.crash 69.54 kb, 292 downloads since 2015-05-20
CDT on after T/D
Attachment icon X-Plane_2015-05-20-142525_Mac-Pro.crash 72.06 kb, 316 downloads since 2015-05-20
Hello, yesterday Flight from Faro to Muinch without Problems, today Frankfurt to Montreal problems as before in Version 1.1b4 - taxiway to the runway Programm stop and shut down! ( v1.1b5.2 )
please attach log files (also crash reporter logs) it is very important.
Hello again, secound Testfilght to day BIKF -EDDT Program crash - taxiing from the Gate - alltime the same Problem :-( good day!
22 (edited by emha 2015-05-20 15:44:48)
First Flight with 1.1b5.2 EDDM-LPFR without any problems.
Second flight EDDM-EDDF starts very well. No problems. But on Descent at short before FL100 i switch landing lights on. On turn back the view to "normal" view, CTD. ;-(
All flights Online via VATISM
23 (edited by cessna729 2015-05-20 19:11:20)
Win 7-64, XP10.35, v1.1b5.2 Downloaded, installed, activated, re-loaded.............CTD.
Restart XP, load C-172SP, then Load v1.1b5.2.........................CTD.
Restart XP, load  Load v1.1b5.2.........................CTD.
Last Log.txt and bbox_log.txt attached.
The last lines of the Log.txt were:
SASL ERROR: Error loading panel: not enough memory
It was then I noticed that I had installed into Aircraft Folder as per instructions......
but I had actually re-named the folder from:330_JARDesign  to 330_JARDesign v1.1b5.2
When I re-named the folder back to 330_JARDesign, the a330 loaded ok!!
cessna729.
Attachment icon bbox_log - Copy.txt 119 b, 304 downloads since 2015-05-20
24 (edited by cessna729 2015-05-20 19:55:41)
Win7-64, XP10.35, v1.1b5.2, If you try and move the aircraft with the engines running using XP Location --> Select Global Airport --> and pick a different ramp start location or a Rwy some of the the displays go blank.
http://jardesign.org/forum/misc.php?action=pun_attachment&item=556&download=0
Not sure if this is an intentional "future" and or a "bug"? i.e. in real life you can't " instantaneously transport" an aircraft to different  location like in Star Trek
cessna729.
Attachment icon bbox_log.txt 122 b, 320 downloads since 2015-05-20
thanks for this info, it is useful about CTD when rename
so, i typical load in needed airport and next - reopen 330, next move it to gate and next - start any procedures
