yes it is
Hello JAR team, so the 330 version 1.1b6 caused on my Mac 10.10.4 and Xplane 10:36 already at the start of the program to crash. Are there any plans for updates or solutions? Greetings to Moscow - Klaus
53 (edited by captbullett 2015-06-01 14:47:03)
as of today every time I open the A330 to run the aircraft it CTD and here is the information I can't tell if it is Gizmo causing the issue or not so I am including the log.txt from it as well. this is what I see a an potential issue //* Gizmo64: warng: ERROR: boot script not found. //
again happy to help
Attachment icon bbox_log.txt 229 b, 338 downloads since 2015-06-01
I updated Xplane on my IMac to 10.36 and Xplane CTD. Went back to 10.35 and loaded latest version of the A330. Three hour flight tonight and no crash. However Gizmo disabled.
Hi Jar,
I just want to inform you that 1.1b5.2 is quite stable if I disable Gizmo plugin on my Mac.
Alessandro
iMac 27" -14. 16 GB RAM, 512 GB SSD, GPU nVidia 775m, CPU i5.
xPlane 10.36 (udated yesterday).
OSx Yosemite latest update.
After installing and successfull activation of the plane, CTD. On xPlane restart, immediate CTD during simulator loading. I will try attaching a logfile later this evening.
Thanks for all the hard work!
thanks for reports!
58 (edited by emha 2015-06-03 12:22:14)
After many testflights i think the ctd's in my case are a result of real whether.
When i fly without real whether, there are no ctd's yet.
Maybe you can Check in this direction?!
59
How do I upload the log.txt file? I only see the "upload images" button...
Choose for "Post Reply" (right under the last post); that gives you the option to upload files ...
61 (edited by captbullett 2015-06-04 16:20:45)
good day,
I thought I would share this correspondence with you so everyone can see just what is going on and stop the guessing. and this is related to the last CTD I had which is posted on this page. post # 53
Brian.
This message indicates that Gizmo64 was unable to find a "commercial product" key file.
It is in no way related to your SASL problems.
If you want to be sure, remove Gizmo64.plugin from your plugins folder and test to see if the A330 still crashes.
You have several other plugins installed too. Any of these could be the source of problems.
It does seem that the A330 is problematic for a large number of users, all with different computers and configs.
While SASL and the A330 are not my products or my problem I do know this:
The problem is being actively investigated with help from Laminar.
Laminar are adding features to the sim that will help ALL plugin authors protect their memory resources from being trampled by other plugins and even the sim itself.
In time, with both sim and plugin updates, this will allow us to know exactly where the problem is with any existing and future plugin conflicts.
Ben R
Note: One,
I just went to the "plugin manager" and turned off the Gismo plugin, along with MaxxFX since MaxxFX uses the Gismo plugin.
Nevertheless, I will not know if this will help until I run some flights and test the set-up.
Additionally, I turned off the plug-in, PythonInterface, SeaTrafic V1.10, Ground Traffic v1.50 LFNL , Ground Traffic v1.50 KRNO,
Ground Traffic v1.50 KPNX, and Ground Traffic v1.50 LOWI.
The plugins that I left on:
CustomSBDatarefs004 , DataRefEditor , EZPushback 0.3.2 (mac) , autoGate v1.60, and Airport-Navigator v1.3.0
Also the A330 plugins are being used.
62 (edited by TDPlane 2015-06-04 16:48:52)
@ El Capitano Brian,
If you want to give the plugin-hypothesis a real test (Ben's suggestion), you should remove them all together from your setup. It's not necessary to delete them; just move them out of your X-Plane folder and restart the simulator. Using the plugin manager within X-Plane could mean you're too late ... Been there done that ...
Theo.
PS
Get well soon ...
63 (edited by captbullett 2015-06-04 18:31:02)
yes you are quite right but I have removed them also and still had the CTD's but that was with the A350 FF so I was not convinced that by removing the plugin does anymore good that just turning them off and testing first, and then going to the next step and removing them.
I also found while I was working on the issue I was not in the right Nav data cycle I was 1505 and not 1506r2 so I will finish the flight that I am working on and continue the process on the next CTD I will remove the Gismo plugin and the MaxxFX since the  MaxxFX is dependent on the Gismo Plugin.
[I have screened shot the settings and the power that the XP app is using to help in the setting for mac]
and what are "Tail Strikes" ? the Developers Console in Screen shot #5 will show a line of code about a "tail strike" and the fowling is the message:
//*  sound3d play sample->tail strike.wave // this is when the issues happen...
Thank-you for your feed back it is most welcomed in my world, I need to see the forest for the trees.
Theo.
PS
Get well soon ...
Attachment icon Screen Shot 2015-06-04 at 12.39.39 PM.png 679.21 kb, 128 downloads since 2015-06-04
Attachment icon Screen Shot 2015-06-04 at 2.07.20 PM.png 65.24 kb, 132 downloads since 2015-06-04
Attachment icon Screen Shot 2015-06-04 at 2.07.31 PM.jpg 49.97 kb, 128 downloads since 2015-06-04
Attachment icon Screen Shot 2015-06-04 at 2.07.48 PM.jpg 78.05 kb, 124 downloads since 2015-06-04
Attachment icon Screen Shot 2015-06-04 at 2.08.58 PM.jpg 114.3 kb, 128 downloads since 2015-06-04
64
Flight from EIDW to KJFK.  Didn't follow route for a large part of the journey.  This may have been due to Route Discontinuity which I though't I'd fixed as was showing as a continuous route and also removed the Route Discontinuity message from the Flight Plan.
