Re: v1.1b5.2 distributive mostly the same b4 + new base SASL plugin
yes it is
JARDesign Group Board → Beta-versions (Download & Discussions) → v1.1b5.2 distributive mostly the same b4 + new base SASL plugin
yes it is
Hello JAR team, so the 330 version 1.1b6 caused on my Mac 10.10.4 and Xplane 10:36 already at the start of the program to crash. Are there any plans for updates or solutions? Greetings to Moscow - Klaus
as of today every time I open the A330 to run the aircraft it CTD and here is the information I can't tell if it is Gizmo causing the issue or not so I am including the log.txt from it as well. this is what I see a an potential issue //* Gizmo64: warng: ERROR: boot script not found. //
again happy to help
I updated Xplane on my IMac to 10.36 and Xplane CTD. Went back to 10.35 and loaded latest version of the A330. Three hour flight tonight and no crash. However Gizmo disabled.
Hi Jar,
I just want to inform you that 1.1b5.2 is quite stable if I disable Gizmo plugin on my Mac.
Alessandro
iMac 27" -14. 16 GB RAM, 512 GB SSD, GPU nVidia 775m, CPU i5.
xPlane 10.36 (udated yesterday).
OSx Yosemite latest update.
After installing and successfull activation of the plane, CTD. On xPlane restart, immediate CTD during simulator loading. I will try attaching a logfile later this evening.
Thanks for all the hard work!
thanks for reports!
After many testflights i think the ctd's in my case are a result of real whether.
When i fly without real whether, there are no ctd's yet.
Maybe you can Check in this direction?!
How do I upload the log.txt file? I only see the "upload images" button...
Choose for "Post Reply" (right under the last post); that gives you the option to upload files ...
good day,
I thought I would share this correspondence with you so everyone can see just what is going on and stop the guessing. and this is related to the last CTD I had which is posted on this page. post # 53
Brian.
This message indicates that Gizmo64 was unable to find a "commercial product" key file.
It is in no way related to your SASL problems.
If you want to be sure, remove Gizmo64.plugin from your plugins folder and test to see if the A330 still crashes.
You have several other plugins installed too. Any of these could be the source of problems.
It does seem that the A330 is problematic for a large number of users, all with different computers and configs.
While SASL and the A330 are not my products or my problem I do know this:
The problem is being actively investigated with help from Laminar.
Laminar are adding features to the sim that will help ALL plugin authors protect their memory resources from being trampled by other plugins and even the sim itself.
In time, with both sim and plugin updates, this will allow us to know exactly where the problem is with any existing and future plugin conflicts.
Ben R
Note: One,
I just went to the "plugin manager" and turned off the Gismo plugin, along with MaxxFX since MaxxFX uses the Gismo plugin.
Nevertheless, I will not know if this will help until I run some flights and test the set-up.
Additionally, I turned off the plug-in, PythonInterface, SeaTrafic V1.10, Ground Traffic v1.50 LFNL , Ground Traffic v1.50 KRNO,
Ground Traffic v1.50 KPNX, and Ground Traffic v1.50 LOWI.
The plugins that I left on:
CustomSBDatarefs004 , DataRefEditor , EZPushback 0.3.2 (mac) , autoGate v1.60, and Airport-Navigator v1.3.0
Also the A330 plugins are being used.
@ El Capitano Brian,
If you want to give the plugin-hypothesis a real test (Ben's suggestion), you should remove them all together from your setup. It's not necessary to delete them; just move them out of your X-Plane folder and restart the simulator. Using the plugin manager within X-Plane could mean you're too late ... Been there done that ...
Theo.
PS
Get well soon ...
yes you are quite right but I have removed them also and still had the CTD's but that was with the A350 FF so I was not convinced that by removing the plugin does anymore good that just turning them off and testing first, and then going to the next step and removing them.
I also found while I was working on the issue I was not in the right Nav data cycle I was 1505 and not 1506r2 so I will finish the flight that I am working on and continue the process on the next CTD I will remove the Gismo plugin and the MaxxFX since the MaxxFX is dependent on the Gismo Plugin.
[I have screened shot the settings and the power that the XP app is using to help in the setting for mac]
and what are "Tail Strikes" ? the Developers Console in Screen shot #5 will show a line of code about a "tail strike" and the fowling is the message:
//* sound3d play sample->tail strike.wave // this is when the issues happen...
Thank-you for your feed back it is most welcomed in my world, I need to see the forest for the trees.
Theo.
PS
Get well soon ...
Flight from EIDW to KJFK. Didn't follow route for a large part of the journey. This may have been due to Route Discontinuity which I though't I'd fixed as was showing as a continuous route and also removed the Route Discontinuity message from the Flight Plan.
X-Plane crashed when I was just about to intercept the localiser at JFK - 6 hours down the drain.
captbullettTDPlane wrote:@ El Capitano Brian,
Theo.
PS
Get well soon ...
Now, we have not result for mac. We understand what some wrong happen with memory, but not understand well what problem exactly.
You have installed 5-6 other plugins. Noone can understand what reason for CTD for this setup. The last words was
DEF load time: 2892 for water.
DEF load time: 2901 for water.
DEF load time: 2840 for water.
DEF load time: 2934 for water.
DEF load time: 2858 for water.
DEF load time: 2913 for water.
DEF load time: 2842 for water.
DEF load time: 2893 for water.
DEF load time: 3034 for water.
DEF load time: 2922 for water.
DEF load time: 2947 for water.
It is nor airbus 100%
Thanks JAR. I'll take out some of the plugins and see if it improves.
Tried a flight from KBOS to KJFK with all plugins bar the JARDesign ones and Autogate removed. It crased in the exact same place just as it was intercepting the localiser. However, this time it crashed the PC.
Looks like an SASL issue?
As per the letter I removed all the plugins and the issue became even more clear Here is the issue that I have been aware of and always thought was the underlying issue and until they fix there will be issues ... I cannot say it any way else I saw the issue with the A350 by FF when I was testing it and the issue was the Sasl plugin I am not trying to be mean but when you take everything away this is the issue just like (Ben's suggestion removing the plugin shows that the issue is in the Sasl plugin it's self) . I am sending the log txt just to look at ... I only meant to download one log txt but the system is playing tricks... and bbox so you can see everything else.. if you need any thing else let me know..
SASL ERROR: Error drawing panel: [string "/Users/brianhelip/Desktop/X-Plane 10/Aircraft..."]:0: attempt to index a nil value
captbullett wrote:Good day,
Theo.
PS
Get well soon ...Now, we have not result for mac. We understand what some wrong happen with memory, but not understand well what problem exactly.
This is SASL error. How can I repeat this situation?
captbullettSASL ERROR: Error drawing panel: [string "/Users/brianhelip/Desktop/X-Plane 10/Aircraft..."]:0: attempt to index a nil value
SASL ERROR: Error drawing panel: [string "/Users/brianhelip/Desktop/X-Plane 10/Aircraft..."]:0: attempt to index a nil valueJ.A.Romanov wrote:captbullett wrote:Good day,
captbullettNow, we have not result for mac. We understand what some wrong happen with memory, but not understand well what problem exactly.
If this can be repeated - we have 2 way -
- need description what need to do to repeate this (i need get the same on my computer, course i have a debugger log, not the same as at user computer)
- contact with Skype and repeat this together using share screen mode
Acei wrote:Tried a flight from KBOS to KJFK with all plugins bar the JARDesign ones and Autogate removed. It crased in the exact same place just as it was intercepting the localiser. However, this time it crashed the PC.
Should be pretty straight forward. It was using standard X-Plane scenery with only Autogate and Airport Navigator plugins.
