Re: v1.1b5.2 distributive mostly the same b4 + new base SASL plugin
the route://* 22L is the departing runway and 25L at KLAX is the landing runway using , Baset , Downe as the STARS to the KLAX 25L landing ...
KMDW DCT JOT J18 MZV V434 OTM V216 LMN J64 TBC J128 PGS STAR KLAX
FL 370 ; speed as per set by UFMC
distance 1491+-< as I already took off when I took this reading.
Take off fuel 033048 KG
note:
I am now running the same route using version V1.1R1 released today using everything the same and the same set-up as when i had the last CTD. only thing different no Gismo plugin to start the session.
captbullett wrote:Good day,
As per the letter I removed all the plugins and the issue became even more clear Here is the issue that I have been aware of and always thought was the underlying issue and until they fix there will be issues ... I cannot say it any way else I saw the issue with the A350 by FF when I was testing it and the issue was the Sasl plugin I am not trying to be mean but when you take everything away this is the issue just like (Ben's suggestion removing the plugin shows that the issue is in the Sasl plugin it's self) . I am sending the log txt just to look at ... I only meant to download one log txt but the system is playing tricks... and bbox so you can see everything else.. if you need any thing else let me know..
captbullettSASL ERROR: Error drawing panel: [string "/Users/brianhelip/Desktop/X-Plane 10/Aircraft..."]:0: attempt to index a nil value
SASL ERROR: Error drawing panel: [string "/Users/brianhelip/Desktop/X-Plane 10/Aircraft..."]:0: attempt to index a nil valueJ.A.Romanov wrote:Now, we have not result for mac. We understand what some wrong happen with memory, but not understand well what problem exactly.
If this can be repeated - we have 2 way -
- need description what need to do to repeate this (i need get the same on my computer, course i have a debugger log, not the same as at user computer)
- contact with Skype and repeat this together using share screen mode