X-Plane crashed when I was just about to intercept the localiser at JFK - 6 hours down the drain.
Theo.
PS
Get well soon ...
Now, we have not result for mac. We understand what some wrong happen with memory, but not understand well what problem exactly.
You have installed 5-6 other plugins. Noone can understand what reason for CTD for this setup. The last words was
DEF load time: 2892 for water.
DEF load time: 2901 for water.
DEF load time: 2840 for water.
DEF load time: 2934 for water.
DEF load time: 2858 for water.
DEF load time: 2913 for water.
DEF load time: 2842 for water.
DEF load time: 2893 for water.
DEF load time: 3034 for water.
DEF load time: 2922 for water.
DEF load time: 2947 for water.
It is nor airbus 100% smile
67
Thanks JAR.  I'll take out some of the plugins and see if it improves.
68
Tried a flight from KBOS to KJFK with all plugins bar the JARDesign ones and Autogate removed.  It crased in the exact same place just as it was intercepting the localiser.  However, this time it crashed the PC.
Looks like an SASL issue?
As per the letter I removed all the plugins and the issue became even more clear Here is the issue that I have been aware of and always thought was the underlying issue and until they fix there will be issues ... I cannot say it any way else I saw the issue with the A350 by FF when I was testing it and the issue was the Sasl plugin I am not trying to be mean but when you take everything away this is the issue just like (Ben's suggestion removing the plugin shows that the issue is in the Sasl plugin it's self) . I am sending the log txt just to look at ... I only meant to download one log txt but the system is playing tricks... and bbox so you can see everything else.. if you need any thing else let me know..
SASL ERROR: Error drawing panel: [string "/Users/brianhelip/Desktop/X-Plane 10/Aircraft..."]:0: attempt to index a nil value
Theo.
PS
Get well soon ...
This is SASL error. How can I repeat this situation?
71
If this can be repeated - we have 2 way -
- need description what need to do to repeate this (i need get the same on my computer, course i have a debugger log, not the same as at user computer)
- contact with Skype and repeat this together using share screen mode
72
Should be pretty straight forward.  It was using standard X-Plane scenery with only Autogate and Airport Navigator plugins.
73
Imac crashed straight after registration!
rocess:               X-Plane [543]
Path:                  /Applications/X-Plane 10/X-Plane.app/Contents/MacOS/X-Plane
Identifier:            com.laminar_research.X-Plane
Version:               10.35r1 (398)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           X-Plane [543]
User ID:               501
Date/Time:             2015-06-05 20:27:39.552 +0930
OS Version:            Mac OS X 10.10.3 (14D136)
Report Version:        11
Anonymous UUID:        715E3FF0-47F5-4FE6-5B19-D11C4CACA2C5
Time Awake Since Boot: 7400 seconds
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x000000022719a28c
VM Regions Near 0x22719a28c:
    MALLOC_SMALL           0000000186800000-0000000188000000 [ 24.0M] rw-/rwx SM=PRV
    __TEXT                 0000123440000000-0000123440865000 [ 8596K] r-x/rwx SM=COW  /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   mac.xpl                           0x0000000084d832b0 lj_tab_get + 48
1   mac.xpl                           0x0000000084d8c033 lua_rawget + 195
2   mac.xpl                           0x0000000084d65b85 getGlobalPanelValue(char const*, int) + 85
3   mac.xpl                           0x0000000084d655c5 xap::reloadPanel(bool) + 1029
4   mac.xpl                           0x0000000084d664ad XPluginEnable + 461
5   XPLM                              0x000000007f128231 XPLMEnablePlugin + 139
6   XPLM                              0x000000007f128339 XPLMEnableACFPlugins() + 37
7   XPLM                              0x000000007f12785b XPLMEventHook + 361
8   com.laminar_research.X-Plane      0x000000010022c929 XPPEventHook(int, float, float, long, long) + 137
9   com.laminar_research.X-Plane      0x0000000100bd4ca3 veh_class::IO_veh(int) + 1187
10  com.laminar_research.X-Plane      0x000000010063a6bd veh_class::load_veh(int, int) + 1533