Imac crashed straight after registration!
rocess: X-Plane [543]
Path: /Applications/X-Plane 10/X-Plane.app/Contents/MacOS/X-Plane
Identifier: com.laminar_research.X-Plane
Version: 10.35r1 (398)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: X-Plane [543]
User ID: 501
Date/Time: 2015-06-05 20:27:39.552 +0930
OS Version: Mac OS X 10.10.3 (14D136)
Report Version: 11
Anonymous UUID: 715E3FF0-47F5-4FE6-5B19-D11C4CACA2C5
Time Awake Since Boot: 7400 seconds
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000022719a28c
VM Regions Near 0x22719a28c:
MALLOC_SMALL 0000000186800000-0000000188000000 [ 24.0M] rw-/rwx SM=PRV
__TEXT 0000123440000000-0000123440865000 [ 8596K] r-x/rwx SM=COW /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 mac.xpl 0x0000000084d832b0 lj_tab_get + 48
1 mac.xpl 0x0000000084d8c033 lua_rawget + 195
2 mac.xpl 0x0000000084d65b85 getGlobalPanelValue(char const*, int) + 85
3 mac.xpl 0x0000000084d655c5 xap::reloadPanel(bool) + 1029
4 mac.xpl 0x0000000084d664ad XPluginEnable + 461
5 XPLM 0x000000007f128231 XPLMEnablePlugin + 139
6 XPLM 0x000000007f128339 XPLMEnableACFPlugins() + 37
7 XPLM 0x000000007f12785b XPLMEventHook + 361
8 com.laminar_research.X-Plane 0x000000010022c929 XPPEventHook(int, float, float, long, long) + 137
9 com.laminar_research.X-Plane 0x0000000100bd4ca3 veh_class::IO_veh(int) + 1187
10 com.laminar_research.X-Plane 0x000000010063a6bd veh_class::load_veh(int, int) + 1533
11 com.laminar_research.X-Plane 0x0000000100ae19f6 APP_handlemenu(int) + 3638
12 com.laminar_research.X-Plane 0x0000000100ad10cb mbar_class::mbar_select_an_item() + 619
13 com.laminar_research.X-Plane 0x0000000100ad1908 mbar_class::mbar_select_an_item_click() + 1048
14 com.laminar_research.X-Plane 0x0000000100b24ba8 MACIBM_handle_click(int) + 24
15 com.apple.AppKit 0x00007fff8cd342fc -[NSWindow _reallySendEvent:isDelayedEvent:] + 14125
16 com.apple.AppKit 0x00007fff8c6c3d76 -[NSWindow sendEvent:] + 470
17 com.apple.AppKit 0x00007fff8c6c0312 -[NSApplication sendEvent:] + 2504
18 com.laminar_research.X-Plane 0x000000010039d2a4 WIN_event_loop_once + 340
19 com.laminar_research.X-Plane 0x0000000100c793cb WIN_run_app + 43
20 com.laminar_research.X-Plane 0x000000010061d053 main + 1075
21 com.laminar_research.X-Plane 0x00000001004918c0 start + 52
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff8e5e8232 kevent64 + 10
1 libdispatch.dylib 0x00007fff8bf68a6a _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x00007fff8e5e251a semaphore_wait_trap + 10
1 com.laminar_research.X-Plane 0x0000000100104bff UTL_platform_semaphore_dec(UTL_semaphore*, int) + 159
2 com.laminar_research.X-Plane 0x0000000100104e4c UTL_semaphore_dec(UTL_semaphore*, int) + 140
3 com.laminar_research.X-Plane 0x00000001001ded0d UTL_pool_task* UTL_message_queue_read<UTL_pool_task*>(UTL_message_queue<UTL_pool_task*>*, int) + 45
4 com.laminar_research.X-Plane 0x00000001007d9c5c UTL_threadpool::thread_func(void*) + 60
5 com.laminar_research.X-Plane 0x00000001005f03b5 THREAD_launch(void*) + 69
6 libsystem_pthread.dylib 0x00007fff8d670268 _pthread_body + 131
7 libsystem_pthread.dylib 0x00007fff8d6701e5 _pthread_start + 176
8 libsystem_pthread.dylib 0x00007fff8d66e41d thread_start + 13
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff8e5e24de mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff8e5e164f mach_msg + 55
2 com.apple.audio.CoreAudio 0x00007fff9013b57e HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 98
3 com.apple.audio.CoreAudio 0x00007fff9013b50c HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4 com.apple.audio.CoreAudio 0x00007fff90139aa9 HALC_ProxyIOContext::IOWorkLoop() + 965
5 com.apple.audio.CoreAudio 0x00007fff90139612 HALC_ProxyIOContext::IOThreadEntry(void*) + 88
6 com.apple.audio.CoreAudio 0x00007fff901394e3 HALB_IOThread::Entry(void*) + 157
7 libsystem_pthread.dylib 0x00007fff8d670268 _pthread_body + 131
8 libsystem_pthread.dylib 0x00007fff8d6701e5 _pthread_start + 176
9 libsystem_pthread.dylib 0x00007fff8d66e41d thread_start + 13
Thread 10:
0 libsystem_kernel.dylib 0x00007fff8e5e748a __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff885e3e50 usleep + 54
2 mac.xpl 0x000000007f1e8197 gizmo_thread_sleep(int) + 23
3 mac.xpl 0x000000007f1e8168 gizmo_pthreads_DoCurlTransfer(void*) + 1368
4 libsystem_pthread.dylib 0x00007fff8d670268 _pthread_body + 131
5 libsystem_pthread.dylib 0x00007fff8d6701e5 _pthread_start + 176
6 libsystem_pthread.dylib 0x00007fff8d66e41d thread_start + 13
Thread 11:
2 mac.xpl 0x000000007f1c09e7 gizmo_pthreads_Mapping_TerrainBake(void*) + 871
3 libsystem_pthread.dylib 0x00007fff8d670268 _pthread_body + 131
4 libsystem_pthread.dylib 0x00007fff8d6701e5 _pthread_start + 176
5 libsystem_pthread.dylib 0x00007fff8d66e41d thread_start + 13
Thread 12:
0 libsystem_kernel.dylib 0x00007fff8e5e2532 semaphore_timedwait_trap + 10
1 com.laminar_research.X-Plane 0x0000000100104bad UTL_platform_semaphore_dec(UTL_semaphore*, int) + 77
2 com.laminar_research.X-Plane 0x0000000100104e21 UTL_semaphore_dec(UTL_semaphore*, int) + 97
3 com.laminar_research.X-Plane 0x000000010010145d void* UTL_message_queue_read<void*>(UTL_message_queue<void*>*, int) + 45
4 com.laminar_research.X-Plane 0x00000001007cb0c7 run_g1000_g430_thread(void*) + 375
Thread 13:
0 libsystem_kernel.dylib 0x00007fff8e5e794a __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff8d66e40d start_wqthread + 13
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x000000007f11f680 rbx: 0x000000022719a280 rcx: 0x0000000017136f80 rdx: 0x000000004200c660
rdi: 0x0000000017120380 rsi: 0x0000000017127240 rbp: 0x00007fff5fbfb7b0 rsp: 0x00007fff5fbfb760
r8: 0x643268746469576c r9: 0x000000007f11f6a0 r10: 0x000000010197f200 r11: 0xfffffffffa2f7392
r12: 0x0000000000000008 r13: 0x0000000000a10d00 r14: 0x0000000017120380 r15: 0x000000001cf31da0
rip: 0x0000000084d832b0 rfl: 0x0000000000010202 cr2: 0x000000022719a28c
Logical CPU: 6
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x10000 - 0x36ff7 com.apple.audio.OpenAL (1.8 - 1.8) <B05578A8-FE08-310C-BF91-C1BDE10858CD> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x48000 - 0x4cfff com.apple.agl (3.3.0 - AGL-3.3.0) <83B4076C-BD87-3436-B59F-65184128FEC1> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x53000 - 0x55fff com.apple.ForceFeedback (1.0.6 - 1.0.6) <A411AA46-5DB6-3C6C-B4B4-613EC1EF33C3> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