11  com.laminar_research.X-Plane      0x0000000100ae19f6 APP_handlemenu(int) + 3638
12  com.laminar_research.X-Plane      0x0000000100ad10cb mbar_class::mbar_select_an_item() + 619
13  com.laminar_research.X-Plane      0x0000000100ad1908 mbar_class::mbar_select_an_item_click() + 1048
14  com.laminar_research.X-Plane      0x0000000100b24ba8 MACIBM_handle_click(int) + 24
15  com.apple.AppKit                  0x00007fff8cd342fc -[NSWindow _reallySendEvent:isDelayedEvent:] + 14125
16  com.apple.AppKit                  0x00007fff8c6c3d76 -[NSWindow sendEvent:] + 470
17  com.apple.AppKit                  0x00007fff8c6c0312 -[NSApplication sendEvent:] + 2504
18  com.laminar_research.X-Plane      0x000000010039d2a4 WIN_event_loop_once + 340
19  com.laminar_research.X-Plane      0x0000000100c793cb WIN_run_app + 43
20  com.laminar_research.X-Plane      0x000000010061d053 main + 1075
21  com.laminar_research.X-Plane      0x00000001004918c0 start + 52
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib            0x00007fff8e5e8232 kevent64 + 10
1   libdispatch.dylib                 0x00007fff8bf68a6a _dispatch_mgr_thread + 52
Thread 2:
0   libsystem_kernel.dylib            0x00007fff8e5e251a semaphore_wait_trap + 10
1   com.laminar_research.X-Plane      0x0000000100104bff UTL_platform_semaphore_dec(UTL_semaphore*, int) + 159
2   com.laminar_research.X-Plane      0x0000000100104e4c UTL_semaphore_dec(UTL_semaphore*, int) + 140
3   com.laminar_research.X-Plane      0x00000001001ded0d UTL_pool_task* UTL_message_queue_read<UTL_pool_task*>(UTL_message_queue<UTL_pool_task*>*, int) + 45
4   com.laminar_research.X-Plane      0x00000001007d9c5c UTL_threadpool::thread_func(void*) + 60
5   com.laminar_research.X-Plane      0x00000001005f03b5 THREAD_launch(void*) + 69
6   libsystem_pthread.dylib           0x00007fff8d670268 _pthread_body + 131
7   libsystem_pthread.dylib           0x00007fff8d6701e5 _pthread_start + 176
8   libsystem_pthread.dylib           0x00007fff8d66e41d thread_start + 13
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:: com.apple.audio.IOThread.client
0   libsystem_kernel.dylib            0x00007fff8e5e24de mach_msg_trap + 10
1   libsystem_kernel.dylib            0x00007fff8e5e164f mach_msg + 55
2   com.apple.audio.CoreAudio         0x00007fff9013b57e HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 98
3   com.apple.audio.CoreAudio         0x00007fff9013b50c HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4   com.apple.audio.CoreAudio         0x00007fff90139aa9 HALC_ProxyIOContext::IOWorkLoop() + 965
5   com.apple.audio.CoreAudio         0x00007fff90139612 HALC_ProxyIOContext::IOThreadEntry(void*) + 88
6   com.apple.audio.CoreAudio         0x00007fff901394e3 HALB_IOThread::Entry(void*) + 157
7   libsystem_pthread.dylib           0x00007fff8d670268 _pthread_body + 131
8   libsystem_pthread.dylib           0x00007fff8d6701e5 _pthread_start + 176
9   libsystem_pthread.dylib           0x00007fff8d66e41d thread_start + 13
Thread 10:
0   libsystem_kernel.dylib            0x00007fff8e5e748a __semwait_signal + 10
1   libsystem_c.dylib                 0x00007fff885e3e50 usleep + 54
2   mac.xpl                           0x000000007f1e8197 gizmo_thread_sleep(int) + 23
3   mac.xpl                           0x000000007f1e8168 gizmo_pthreads_DoCurlTransfer(void*) + 1368
4   libsystem_pthread.dylib           0x00007fff8d670268 _pthread_body + 131
5   libsystem_pthread.dylib           0x00007fff8d6701e5 _pthread_start + 176
6   libsystem_pthread.dylib           0x00007fff8d66e41d thread_start + 13
Thread 11:
2   mac.xpl                           0x000000007f1c09e7 gizmo_pthreads_Mapping_TerrainBake(void*) + 871
3   libsystem_pthread.dylib           0x00007fff8d670268 _pthread_body + 131
4   libsystem_pthread.dylib           0x00007fff8d6701e5 _pthread_start + 176
5   libsystem_pthread.dylib           0x00007fff8d66e41d thread_start + 13
Thread 12:
0   libsystem_kernel.dylib            0x00007fff8e5e2532 semaphore_timedwait_trap + 10
1   com.laminar_research.X-Plane      0x0000000100104bad UTL_platform_semaphore_dec(UTL_semaphore*, int) + 77
2   com.laminar_research.X-Plane      0x0000000100104e21 UTL_semaphore_dec(UTL_semaphore*, int) + 97
3   com.laminar_research.X-Plane      0x000000010010145d void* UTL_message_queue_read<void*>(UTL_message_queue<void*>*, int) + 45
4   com.laminar_research.X-Plane      0x00000001007cb0c7 run_g1000_g430_thread(void*) + 375
Thread 13:
0   libsystem_kernel.dylib            0x00007fff8e5e794a __workq_kernreturn + 10
1   libsystem_pthread.dylib           0x00007fff8d66e40d start_wqthread + 13
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x000000007f11f680  rbx: 0x000000022719a280  rcx: 0x0000000017136f80  rdx: 0x000000004200c660
  rdi: 0x0000000017120380  rsi: 0x0000000017127240  rbp: 0x00007fff5fbfb7b0  rsp: 0x00007fff5fbfb760
   r8: 0x643268746469576c   r9: 0x000000007f11f6a0  r10: 0x000000010197f200  r11: 0xfffffffffa2f7392
  r12: 0x0000000000000008  r13: 0x0000000000a10d00  r14: 0x0000000017120380  r15: 0x000000001cf31da0
  rip: 0x0000000084d832b0  rfl: 0x0000000000010202  cr2: 0x000000022719a28c
Logical CPU:     6
Error Code:      0x00000004
Trap Number:     14
Binary Images:
           0x10000 -            0x36ff7  com.apple.audio.OpenAL (1.8 - 1.8) <B05578A8-FE08-310C-BF91-C1BDE10858CD> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
           0x48000 -            0x4cfff  com.apple.agl (3.3.0 - AGL-3.3.0) <83B4076C-BD87-3436-B59F-65184128FEC1> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
           0x53000 -            0x55fff  com.apple.ForceFeedback (1.0.6 - 1.0.6) <A411AA46-5DB6-3C6C-B4B4-613EC1EF33C3> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
           0x5a000 -            0x61fff +com.googlecode.google-breakpad (1.0) <D40F69E5-0F60-C476-668A-E1CB9B0DFA6F> /Applications/X-Plane 10/X-Plane.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad
           0x6d000 -            0x7efe7 +breakpadUtilities.dylib (1) <0B629D05-BC04-EB6D-7D62-1D108165D719> /Applications/X-Plane 10/X-Plane.app/Contents/Frameworks/Breakpad.framework/Resources/breakpadUtilities.dylib
          0x7fc000 -           0x7fcff5 +cl_kernels (???) <CCF8CF59-B8D9-47F6-9F14-55FC3AEDCEA5> cl_kernels
         0x9479000 -          0x9479fef +cl_kernels (???) <EB6D6F44-5361-4B32-83CC-90C922F4DF27> cl_kernels
         0xb696000 -          0xb77cfef  unorm8_bgra.dylib (2.4.5) <7BFE1DA8-2BE4-3B4F-8A7F-F3D6D4D36ADA> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
         0xe42d000 -          0xe64aff3  com.apple.audio.units.Components (1.12 - 1.12) <AC14ADC7-587F-3E0F-92E7-9D8C07753C22> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
         0xe706000 -          0xe70afff  com.apple.audio.AppleHDAHALPlugIn (272.18 - 272.18) <BCBCD7EE-C5ED-3558-8176-70BFC88925B1> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
        0x1283a000 -         0x12847fe7 +mac.xpl (???) <DAE0B9E8-C065-A86F-83F1-229764492248> /Applications/X-Plane 10/*/mac.xpl
        0x12c6a000 -         0x12c83ff7 +mac.xpl (0) <A6C2A760-5D66-3DBD-BFBD-9B97FC40B517> /Applications/X-Plane 10/*/mac.xpl
        0x15dc3000 -         0x15dc9fff +mac.xpl (0) <D5511E70-ED6C-361B-B713-CBE44AE0FE3F> /Applications/X-Plane 10/*/mac.xpl
        0x15ef4000 -         0x15ef9ff7 +mac.xpl (???) <99D8A359-C98D-1DE2-A234-1B2100D777BB> /Applications/X-Plane 10/*/mac.xpl
        0x7f120000 -         0x7f141ff7 +XPLM (1) <B497C673-ADC9-CC40-FCC7-57ADA1831586> /Applications/X-Plane 10/*/XPLM.framework/XPLM
        0x7f15a000 -         0x7f164fff +XPWidgets (1) <D70FDCF2-B986-53CA-8E7F-5068206957BF> /Applications/X-Plane 10/*/XPWidgets.framework/XPWidgets
        0x7f16c000 -         0x7f556fe7 +mac.xpl (0) <B6298CA1-228E-3987-93C1-45DDB927368B> /Applications/X-Plane 10/*/Gizmo64.plugin/64/mac.xpl
        0x7fa2f000 -         0x7fa6dfef +libcurl (6.1) <2CFAC41E-2634-9196-90A7-9A5084C91FC3> /Users/USER/Library/Frameworks/libcurl.framework/Versions/A/libcurl
        0x818d9000 -         0x819c9fff +mac.xpl (???) <B020D7F6-D6B6-37F7-AC5F-0B01A6EA8DBA> /Applications/X-Plane 10/*/mac.xpl
        0x83cb6000 -         0x83cbcff7 +mac.xpl (0) <D22D47AC-FD7E-347A-8FB8-A1061778986F> /Applications/X-Plane 10/*/mac.xpl
        0x84439000 -         0x84444ff7 +mac.xpl (0) <27C45F74-FBC4-31CF-B6E3-204C0222C010> /Applications/X-Plane 10/*/mac.xpl
        0x84d54000 -         0x84e5dff7 +mac.xpl (0) <D3769C84-9589-3DCA-AB8A-E1600FDE40E7> /Applications/X-Plane 10/*/mac.xpl