0x5a000 - 0x61fff +com.googlecode.google-breakpad (1.0) <D40F69E5-0F60-C476-668A-E1CB9B0DFA6F> /Applications/X-Plane 10/X-Plane.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad
0x6d000 - 0x7efe7 +breakpadUtilities.dylib (1) <0B629D05-BC04-EB6D-7D62-1D108165D719> /Applications/X-Plane 10/X-Plane.app/Contents/Frameworks/Breakpad.framework/Resources/breakpadUtilities.dylib
0x7fc000 - 0x7fcff5 +cl_kernels (???) <CCF8CF59-B8D9-47F6-9F14-55FC3AEDCEA5> cl_kernels
0x9479000 - 0x9479fef +cl_kernels (???) <EB6D6F44-5361-4B32-83CC-90C922F4DF27> cl_kernels
0xb696000 - 0xb77cfef unorm8_bgra.dylib (2.4.5) <7BFE1DA8-2BE4-3B4F-8A7F-F3D6D4D36ADA> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0xe42d000 - 0xe64aff3 com.apple.audio.units.Components (1.12 - 1.12) <AC14ADC7-587F-3E0F-92E7-9D8C07753C22> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0xe706000 - 0xe70afff com.apple.audio.AppleHDAHALPlugIn (272.18 - 272.18) <BCBCD7EE-C5ED-3558-8176-70BFC88925B1> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x1283a000 - 0x12847fe7 +mac.xpl (???) <DAE0B9E8-C065-A86F-83F1-229764492248> /Applications/X-Plane 10/*/mac.xpl
0x12c6a000 - 0x12c83ff7 +mac.xpl (0) <A6C2A760-5D66-3DBD-BFBD-9B97FC40B517> /Applications/X-Plane 10/*/mac.xpl
0x15dc3000 - 0x15dc9fff +mac.xpl (0) <D5511E70-ED6C-361B-B713-CBE44AE0FE3F> /Applications/X-Plane 10/*/mac.xpl
0x15ef4000 - 0x15ef9ff7 +mac.xpl (???) <99D8A359-C98D-1DE2-A234-1B2100D777BB> /Applications/X-Plane 10/*/mac.xpl
0x7f120000 - 0x7f141ff7 +XPLM (1) <B497C673-ADC9-CC40-FCC7-57ADA1831586> /Applications/X-Plane 10/*/XPLM.framework/XPLM
0x7f15a000 - 0x7f164fff +XPWidgets (1) <D70FDCF2-B986-53CA-8E7F-5068206957BF> /Applications/X-Plane 10/*/XPWidgets.framework/XPWidgets
0x7f16c000 - 0x7f556fe7 +mac.xpl (0) <B6298CA1-228E-3987-93C1-45DDB927368B> /Applications/X-Plane 10/*/Gizmo64.plugin/64/mac.xpl
0x7fa2f000 - 0x7fa6dfef +libcurl (6.1) <2CFAC41E-2634-9196-90A7-9A5084C91FC3> /Users/USER/Library/Frameworks/libcurl.framework/Versions/A/libcurl
0x818d9000 - 0x819c9fff +mac.xpl (???) <B020D7F6-D6B6-37F7-AC5F-0B01A6EA8DBA> /Applications/X-Plane 10/*/mac.xpl
0x83cb6000 - 0x83cbcff7 +mac.xpl (0) <D22D47AC-FD7E-347A-8FB8-A1061778986F> /Applications/X-Plane 10/*/mac.xpl
0x84439000 - 0x84444ff7 +mac.xpl (0) <27C45F74-FBC4-31CF-B6E3-204C0222C010> /Applications/X-Plane 10/*/mac.xpl
0x84d54000 - 0x84e5dff7 +mac.xpl (0) <D3769C84-9589-3DCA-AB8A-E1600FDE40E7> /Applications/X-Plane 10/*/mac.xpl
0x86def000 - 0x86dfafff com.apple.iokit.IOHIDLib (2.0.0 - 2.0.0) <F02FEFEC-1005-3DBC-919E-3BD31B273684> /System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib
0x87c24000 - 0x87c2ffe7 +mac.xpl (???) <DF8FA97C-AB36-4C13-D94B-EEA1CCEA24FB> /Applications/X-Plane 10/*/mac.xpl
0x87c34000 - 0x87c41fe7 +mac.xpl (???) <DAE0B9E8-C065-A86F-83F1-229764492248> /Applications/X-Plane 10/*/mac.xpl
0x100000000 - 0x1014b5fcf +com.laminar_research.X-Plane (10.35r1 - 398) <FEF96756-B25C-F035-1FD6-82E0C8F6BE2D> /Applications/X-Plane 10/X-Plane.app/Contents/MacOS/X-Plane
0x123440000000 - 0x123440864ff7 com.apple.GeForceGLDriver (10.2.7 - 10.0.2) <0C5B7449-911C-35A0-8BC8-03FA1ADEB670> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x7fff68fce000 - 0x7fff69004837 dyld (353.2.1) <65DCCB06-339C-3E25-9702-600A28291D0E> /usr/lib/dyld
0x7fff85b9f000 - 0x7fff85c75ff3 com.apple.DiskImagesFramework (10.10.1 - 396) <1149D3E1-CC6C-3177-916D-2BE066DC9344> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff85c8c000 - 0x7fff85e1afff libBLAS.dylib (1128) <497912C1-A98E-3281-BED7-E9C751552F61> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff85e1e000 - 0x7fff85e1eff7 libunc.dylib (29) <5676F7EA-C1DF-329F-B006-D2C3022B7D70> /usr/lib/system/libunc.dylib
0x7fff85ee0000 - 0x7fff85ee0fff libOpenScriptingUtil.dylib (162.1) <E0605012-0DDB-3150-8FD0-699376FA3CD0> /usr/lib/libOpenScriptingUtil.dylib
0x7fff85eee000 - 0x7fff85f21fff com.apple.MediaKit (16 - 757.2) <2912E5C2-085F-3FE2-8531-23B6E894B0F0> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff85f22000 - 0x7fff85fb3ff7 libCoreStorage.dylib (471.20.7) <ECD8903C-F131-3A9A-BBF4-E124DA028909> /usr/lib/libCoreStorage.dylib
0x7fff86093000 - 0x7fff86096ff7 libdyld.dylib (353.2.1) <9EACCA38-291D-38CC-811F-7E9D1451E2D3> /usr/lib/system/libdyld.dylib
0x7fff86097000 - 0x7fff86099fff com.apple.loginsupport (1.0 - 1) <DAAD7013-A19D-3858-BFF7-DE1DAF664401> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff860a5000 - 0x7fff860a5fff com.apple.Accelerate (1.10 - Accelerate 1.10) <2C8AF258-4F11-3BEC-A826-22D7199B3975> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff8621f000 - 0x7fff86228ff3 com.apple.CommonAuth (4.0 - 2.0) <BA9F5A09-D200-3D18-9F4A-20C789291A30> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff86229000 - 0x7fff8622eff7 libmacho.dylib (862) <126CA2ED-DE91-308F-8881-B9DAEC3C63B6> /usr/lib/system/libmacho.dylib
0x7fff8622f000 - 0x7fff86249fff com.apple.AppleVPAFramework (1.4.4 - 1.4.4) <5C37DBD3-EB91-3A58-BD2F-E0CD533DE467> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff8682e000 - 0x7fff8684efff com.apple.IconServices (47.1 - 47.1) <E83DFE3B-6541-3736-96BB-26DC5D0100F1> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff86873000 - 0x7fff86885ff7 libsasl2.2.dylib (194.1) <35371406-75EF-304A-A073-956C40373555> /usr/lib/libsasl2.2.dylib
0x7fff86886000 - 0x7fff86a35fff GLEngine (11.1.2) <68FDFD73-F15C-3460-9984-10F5DEF79907> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff86a36000 - 0x7fff86b5aff7 com.apple.LaunchServices (644.56 - 644.56) <20AABB1C-9319-3E4D-A024-51B0DD5FCD3B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff86b5b000 - 0x7fff86b78ffb libresolv.9.dylib (57) <26B38E61-298A-3C3A-82C1-3B5E98AD5E29> /usr/lib/libresolv.9.dylib
0x7fff86b79000 - 0x7fff86b9afff com.apple.framework.Apple80211 (10.3 - 1030.71.6) <D3862426-2586-3DF7-BA75-9A184FCD74C4> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff87534000 - 0x7fff8753aff7 libsystem_networkextension.dylib (167.1.10) <29AB225B-D7FB-30ED-9600-65D44B9A9442> /usr/lib/system/libsystem_networkextension.dylib
0x7fff87550000 - 0x7fff8755ffff com.apple.LangAnalysis (1.7.0 - 1.7.0) <D1E527E4-C561-352F-9457-E8C50232793C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff877f8000 - 0x7fff87824fff com.apple.framework.SystemAdministration (1.0 - 1.0) <B427BF0A-36DC-357F-B807-1B1AA2AFB7BA> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff87825000 - 0x7fff8782bfff libsystem_trace.dylib (72.20.1) <840F5301-B55A-3078-90B9-FEFFD6CD741A> /usr/lib/system/libsystem_trace.dylib
0x7fff8782c000 - 0x7fff879bbfff libGLProgrammability.dylib (11.1.2) <E4FDCB86-E93C-36CC-B2EF-5FA0E96FF880> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff87a20000 - 0x7fff87a24fff com.apple.IOAccelerator (156.14 - 156.14) <5D593364-14AA-3DDA-96FE-B9CF4FE09143> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff87a25000 - 0x7fff87a2dfe7 libcldcpuengine.dylib (2.4.5) <0E9B5292-1EBC-379D-A706-83A27C05D742> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff87a6e000 - 0x7fff882aafe3 com.apple.CoreGraphics (1.600.0 - 779.11) <DC15AADD-387C-348E-84F0-1C8BAAB1B567> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff882ab000 - 0x7fff882abfff com.apple.ApplicationServices (48 - 48) <5BF7910B-C328-3BF8-BA4F-CE52B574CE01> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff882af000 - 0x7fff882b7ff3 com.apple.CoreServices.FSEvents (1210.20.1 - 1210.20.1) <84F79D3E-7B5E-3C93-8479-35794A3F125E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff882b8000 - 0x7fff883e8fff com.apple.UIFoundation (1.0 - 1) <466BDFA8-0B9F-3AB0-989D-F9779422926A> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff88423000 - 0x7fff884a1fff com.apple.CoreServices.OSServices (640.4 - 640.4) <20121A5E-7AB5-3624-8CF0-3562F97C8A95> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff884a2000 - 0x7fff884a4fff com.apple.CoreDuetDebugLogging (1.0 - 1) <9A6E5710-EA99-366E-BF40-9A65EC1B46A1> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff884dd000 - 0x7fff884e1fff libpam.2.dylib (20) <E805398D-9A92-31F8-8005-8DC188BD8B6E> /usr/lib/libpam.2.dylib
0x7fff884e2000 - 0x7fff884eaff7 com.apple.icloud.FindMyDevice (1.0 - 1) <9CE67F85-2BA8-3093-97BA-07BF5C04A5D6> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x7fff884f3000 - 0x7fff8850dff7 liblzma.5.dylib (7) <1D03E875-A7C0-3028-814C-3C27F7B7C079> /usr/lib/liblzma.5.dylib
0x7fff8850e000 - 0x7fff8854ffff libGLU.dylib (11.1.2) <4C54F0D1-2ADC-38A0-92D1-F479E9B99355> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff88550000 - 0x7fff8855dfff libxar.1.dylib (255) <7CD69BB5-97BA-3858-8A8B-2F33F129E6E7> /usr/lib/libxar.1.dylib
0x7fff8855e000 - 0x7fff8855efff com.apple.audio.units.AudioUnit (1.12 - 1.12) <E5335492-7EFE-31EA-BE72-4A9CEE68D58E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff8855f000 - 0x7fff88564ffb libheimdal-asn1.dylib (398.10.1) <A7B6447A-6680-3625-83C3-993B58D5C43F> /usr/lib/libheimdal-asn1.dylib
0x7fff88565000 - 0x7fff885f1ff7 libsystem_c.dylib (1044.10.1) <86FBED7A-F2C8-3591-AD6F-486DD57E6B6A> /usr/lib/system/libsystem_c.dylib
0x7fff885f2000 - 0x7fff885fdff7 libkxld.dylib (2782.20.48) <28EF8328-E3E2-336A-974B-FB1BF119D55A> /usr/lib/system/libkxld.dylib
0x7fff885fe000 - 0x7fff8861dfff com.apple.CoreDuet (1.0 - 1) <36AA9FD5-2685-314D-B364-3FA4688D86BD> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff889a6000 - 0x7fff889caff7 com.apple.Sharing (328.16 - 328.16) <F96C7040-5FAF-3BC6-AE1E-5BF9CBE786C4> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff889f0000 - 0x7fff88a66fe7 libcorecrypto.dylib (233.1.2) <E1789801-3985-3949-B736-6B3378873301> /usr/lib/system/libcorecrypto.dylib
0x7fff88a72000 - 0x7fff88c22ff3 com.apple.QuartzCore (1.10 - 361.18) <ACA61D8F-9535-3141-8FDD-AC3EF6BF0806> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff88cbd000 - 0x7fff88cd4ff7 libLinearAlgebra.dylib (1128) <E78CCBAA-A999-3B65-8EC9-06DB15E67C37> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff88cd5000 - 0x7fff88d00fff com.apple.DictionaryServices (1.2 - 229) <F03DFAC6-6285-3176-9C6D-7CC50F8CD52A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff88d67000 - 0x7fff88eadfef libsqlite3.dylib (168) <8B78BED1-7B9B-3943-80DC-0871015AEAC4> /usr/lib/libsqlite3.dylib
0x7fff88ebd000 - 0x7fff88ec6fff libGFXShared.dylib (11.1.2) <0BAF2EA8-3BC4-3BF4-ABB6-A6E0A1F3F6A5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff88ec7000 - 0x7fff89196ff3 com.apple.CoreImage (10.3.4) <C1AE8252-A95D-3BF4-83B8-BE85E979F2CB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff891c9000 - 0x7fff89237ffb com.apple.Heimdal (4.0 - 2.0) <7697A837-98B8-3BDB-A7D2-8ED4C9ABC510> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff894d6000 - 0x7fff89524fff libcurl.4.dylib (83.1.2) <462767FC-C7F2-39F1-8C10-DA4114945F55> /usr/lib/libcurl.4.dylib
0x7fff89525000 - 0x7fff89526ff7 com.apple.print.framework.Print (10.0 - 265) <3BC4FE7F-78A0-3E57-8F4C-520E7EFD36FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff89527000 - 0x7fff89829ffb com.apple.GeoServices (1.0 - 1077.0.18) <2BBF8B44-DD46-3432-8C84-6D6AA004C233> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff8982a000 - 0x7fff89891ffb com.apple.datadetectorscore (6.0 - 396.1.1) <9B0B3198-DDBE-36C0-8BA9-3EC89C725282> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff89892000 - 0x7fff89897fff libsystem_stats.dylib (163.20.16) <FBC3F80F-A0FB-3BD6-9A7E-800DE45F092E> /usr/lib/system/libsystem_stats.dylib
0x7fff89898000 - 0x7fff898b2ff7 libextension.dylib (55.2) <3BB019CA-199A-36AC-AA22-14B562138545> /usr/lib/libextension.dylib
0x7fff898b3000 - 0x7fff89bcefcf com.apple.vImage (8.0 - 8.0) <1183FE6A-FDB6-3B3B-928D-50C7909F2308> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff89d38000 - 0x7fff89d40ff7 com.apple.AppleSRP (5.0 - 1) <01EC5144-D09A-3D6A-AE35-F6D48585F154> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff89d41000 - 0x7fff89d8cfff com.apple.CloudDocs (1.0 - 321.6) <4C54EDB7-4377-3722-8C47-F3C3D260FCBA> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff89d90000 - 0x7fff89d9bff7 libcsfde.dylib (471.20.7) <44E51549-CECC-3C7B-867B-01901CA9C756> /usr/lib/libcsfde.dylib
0x7fff89d9c000 - 0x7fff89dcbff7 com.apple.CoreServicesInternal (221.7.2 - 221.7.2) <B93D4775-149C-3698-B38C-9C50673D455C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff89dcc000 - 0x7fff89dcdff3 libSystem.B.dylib (1213) <CCEC13A5-D0D9-31C5-B0B0-1C564B4A20A6> /usr/lib/libSystem.B.dylib