        0x86def000 -         0x86dfafff  com.apple.iokit.IOHIDLib (2.0.0 - 2.0.0) <F02FEFEC-1005-3DBC-919E-3BD31B273684> /System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib
        0x87c24000 -         0x87c2ffe7 +mac.xpl (???) <DF8FA97C-AB36-4C13-D94B-EEA1CCEA24FB> /Applications/X-Plane 10/*/mac.xpl
        0x87c34000 -         0x87c41fe7 +mac.xpl (???) <DAE0B9E8-C065-A86F-83F1-229764492248> /Applications/X-Plane 10/*/mac.xpl
       0x100000000 -        0x1014b5fcf +com.laminar_research.X-Plane (10.35r1 - 398) <FEF96756-B25C-F035-1FD6-82E0C8F6BE2D> /Applications/X-Plane 10/X-Plane.app/Contents/MacOS/X-Plane
    0x123440000000 -     0x123440864ff7  com.apple.GeForceGLDriver (10.2.7 - 10.0.2) <0C5B7449-911C-35A0-8BC8-03FA1ADEB670> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
    0x7fff68fce000 -     0x7fff69004837  dyld (353.2.1) <65DCCB06-339C-3E25-9702-600A28291D0E> /usr/lib/dyld
    0x7fff85b9f000 -     0x7fff85c75ff3  com.apple.DiskImagesFramework (10.10.1 - 396) <1149D3E1-CC6C-3177-916D-2BE066DC9344> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fff85c8c000 -     0x7fff85e1afff  libBLAS.dylib (1128) <497912C1-A98E-3281-BED7-E9C751552F61> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff85e1e000 -     0x7fff85e1eff7  libunc.dylib (29) <5676F7EA-C1DF-329F-B006-D2C3022B7D70> /usr/lib/system/libunc.dylib
    0x7fff85ee0000 -     0x7fff85ee0fff  libOpenScriptingUtil.dylib (162.1) <E0605012-0DDB-3150-8FD0-699376FA3CD0> /usr/lib/libOpenScriptingUtil.dylib
    0x7fff85eee000 -     0x7fff85f21fff  com.apple.MediaKit (16 - 757.2) <2912E5C2-085F-3FE2-8531-23B6E894B0F0> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff85f22000 -     0x7fff85fb3ff7  libCoreStorage.dylib (471.20.7) <ECD8903C-F131-3A9A-BBF4-E124DA028909> /usr/lib/libCoreStorage.dylib
    0x7fff86093000 -     0x7fff86096ff7  libdyld.dylib (353.2.1) <9EACCA38-291D-38CC-811F-7E9D1451E2D3> /usr/lib/system/libdyld.dylib
    0x7fff86097000 -     0x7fff86099fff  com.apple.loginsupport (1.0 - 1) <DAAD7013-A19D-3858-BFF7-DE1DAF664401> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff860a5000 -     0x7fff860a5fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <2C8AF258-4F11-3BEC-A826-22D7199B3975> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff8621f000 -     0x7fff86228ff3  com.apple.CommonAuth (4.0 - 2.0) <BA9F5A09-D200-3D18-9F4A-20C789291A30> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff86229000 -     0x7fff8622eff7  libmacho.dylib (862) <126CA2ED-DE91-308F-8881-B9DAEC3C63B6> /usr/lib/system/libmacho.dylib
    0x7fff8622f000 -     0x7fff86249fff  com.apple.AppleVPAFramework (1.4.4 - 1.4.4) <5C37DBD3-EB91-3A58-BD2F-E0CD533DE467> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
    0x7fff8682e000 -     0x7fff8684efff  com.apple.IconServices (47.1 - 47.1) <E83DFE3B-6541-3736-96BB-26DC5D0100F1> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff86873000 -     0x7fff86885ff7  libsasl2.2.dylib (194.1) <35371406-75EF-304A-A073-956C40373555> /usr/lib/libsasl2.2.dylib
    0x7fff86886000 -     0x7fff86a35fff  GLEngine (11.1.2) <68FDFD73-F15C-3460-9984-10F5DEF79907> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fff86a36000 -     0x7fff86b5aff7  com.apple.LaunchServices (644.56 - 644.56) <20AABB1C-9319-3E4D-A024-51B0DD5FCD3B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff86b5b000 -     0x7fff86b78ffb  libresolv.9.dylib (57) <26B38E61-298A-3C3A-82C1-3B5E98AD5E29> /usr/lib/libresolv.9.dylib
    0x7fff86b79000 -     0x7fff86b9afff  com.apple.framework.Apple80211 (10.3 - 1030.71.6) <D3862426-2586-3DF7-BA75-9A184FCD74C4> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff87534000 -     0x7fff8753aff7  libsystem_networkextension.dylib (167.1.10) <29AB225B-D7FB-30ED-9600-65D44B9A9442> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff87550000 -     0x7fff8755ffff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <D1E527E4-C561-352F-9457-E8C50232793C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff877f8000 -     0x7fff87824fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <B427BF0A-36DC-357F-B807-1B1AA2AFB7BA> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