0x7fff89e66000 - 0x7fff89e66fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <9D749502-A228-3BF1-B52F-A182DEEB2C4D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff89e9d000 - 0x7fff89eb9ff7 libsystem_malloc.dylib (53.1.1) <19BCC257-5717-3502-A71F-95D65AFA861B> /usr/lib/system/libsystem_malloc.dylib
0x7fff89eba000 - 0x7fff89f4fff7 com.apple.ColorSync (4.9.0 - 4.9.0) <9150C2B7-2E6E-3509-96EA-7B3F959F049E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff89fab000 - 0x7fff89facff7 libsystem_blocks.dylib (65) <9615D10A-FCA7-3BE4-AA1A-1B195DACE1A1> /usr/lib/system/libsystem_blocks.dylib
0x7fff89ffc000 - 0x7fff8a008ff7 libGPUSupportMercury.dylib (11.1.2) <55BFDDBD-C196-3D24-A7DA-905A6A722DAC> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff8a29e000 - 0x7fff8a49846f libobjc.A.dylib (647) <759E155D-BC42-3D4E-869B-6F57D477177C> /usr/lib/libobjc.A.dylib
0x7fff8a4e9000 - 0x7fff8a6f6ff3 com.apple.CFNetwork (720.3.13 - 720.3.13) <69E15385-5784-3912-88F6-03B16F1C1A5C> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff8a839000 - 0x7fff8a8f9ff7 com.apple.backup.framework (1.6.4 - 1.6.4) <A67CE7D7-AAE4-3AC0-86B7-EAF403853D09> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff8a972000 - 0x7fff8a9bcff7 com.apple.HIServices (1.22 - 522.1) <E8BD41E4-7747-3CAF-807A-5CA9AD16B525> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff8ab53000 - 0x7fff8ab65ff7 com.apple.CoreDuetDaemonProtocol (1.0 - 1) <CE9FABB4-1C5D-3F9B-9BB8-5CC50C3E5E31> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff8abb4000 - 0x7fff8abbcfff libsystem_dnssd.dylib (561.1.1) <62B70ECA-E40D-3C63-896E-7F00EC386DDB> /usr/lib/system/libsystem_dnssd.dylib
0x7fff8abbd000 - 0x7fff8ac09fff com.apple.corelocation (1486.17 - 1615.24) <8825B3E2-E053-3E01-AE31-793443962D06> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff8ae93000 - 0x7fff8aec0fff com.apple.CoreVideo (1.8 - 145.1) <18DB07E0-B927-3260-A234-636F298D1917> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff8b120000 - 0x7fff8b125fff com.apple.DiskArbitration (2.6 - 2.6) <0DFF4D9B-2AC3-3B82-B5C5-30F4EFBD2DB9> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff8b126000 - 0x7fff8b131ff7 com.apple.CrashReporterSupport (10.10 - 631) <D87A64FA-64B1-3B23-BB43-ADE173C108C6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff8b132000 - 0x7fff8b162fff com.apple.GSS (4.0 - 2.0) <A37BAF76-C262-3292-B82D-F004CAC5F333> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff8b163000 - 0x7fff8b170ff3 com.apple.ProtocolBuffer (1 - 228.0.1) <3429EB06-9F0E-355F-B9AB-F72879177398> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff8b171000 - 0x7fff8b199fff libRIP.A.dylib (779.11) <88434DA0-B6B8-304A-9DC0-41D3947E8734> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff8b19a000 - 0x7fff8b1e7ff7 com.apple.print.framework.PrintCore (10.3 - 451.1) <DE992474-0841-38A1-B4F6-46D653E454D5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff8b1e8000 - 0x7fff8b1eaff7 libutil.dylib (38) <471AD65E-B86E-3C4A-8ABD-B8665A2BCE3F> /usr/lib/libutil.dylib
0x7fff8b1eb000 - 0x7fff8b211fff com.apple.ChunkingLibrary (2.1 - 163.6) <29D4CB95-42EF-34C6-8182-BDB6F7BB1E79> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff8b24a000 - 0x7fff8b24bfff liblangid.dylib (117) <B54A4AA0-2E53-3671-90F5-AFF711C0EB9E> /usr/lib/liblangid.dylib
0x7fff8b24c000 - 0x7fff8b24efff libquarantine.dylib (76.20.1) <7AF90041-2768-378A-925A-D83161863642> /usr/lib/system/libquarantine.dylib
0x7fff8b24f000 - 0x7fff8b2aafe7 libTIFF.dylib (1237) <6C8BBCA3-C233-3941-ACF9-F06C5E6EE2E6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff8b2ab000 - 0x7fff8bb33ff7 libclh.dylib (4.0.3 - 4.0.3) <6B7DEEBD-1784-3998-ABC2-8623B9E4F3EC> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x7fff8bb34000 - 0x7fff8bb50fff com.apple.GenerationalStorage (2.0 - 209.11) <9FF8DD11-25FB-3047-A5BF-9415339B3EEC> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff8bb64000 - 0x7fff8bb68fff com.apple.CommonPanels (1.2.6 - 96) <F9ECC8AF-D9CA-3350-AFB4-5113A9B789A5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff8bb69000 - 0x7fff8bc59fef libJP2.dylib (1237) <A24C99BF-2360-343F-BCA1-F044E78EA0DE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff8bc5a000 - 0x7fff8bc62ffb libcopyfile.dylib (118.1.2) <0C68D3A6-ACDD-3EF3-991A-CC82C32AB836> /usr/lib/system/libcopyfile.dylib
0x7fff8bc79000 - 0x7fff8bdb3fff com.apple.ImageIO.framework (3.3.0 - 1237) <3C06213D-847A-3C7B-843E-6EC37113965D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff8bdb4000 - 0x7fff8bdb5fff libDiagnosticMessagesClient.dylib (100) <2EE8E436-5CDC-34C5-9959-5BA218D507FB> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff8bde6000 - 0x7fff8be7afff com.apple.ink.framework (10.9 - 213) <8E029630-1530-3734-A446-13353F0E7AC5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff8be7b000 - 0x7fff8be7efff com.apple.xpc.ServiceManagement (1.0 - 1) <9E025823-660A-30C5-A568-223BD595B6F7> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff8bee5000 - 0x7fff8bf56ffb com.apple.ApplicationServices.ATS (360 - 375.2) <2338AF23-528F-359A-847F-8B04E49E2B84> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff8bf64000 - 0x7fff8bf8eff7 libdispatch.dylib (442.1.4) <502CF32B-669B-3709-8862-08188225E4F0> /usr/lib/system/libdispatch.dylib
0x7fff8c0c9000 - 0x7fff8c109ff7 libGLImage.dylib (11.1.2) <260A4BF3-DC45-369C-A0CD-B667F9D17179> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff8c10a000 - 0x7fff8c43bfff com.apple.Foundation (6.9 - 1153.20) <F0FF3A5D-C5B7-34A1-9319-DE1EF928E58E> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff8c53d000 - 0x7fff8c560ff7 com.apple.framework.familycontrols (4.1 - 410) <E491AFDB-2E12-37D0-B093-6E93091019C4> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff8c561000 - 0x7fff8c562fff com.apple.TrustEvaluationAgent (2.0 - 25) <2D61A2C3-C83E-3A3F-8EC1-736DBEC250AB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff8c563000 - 0x7fff8d0e4ff7 com.apple.AppKit (6.9 - 1347.57) <B214D528-7D1C-39B2-BE36-821D417A0297> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff8d0e5000 - 0x7fff8d194fe7 libvMisc.dylib (516) <6739E390-46E7-3BFA-9B69-B278562326E6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8d195000 - 0x7fff8d1c0ff3 libarchive.2.dylib (30) <8CBB4416-EBE9-3574-8ADC-44655D245F39> /usr/lib/libarchive.2.dylib
0x7fff8d1c6000 - 0x7fff8d1d0ff7 com.apple.NetAuth (5.2 - 5.2) <2BBD749A-8E18-35B8-8E48-A90347C1CCA7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8d1d1000 - 0x7fff8d1dcfff libGL.dylib (11.1.2) <BF99CC65-215A-3C7D-87D7-3F7EE6E9B3DD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff8d1dd000 - 0x7fff8d1e1fff libcache.dylib (69) <45E9A2E7-99C4-36B2-BEE3-0C4E11614AD1> /usr/lib/system/libcache.dylib
0x7fff8d1e2000 - 0x7fff8d1e9ff7 libcompiler_rt.dylib (35) <BF8FC133-EE10-3DA6-9B90-92039E28678F> /usr/lib/system/libcompiler_rt.dylib
0x7fff8d62c000 - 0x7fff8d654fff libsystem_info.dylib (459.20.1) <AEB3FE62-4763-3050-8352-D6F9AF961AE6> /usr/lib/system/libsystem_info.dylib
0x7fff8d66d000 - 0x7fff8d676fff libsystem_pthread.dylib (105.10.1) <3103AA7F-3BAE-3673-9649-47FFD7E15C97> /usr/lib/system/libsystem_pthread.dylib
0x7fff8d749000 - 0x7fff8d784fff com.apple.Symbolication (1.4 - 56045) <D64571B1-4483-3FE2-BD67-A91360F79727> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff8d8ed000 - 0x7fff8d8effff libsystem_configuration.dylib (699.1.5) <20F3B077-179D-3CB0-A3C1-C8602D53B4DB> /usr/lib/system/libsystem_configuration.dylib
0x7fff8de1f000 - 0x7fff8de38ff7 com.apple.CFOpenDirectory (10.10 - 187) <790ED527-EFD2-3EA6-8C97-A8C04E96EBA7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff8de39000 - 0x7fff8df2bfff libxml2.2.dylib (26) <B834E7C8-EC3E-3382-BC5A-DA38DC4D720C> /usr/lib/libxml2.2.dylib
0x7fff8e0d0000 - 0x7fff8e108fff libsystem_network.dylib (412.20.3) <589A5F67-BE2A-3245-A181-0ECC9B53EB00> /usr/lib/system/libsystem_network.dylib
0x7fff8e3b5000 - 0x7fff8e3e5fff libsystem_m.dylib (3086.1) <1E12AB45-6D96-36D0-A226-F24D9FB0D9D6> /usr/lib/system/libsystem_m.dylib
0x7fff8e3e6000 - 0x7fff8e400ff7 com.apple.Kerberos (3.0 - 1) <7760E0C2-A222-3709-B2A6-B692D900CEB1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff8e401000 - 0x7fff8e401ff7 liblaunch.dylib (559.20.9) <FA89A113-696E-3271-8FE1-A0D7324E8481> /usr/lib/system/liblaunch.dylib
0x7fff8e402000 - 0x7fff8e402ff7 libkeymgr.dylib (28) <77845842-DE70-3CC5-BD01-C3D14227CED5> /usr/lib/system/libkeymgr.dylib
0x7fff8e44c000 - 0x7fff8e498ff7 libcups.2.dylib (408.2) <E8AD18F9-61E4-3791-B840-504468C25556> /usr/lib/libcups.2.dylib
0x7fff8e499000 - 0x7fff8e49dfff com.apple.TCC (1.0 - 1) <CCA42EE2-3400-3444-9486-BC454E60D944> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff8e49e000 - 0x7fff8e4d8ffb com.apple.DebugSymbols (115 - 115) <6F03761D-7C3A-3C80-8031-AA1C1AD7C706> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff8e4d9000 - 0x7fff8e4e9ff7 libbsm.0.dylib (34) <A3A2E56C-2B65-37C7-B43A-A1F926E1A0BB> /usr/lib/libbsm.0.dylib
0x7fff8e4ee000 - 0x7fff8e501ff7 com.apple.CoreBluetooth (1.0 - 1) <8D7BA9BA-EB36-307A-9119-0B3D9732C953> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff8e502000 - 0x7fff8e52bffb libxslt.1.dylib (13) <AED1143F-B848-3E73-81ED-71356F25F084> /usr/lib/libxslt.1.dylib
0x7fff8e55f000 - 0x7fff8e570fff libsystem_coretls.dylib (35.20.2) <6084A531-2523-39F8-B030-811FA1A32FB5> /usr/lib/system/libsystem_coretls.dylib
0x7fff8e571000 - 0x7fff8e573fff libsystem_sandbox.dylib (358.20.5) <4CF77128-6BE0-3958-B646-707FA9CE61B2> /usr/lib/system/libsystem_sandbox.dylib
0x7fff8e5d1000 - 0x7fff8e5eefff libsystem_kernel.dylib (2782.20.48) <EAFD7BD0-0C30-3E7D-9528-F9916BA0167C> /usr/lib/system/libsystem_kernel.dylib
0x7fff8e5ef000 - 0x7fff8e626ffb com.apple.LDAPFramework (2.4.28 - 194.5) <CAFB9695-000F-34EA-8DF5-09996929C26A> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff8e627000 - 0x7fff8e62bfff libCoreVMClient.dylib (79.1) <201EF6DF-5074-3CB7-A361-398CF957A264> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff8e669000 - 0x7fff8e6afff7 libFontRegistry.dylib (134.1) <CE41D8C2-BEED-345C-BC4F-3775CC06C672> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff8e6b0000 - 0x7fff8e6e8fff com.apple.RemoteViewServices (2.0 - 99) <C9A62691-B0D9-34B7-B71C-A48B5F4DC553> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff8e6e9000 - 0x7fff8e70bfff libssl.0.9.7.dylib (106) <E23FBD0B-DFDB-30D2-B7EA-D6885610EBBA> /usr/lib/libssl.0.9.7.dylib
0x7fff8e70c000 - 0x7fff8e9f3ffb com.apple.CoreServices.CarbonCore (1108.6 - 1108.6) <8953580E-7857-33B2-AA64-98296830D3A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff8edcc000 - 0x7fff8eef4ff7 com.apple.coreui (2.1 - 308.6) <DEA5D3E1-D333-302B-A6CF-7643BFDFAED0> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff8eef5000 - 0x7fff8eef7ff7 com.apple.securityhi (9.0 - 55006) <5DB5773C-FC07-302C-98FE-4B80D88D481A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff8f40e000 - 0x7fff8f416fff libsystem_platform.dylib (63) <64E34079-D712-3D66-9CE2-418624A5C040> /usr/lib/system/libsystem_platform.dylib
0x7fff8fd5d000 - 0x7fff8fd5eff7 libodfde.dylib (22) <52D0ABCD-F464-362C-86EA-ACA10993F556> /usr/lib/libodfde.dylib
0x7fff8fd5f000 - 0x7fff8fd83fef libJPEG.dylib (1237) <6DB10054-5C64-32FB-83FD-E102A8F73258> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff8ffaf000 - 0x7fff900a3fff libFontParser.dylib (134.2) <9F57B025-AB9C-31DD-9D54-2D7AB1298885> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff900a4000 - 0x7fff900a7fff com.apple.IOSurface (97.4 - 97.4) <AE11CFBC-4D46-30F3-BEEC-4C8131079391> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff900a8000 - 0x7fff9010fff7 com.apple.framework.CoreWiFi (3.0 - 300.4) <19269C1D-EB29-384A-83F3-7DDDEB7D9DAD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff90110000 - 0x7fff90161fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <450293F7-DAE7-3DD0-8F7C-71FC2FD72627> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff90162000 - 0x7fff90467ff3 com.apple.HIToolbox (2.1.1 - 758.7) <6711FAA9-904A-3B49-9665-FC8D13B93C42> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff9055a000 - 0x7fff90669ff3 com.apple.desktopservices (1.9.3 - 1.9.3) <FEE11342-5BC4-37A7-8169-DA48BE17B9C9> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff9066a000 - 0x7fff906a5fff com.apple.QD (301 - 301) <C4D2AD03-B839-350A-AAF0-B4A08F8BED77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff90715000 - 0x7fff90730ff7 libCRFSuite.dylib (34) <D64842BE-7BD4-3D0C-9842-1D202F7C2A51> /usr/lib/libCRFSuite.dylib