    0x7fff87825000 -     0x7fff8782bfff  libsystem_trace.dylib (72.20.1) <840F5301-B55A-3078-90B9-FEFFD6CD741A> /usr/lib/system/libsystem_trace.dylib
    0x7fff8782c000 -     0x7fff879bbfff  libGLProgrammability.dylib (11.1.2) <E4FDCB86-E93C-36CC-B2EF-5FA0E96FF880> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff87a20000 -     0x7fff87a24fff  com.apple.IOAccelerator (156.14 - 156.14) <5D593364-14AA-3DDA-96FE-B9CF4FE09143> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff87a25000 -     0x7fff87a2dfe7  libcldcpuengine.dylib (2.4.5) <0E9B5292-1EBC-379D-A706-83A27C05D742> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fff87a6e000 -     0x7fff882aafe3  com.apple.CoreGraphics (1.600.0 - 779.11) <DC15AADD-387C-348E-84F0-1C8BAAB1B567> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff882ab000 -     0x7fff882abfff  com.apple.ApplicationServices (48 - 48) <5BF7910B-C328-3BF8-BA4F-CE52B574CE01> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff882af000 -     0x7fff882b7ff3  com.apple.CoreServices.FSEvents (1210.20.1 - 1210.20.1) <84F79D3E-7B5E-3C93-8479-35794A3F125E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff882b8000 -     0x7fff883e8fff  com.apple.UIFoundation (1.0 - 1) <466BDFA8-0B9F-3AB0-989D-F9779422926A> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff88423000 -     0x7fff884a1fff  com.apple.CoreServices.OSServices (640.4 - 640.4) <20121A5E-7AB5-3624-8CF0-3562F97C8A95> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff884a2000 -     0x7fff884a4fff  com.apple.CoreDuetDebugLogging (1.0 - 1) <9A6E5710-EA99-366E-BF40-9A65EC1B46A1> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
    0x7fff884dd000 -     0x7fff884e1fff  libpam.2.dylib (20) <E805398D-9A92-31F8-8005-8DC188BD8B6E> /usr/lib/libpam.2.dylib
    0x7fff884e2000 -     0x7fff884eaff7  com.apple.icloud.FindMyDevice (1.0 - 1) <9CE67F85-2BA8-3093-97BA-07BF5C04A5D6> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
    0x7fff884f3000 -     0x7fff8850dff7  liblzma.5.dylib (7) <1D03E875-A7C0-3028-814C-3C27F7B7C079> /usr/lib/liblzma.5.dylib
    0x7fff8850e000 -     0x7fff8854ffff  libGLU.dylib (11.1.2) <4C54F0D1-2ADC-38A0-92D1-F479E9B99355> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff88550000 -     0x7fff8855dfff  libxar.1.dylib (255) <7CD69BB5-97BA-3858-8A8B-2F33F129E6E7> /usr/lib/libxar.1.dylib
    0x7fff8855e000 -     0x7fff8855efff  com.apple.audio.units.AudioUnit (1.12 - 1.12) <E5335492-7EFE-31EA-BE72-4A9CEE68D58E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff8855f000 -     0x7fff88564ffb  libheimdal-asn1.dylib (398.10.1) <A7B6447A-6680-3625-83C3-993B58D5C43F> /usr/lib/libheimdal-asn1.dylib
    0x7fff88565000 -     0x7fff885f1ff7  libsystem_c.dylib (1044.10.1) <86FBED7A-F2C8-3591-AD6F-486DD57E6B6A> /usr/lib/system/libsystem_c.dylib
    0x7fff885f2000 -     0x7fff885fdff7  libkxld.dylib (2782.20.48) <28EF8328-E3E2-336A-974B-FB1BF119D55A> /usr/lib/system/libkxld.dylib
    0x7fff885fe000 -     0x7fff8861dfff  com.apple.CoreDuet (1.0 - 1) <36AA9FD5-2685-314D-B364-3FA4688D86BD> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
    0x7fff889a6000 -     0x7fff889caff7  com.apple.Sharing (328.16 - 328.16) <F96C7040-5FAF-3BC6-AE1E-5BF9CBE786C4> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff889f0000 -     0x7fff88a66fe7  libcorecrypto.dylib (233.1.2) <E1789801-3985-3949-B736-6B3378873301> /usr/lib/system/libcorecrypto.dylib
    0x7fff88a72000 -     0x7fff88c22ff3  com.apple.QuartzCore (1.10 - 361.18) <ACA61D8F-9535-3141-8FDD-AC3EF6BF0806> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff88cbd000 -     0x7fff88cd4ff7  libLinearAlgebra.dylib (1128) <E78CCBAA-A999-3B65-8EC9-06DB15E67C37> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff88cd5000 -     0x7fff88d00fff  com.apple.DictionaryServices (1.2 - 229) <F03DFAC6-6285-3176-9C6D-7CC50F8CD52A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff88d67000 -     0x7fff88eadfef  libsqlite3.dylib (168) <8B78BED1-7B9B-3943-80DC-0871015AEAC4> /usr/lib/libsqlite3.dylib