0x7fff90731000 - 0x7fff90ac9ff7 com.apple.CoreFoundation (6.9 - 1153.18) <5C0892B8-9691-341F-9279-CA3A74D59AA0> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff90b37000 - 0x7fff90b3eff7 libCGCMS.A.dylib (779.11) <5D33FF8C-AC74-3B7B-A602-4AA470FEAF79> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0x7fff90b3f000 - 0x7fff90b99ff7 com.apple.LanguageModeling (1.0 - 1) <ACA93FE0-A0E3-333E-AE3C-8EB7DE5F362F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff90b9a000 - 0x7fff90c55ff7 com.apple.DiscRecording (9.0 - 9000.4.2) <4655B4B8-523D-3AE6-92A0-8486A2258B3B> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff90c56000 - 0x7fff90c63ff7 com.apple.SpeechRecognitionCore (2.1.2 - 2.1.2) <551322E2-C1E4-3378-A218-F362985E3E3C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff90c64000 - 0x7fff90c6bfff com.apple.NetFS (6.0 - 4.0) <1581D25F-CC07-39B0-90E8-5D4F3CF84EBA> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff90c83000 - 0x7fff90cefff3 com.apple.MMCS (1.3 - 327.5) <FC998246-ED60-334D-9E94-453F35EF9C78> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fff90cf0000 - 0x7fff90cf2ff7 libsystem_coreservices.dylib (9) <41B7C578-5A53-31C8-A96F-C73E030B0938> /usr/lib/system/libsystem_coreservices.dylib
0x7fff90cf3000 - 0x7fff90cfeff7 com.apple.DirectoryService.Framework (10.10 - 187) <85675744-B77D-37ED-805B-4BD0DD20845D> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff90cff000 - 0x7fff90d01fff com.apple.EFILogin (2.0 - 2) <3BA837D8-94F5-3240-9CF7-E40DC2808446> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff90d02000 - 0x7fff90e69ffb com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <5678FC94-456A-3F5F-BA9A-10EB6E462997> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff90e98000 - 0x7fff90e9afff com.apple.SecCodeWrapper (4.0 - 238.20.2) <C6C126F0-6BF4-3E29-A9B7-7BAD8D17EE4F> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff910b8000 - 0x7fff910b8fff com.apple.Carbon (154 - 157) <9BF51672-1684-3FDE-A561-FC59A2864EF8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff91249000 - 0x7fff91262ffb com.apple.openscripting (1.4 - 162.1) <E6B42781-A556-355A-8A49-82A8D2B347FF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff91263000 - 0x7fff914e2ff7 com.apple.CoreData (111 - 526.3) <5A27E0D8-5E5A-335B-B3F6-2601C7B976FA> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff91b4d000 - 0x7fff91b7fff3 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <C6DB0A07-F8E4-3837-BCA9-225F460EDA81> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff91b8a000 - 0x7fff91b9bff7 libz.1.dylib (55) <88C7C7DE-04B8-316F-8B74-ACD9F3DE1AA1> /usr/lib/libz.1.dylib
0x7fff91bf0000 - 0x7fff91c5cfff com.apple.framework.CoreWLAN (5.0 - 500.35.2) <5E228544-77A9-3AA5-8355-E8F6626F50E7> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff91c5d000 - 0x7fff91ccffff com.apple.framework.IOKit (2.0.2 - 1050.20.2) <09C0518C-90DF-3FC3-96D6-34D35F72C8EF> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff91cd0000 - 0x7fff91d66ff7 com.apple.cloudkit.CloudKit (283.67.2 - 283.67.2) <79F5AD38-61D5-30E6-96DC-974351D4195B> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff91d8f000 - 0x7fff91da5ff7 libsystem_asl.dylib (267) <F153AC5B-0542-356E-88C8-20A62CA704E2> /usr/lib/system/libsystem_asl.dylib
0x7fff91ddf000 - 0x7fff91df1ff7 com.apple.ImageCapture (9.0 - 9.0) <7FB65DD4-56B5-35C4-862C-7A2DED991D1F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff91f41000 - 0x7fff91f4fff7 com.apple.opengl (11.1.2 - 11.1.2) <864B35BF-1E76-382B-8D5F-38C7282621E6> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff92184000 - 0x7fff92195fff libcmph.dylib (1) <46EC3997-DB5E-38AE-BBBB-A035A54AD3C0> /usr/lib/libcmph.dylib
0x7fff921f2000 - 0x7fff921f6fff com.apple.LoginUICore (3.2 - 3.2) <417954C5-1675-31A8-9631-6B56E9AA3E93> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff921f7000 - 0x7fff921f8ffb libremovefile.dylib (35) <3485B5F4-6CE8-3C62-8DFD-8736ED6E8531> /usr/lib/system/libremovefile.dylib
0x7fff921f9000 - 0x7fff92205ff7 com.apple.OpenDirectory (10.10 - 187) <1E07769D-68DE-3BF2-8E9E-A1E98BF70D1B> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff92206000 - 0x7fff92220ff3 com.apple.Ubiquity (1.3 - 313) <DF56A657-CC6E-3BE2-86A0-71F07127724C> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x7fff92221000 - 0x7fff92223fff libCVMSPluginSupport.dylib (11.1.2) <6EFEC4A6-2EAC-3C27-820E-C28BE71B9FCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff92224000 - 0x7fff92224fff com.apple.CoreServices (62 - 62) <C69DA8A7-B536-34BF-A93F-1C170E2C6D58> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff9225c000 - 0x7fff92318ff7 libcrypto.0.9.7.dylib (106) <E0A293F8-0799-38DC-9ADA-1AD705EDD12B> /usr/lib/libcrypto.0.9.7.dylib
0x7fff9231d000 - 0x7fff9231ffff libRadiance.dylib (1237) <9B048776-53BB-3947-8ECE-9DDA804C86B2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff92320000 - 0x7fff9236fff7 libstdc++.6.dylib (104.1) <803F6AC8-87DC-3E24-9E80-729B551F6FFF> /usr/lib/libstdc++.6.dylib
0x7fff92370000 - 0x7fff9237bfff libcommonCrypto.dylib (60061) <D381EBC6-69D8-31D3-8084-5A80A32CB748> /usr/lib/system/libcommonCrypto.dylib
0x7fff9237c000 - 0x7fff9248eff7 libvDSP.dylib (516) <151B3CCB-77D3-3715-A3D0-7C74CD5C7FFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff924be000 - 0x7fff924dbfff com.apple.MultitouchSupport.framework (263.9.1 - 263.9.1) <6ABD3AE2-DF6A-3AB2-994B-9C0FB42CE2B7> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff934a3000 - 0x7fff934a9fff com.apple.speech.recognition.framework (5.0.9 - 5.0.9) <BB2D573F-0A01-379F-A2BA-3C454EDCB111> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff934aa000 - 0x7fff93509fff com.apple.AE (681.2 - 681.2) <181B3B06-2DC6-3E4D-B44A-2551C5E9CF6F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff9350a000 - 0x7fff9350bfff libsystem_secinit.dylib (18) <581DAD0F-6B63-3A48-B63B-917AF799ABAA> /usr/lib/system/libsystem_secinit.dylib
0x7fff93517000 - 0x7fff9356bfff libc++.1.dylib (120) <1B9530FD-989B-3174-BB1C-BDC159501710> /usr/lib/libc++.1.dylib
0x7fff9356c000 - 0x7fff9359dff7 com.apple.ProtectedCloudStorage (1.0 - 1) <D0903EA8-D861-3488-BCF5-9D8E7C6D01FA> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff9359e000 - 0x7fff935a3ff7 libunwind.dylib (35.3) <BE7E51A0-B6EA-3A54-9CCA-9D88F683A6D6> /usr/lib/system/libunwind.dylib
0x7fff935a4000 - 0x7fff935adff7 libsystem_notify.dylib (133.1.1) <61147800-F320-3DAA-850C-BADF33855F29> /usr/lib/system/libsystem_notify.dylib
0x7fff9363d000 - 0x7fff936acfff com.apple.SearchKit (1.4.0 - 1.4.0) <80883BD1-C9BA-3794-A20E-476F94DD89A9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff936dd000 - 0x7fff936e1ff7 libGIF.dylib (1237) <8A40FED5-FA90-3E76-A359-CD974C43A962> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff93746000 - 0x7fff9378cff7 libauto.dylib (186) <A260789B-D4D8-316A-9490-254767B8A5F1> /usr/lib/libauto.dylib
0x7fff938d2000 - 0x7fff93946ffb com.apple.securityfoundation (6.0 - 55126) <42589E18-D38C-3E25-B638-6E29740C224C> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff93947000 - 0x7fff93947fff com.apple.Cocoa (6.8 - 21) <EAC0EA1E-3C62-3B28-A941-5D8B1E085FF8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff939da000 - 0x7fff939e5fff com.apple.CommerceCore (1.0 - 376.24) <1B2B5206-43B6-3CA4-B057-8A7252CE6902> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff939e6000 - 0x7fff93a6afff com.apple.PerformanceAnalysis (1.0 - 1) <599AED3E-B689-3C40-8B91-93AD36C97658> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff93a99000 - 0x7fff93b7dfff libcrypto.0.9.8.dylib (52.20.2) <977DA067-2588-3BF8-A7B2-F08FC6E9088F> /usr/lib/libcrypto.0.9.8.dylib
0x7fff93b7e000 - 0x7fff93c1cfff com.apple.Metadata (10.7.0 - 917.35) <8CBD1D32-4F4B-3F9A-AC65-76F2B5376FBF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff93c3c000 - 0x7fff93c61fff libPng.dylib (1237) <F5652650-87ED-3D53-9E59-A897DFA41DD0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff93c62000 - 0x7fff93d54ff7 libiconv.2.dylib (42) <2A06D02F-8B76-3864-8D96-64EF5B40BC6C> /usr/lib/libiconv.2.dylib
0x7fff93d55000 - 0x7fff93dcdff7 com.apple.SystemConfiguration (1.14 - 1.14) <06A8405D-53BA-30A9-BA8A-222099176091> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff93ed7000 - 0x7fff93f79fff com.apple.Bluetooth (4.3.4 - 4.3.4f4) <A1120885-F31B-3C13-9B0D-2589F391CC7A> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff93f7a000 - 0x7fff94093ffb com.apple.CoreText (352.0 - 454.6) <D45790B0-E1A3-3C7D-8BA2-AB71D2CFA7FB> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff94181000 - 0x7fff941a9fff libxpc.dylib (559.20.9) <D35D0DB2-D7BD-3BE4-8378-062BFE545E1D> /usr/lib/system/libxpc.dylib
0x7fff941aa000 - 0x7fff941d4fff GLRendererFloat (11.1.2) <87953360-E0E4-3523-8EC3-2062C26C7FD2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff941d5000 - 0x7fff94200fff libc++abi.dylib (125) <88A22A0F-87C6-3002-BFBA-AC0F2808B8B9> /usr/lib/libc++abi.dylib
0x7fff94201000 - 0x7fff94203ffb libCGXType.A.dylib (779.11) <51607E77-F183-3CC2-A78C-238AFBDF6262> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff94204000 - 0x7fff94253ff7 com.apple.opencl (2.4.2 - 2.4.2) <4A9574ED-15CF-3EBB-B4C0-D30F644D6C74> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff94254000 - 0x7fff942ddff7 com.apple.CoreSymbolication (3.1 - 57020.1) <85707039-0C8A-3409-B0B5-153431CC1841> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff942de000 - 0x7fff9470efff com.apple.vision.FaceCore (3.1.6 - 3.1.6) <C3B823AA-C261-37D3-B4AC-C59CE91C8241> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff9470f000 - 0x7fff94a42ff7 libmecabra.dylib (666.7) <0ED8AE5E-7A5B-34A6-A2EE-2B852E60E1E2> /usr/lib/libmecabra.dylib
0x7fff94a43000 - 0x7fff94a4eff7 com.apple.speech.synthesis.framework (5.3.3 - 5.3.3) <A5640275-E2A6-3856-95EF-5F0DC440B10C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff94a58000 - 0x7fff94e65ff7 libLAPACK.dylib (1128) <F9201AE7-B031-36DB-BCF8-971E994EF7C1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff94ea2000 - 0x7fff94eafff7 libbz2.1.0.dylib (36) <2DF83FBC-5C08-39E1-94F5-C28653791B5F> /usr/lib/libbz2.1.0.dylib
0x7fff94eb0000 - 0x7fff9511aff7 com.apple.security (7.0 - 57031.20.26) <6568520A-587D-3167-BB79-60CE6FEADC64> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff953e7000 - 0x7fff95486e27 com.apple.AppleJPEG (1.0 - 1) <6627DDD9-A8FE-3968-B23A-B6A29AA3919A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff95487000 - 0x7fff9566cff7 libicucore.A.dylib (531.48) <3CD34752-B1F9-31D2-865D-B5B0F0BE3111> /usr/lib/libicucore.A.dylib
0x7fff9566d000 - 0x7fff95670fff com.apple.help (1.3.3 - 46) <CA4541F4-CEF5-355C-8F1F-EA65DC1B400F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff95671000 - 0x7fff95686ff7 com.apple.AppContainer (4.0 - 238.20.2) <2AA2EF49-9F38-31F6-8B08-8CC7C26F57F3> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 5
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 2380
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=250.5M resident=164.1M(66%) swapped_out_or_unallocated=86.4M(34%)
Writable regions: Total=8.4G written=3.8G(45%) resident=5.7G(67%) swapped_out=0K(0%) unallocated=2.8G(33%)
REGION TYPE VIRTUAL
Activity Tracing 2048K
CG backing stores 15.4M
CG image 12K
CG shared images 240K
CoreImage 8K
CoreUI image data 44K
IOKit 1.6G
Kernel Alloc Once 8K
MALLOC 4.6G
MALLOC (admin) 32K
MALLOC_LARGE (reserved) 75.0M reserved VM address space (unallocated)
Memory Tag 242 12K
Memory Tag 249 156K
OpenCL 16K
OpenGL GLSL 256K
STACK GUARD 56.1M
Stack 17.7M
VM_ALLOCATE 2.1G
__DATA 58.4M
__GLSLBUILTINS 2588K
__IMAGE 528K
__LINKEDIT 86.9M
__TEXT 163.6M
__UNICODE 552K
mapped file 71.8M
shared memory 196K
TOTAL 8.8G
TOTAL, minus reserved VM space 8.8G
Model: iMac14,2, BootROM IM142.0118.B09, 4 processors, Intel Core i7, 3.5 GHz, 32 GB, SMC 2.15f7
Graphics: NVIDIA GeForce GTX 780M, NVIDIA GeForce GTX 780M, PCIe, 4096 MB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x111), Broadcom BCM43xx 1.0 (7.15.166.24.3)
Bluetooth: Version 4.3.4f4 15601, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD ST3000DM001, 3 TB
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple USB SuperDrive
USB Device: USB2.0 Hub
Thunderbolt Bus: iMac, Apple Inc., 23.10
just looked at the messages contact me email so we can set up everything need instructions on how to setup Skype I do have builtin iMessages for apple computer so Skype should be easy. will be standing by to here from you and will research the how to Skype ...
captbullett@gmail.com
SASL ERROR: Error drawing panel: [string "/Users/brianhelip/Desktop/X-Plane 10/Aircraft..."]:0: attempt to index a nil valueJ.A.Romanov wrote:Now, we have not result for mac. We understand what some wrong happen with memory, but not understand well what problem exactly.
www.skype.com and Download it for MAC, very easy. Really!