    0x7fff88ebd000 -     0x7fff88ec6fff  libGFXShared.dylib (11.1.2) <0BAF2EA8-3BC4-3BF4-ABB6-A6E0A1F3F6A5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff88ec7000 -     0x7fff89196ff3  com.apple.CoreImage (10.3.4) <C1AE8252-A95D-3BF4-83B8-BE85E979F2CB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff891c9000 -     0x7fff89237ffb  com.apple.Heimdal (4.0 - 2.0) <7697A837-98B8-3BDB-A7D2-8ED4C9ABC510> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff894d6000 -     0x7fff89524fff  libcurl.4.dylib (83.1.2) <462767FC-C7F2-39F1-8C10-DA4114945F55> /usr/lib/libcurl.4.dylib
    0x7fff89525000 -     0x7fff89526ff7  com.apple.print.framework.Print (10.0 - 265) <3BC4FE7F-78A0-3E57-8F4C-520E7EFD36FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff89527000 -     0x7fff89829ffb  com.apple.GeoServices (1.0 - 1077.0.18) <2BBF8B44-DD46-3432-8C84-6D6AA004C233> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fff8982a000 -     0x7fff89891ffb  com.apple.datadetectorscore (6.0 - 396.1.1) <9B0B3198-DDBE-36C0-8BA9-3EC89C725282> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff89892000 -     0x7fff89897fff  libsystem_stats.dylib (163.20.16) <FBC3F80F-A0FB-3BD6-9A7E-800DE45F092E> /usr/lib/system/libsystem_stats.dylib
    0x7fff89898000 -     0x7fff898b2ff7  libextension.dylib (55.2) <3BB019CA-199A-36AC-AA22-14B562138545> /usr/lib/libextension.dylib
    0x7fff898b3000 -     0x7fff89bcefcf  com.apple.vImage (8.0 - 8.0) <1183FE6A-FDB6-3B3B-928D-50C7909F2308> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff89d38000 -     0x7fff89d40ff7  com.apple.AppleSRP (5.0 - 1) <01EC5144-D09A-3D6A-AE35-F6D48585F154> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff89d41000 -     0x7fff89d8cfff  com.apple.CloudDocs (1.0 - 321.6) <4C54EDB7-4377-3722-8C47-F3C3D260FCBA> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fff89d90000 -     0x7fff89d9bff7  libcsfde.dylib (471.20.7) <44E51549-CECC-3C7B-867B-01901CA9C756> /usr/lib/libcsfde.dylib
    0x7fff89d9c000 -     0x7fff89dcbff7  com.apple.CoreServicesInternal (221.7.2 - 221.7.2) <B93D4775-149C-3698-B38C-9C50673D455C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff89dcc000 -     0x7fff89dcdff3  libSystem.B.dylib (1213) <CCEC13A5-D0D9-31C5-B0B0-1C564B4A20A6> /usr/lib/libSystem.B.dylib
    0x7fff89e66000 -     0x7fff89e66fff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <9D749502-A228-3BF1-B52F-A182DEEB2C4D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff89e9d000 -     0x7fff89eb9ff7  libsystem_malloc.dylib (53.1.1) <19BCC257-5717-3502-A71F-95D65AFA861B> /usr/lib/system/libsystem_malloc.dylib
    0x7fff89eba000 -     0x7fff89f4fff7  com.apple.ColorSync (4.9.0 - 4.9.0) <9150C2B7-2E6E-3509-96EA-7B3F959F049E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff89fab000 -     0x7fff89facff7  libsystem_blocks.dylib (65) <9615D10A-FCA7-3BE4-AA1A-1B195DACE1A1> /usr/lib/system/libsystem_blocks.dylib
    0x7fff89ffc000 -     0x7fff8a008ff7  libGPUSupportMercury.dylib (11.1.2) <55BFDDBD-C196-3D24-A7DA-905A6A722DAC> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fff8a29e000 -     0x7fff8a49846f  libobjc.A.dylib (647) <759E155D-BC42-3D4E-869B-6F57D477177C> /usr/lib/libobjc.A.dylib
    0x7fff8a4e9000 -     0x7fff8a6f6ff3  com.apple.CFNetwork (720.3.13 - 720.3.13) <69E15385-5784-3912-88F6-03B16F1C1A5C> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff8a839000 -     0x7fff8a8f9ff7  com.apple.backup.framework (1.6.4 - 1.6.4) <A67CE7D7-AAE4-3AC0-86B7-EAF403853D09> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff8a972000 -     0x7fff8a9bcff7  com.apple.HIServices (1.22 - 522.1) <E8BD41E4-7747-3CAF-807A-5CA9AD16B525> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff8ab53000 -     0x7fff8ab65ff7  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <CE9FABB4-1C5D-3F9B-9BB8-5CC50C3E5E31> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
    0x7fff8abb4000 -     0x7fff8abbcfff  libsystem_dnssd.dylib (561.1.1) <62B70ECA-E40D-3C63-896E-7F00EC386DDB> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff8abbd000 -     0x7fff8ac09fff  com.apple.corelocation (1486.17 - 1615.24) <8825B3E2-E053-3E01-AE31-793443962D06> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fff8ae93000 -     0x7fff8aec0fff  com.apple.CoreVideo (1.8 - 145.1) <18DB07E0-B927-3260-A234-636F298D1917> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff8b120000 -     0x7fff8b125fff  com.apple.DiskArbitration (2.6 - 2.6) <0DFF4D9B-2AC3-3B82-B5C5-30F4EFBD2DB9> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff8b126000 -     0x7fff8b131ff7  com.apple.CrashReporterSupport (10.10 - 631) <D87A64FA-64B1-3B23-BB43-ADE173C108C6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff8b132000 -     0x7fff8b162fff  com.apple.GSS (4.0 - 2.0) <A37BAF76-C262-3292-B82D-F004CAC5F333> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff8b163000 -     0x7fff8b170ff3  com.apple.ProtocolBuffer (1 - 228.0.1) <3429EB06-9F0E-355F-B9AB-F72879177398> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff8b171000 -     0x7fff8b199fff  libRIP.A.dylib (779.11) <88434DA0-B6B8-304A-9DC0-41D3947E8734> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x7fff8b19a000 -     0x7fff8b1e7ff7  com.apple.print.framework.PrintCore (10.3 - 451.1) <DE992474-0841-38A1-B4F6-46D653E454D5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff8b1e8000 -     0x7fff8b1eaff7  libutil.dylib (38) <471AD65E-B86E-3C4A-8ABD-B8665A2BCE3F> /usr/lib/libutil.dylib
    0x7fff8b1eb000 -     0x7fff8b211fff  com.apple.ChunkingLibrary (2.1 - 163.6) <29D4CB95-42EF-34C6-8182-BDB6F7BB1E79> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff8b24a000 -     0x7fff8b24bfff  liblangid.dylib (117) <B54A4AA0-2E53-3671-90F5-AFF711C0EB9E> /usr/lib/liblangid.dylib
    0x7fff8b24c000 -     0x7fff8b24efff  libquarantine.dylib (76.20.1) <7AF90041-2768-378A-925A-D83161863642> /usr/lib/system/libquarantine.dylib
    0x7fff8b24f000 -     0x7fff8b2aafe7  libTIFF.dylib (1237) <6C8BBCA3-C233-3941-ACF9-F06C5E6EE2E6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff8b2ab000 -     0x7fff8bb33ff7  libclh.dylib (4.0.3 - 4.0.3) <6B7DEEBD-1784-3998-ABC2-8623B9E4F3EC> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
    0x7fff8bb34000 -     0x7fff8bb50fff  com.apple.GenerationalStorage (2.0 - 209.11) <9FF8DD11-25FB-3047-A5BF-9415339B3EEC> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff8bb64000 -     0x7fff8bb68fff  com.apple.CommonPanels (1.2.6 - 96) <F9ECC8AF-D9CA-3350-AFB4-5113A9B789A5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff8bb69000 -     0x7fff8bc59fef  libJP2.dylib (1237) <A24C99BF-2360-343F-BCA1-F044E78EA0DE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff8bc5a000 -     0x7fff8bc62ffb  libcopyfile.dylib (118.1.2) <0C68D3A6-ACDD-3EF3-991A-CC82C32AB836> /usr/lib/system/libcopyfile.dylib
    0x7fff8bc79000 -     0x7fff8bdb3fff  com.apple.ImageIO.framework (3.3.0 - 1237) <3C06213D-847A-3C7B-843E-6EC37113965D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff8bdb4000 -     0x7fff8bdb5fff  libDiagnosticMessagesClient.dylib (100) <2EE8E436-5CDC-34C5-9959-5BA218D507FB> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff8bde6000 -     0x7fff8be7afff  com.apple.ink.framework (10.9 - 213) <8E029630-1530-3734-A446-13353F0E7AC5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff8be7b000 -     0x7fff8be7efff  com.apple.xpc.ServiceManagement (1.0 - 1) <9E025823-660A-30C5-A568-223BD595B6F7> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff8bee5000 -     0x7fff8bf56ffb  com.apple.ApplicationServices.ATS (360 - 375.2) <2338AF23-528F-359A-847F-8B04E49E2B84> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff8bf64000 -     0x7fff8bf8eff7  libdispatch.dylib (442.1.4) <502CF32B-669B-3709-8862-08188225E4F0> /usr/lib/system/libdispatch.dylib
    0x7fff8c0c9000 -     0x7fff8c109ff7  libGLImage.dylib (11.1.2) <260A4BF3-DC45-369C-A0CD-B667F9D17179> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff8c10a000 -     0x7fff8c43bfff  com.apple.Foundation (6.9 - 1153.20) <F0FF3A5D-C5B7-34A1-9319-DE1EF928E58E> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff8c53d000 -     0x7fff8c560ff7  com.apple.framework.familycontrols (4.1 - 410) <E491AFDB-2E12-37D0-B093-6E93091019C4> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
    0x7fff8c561000 -     0x7fff8c562fff  com.apple.TrustEvaluationAgent (2.0 - 25) <2D61A2C3-C83E-3A3F-8EC1-736DBEC250AB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff8c563000 -     0x7fff8d0e4ff7  com.apple.AppKit (6.9 - 1347.57) <B214D528-7D1C-39B2-BE36-821D417A0297> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff8d0e5000 -     0x7fff8d194fe7  libvMisc.dylib (516) <6739E390-46E7-3BFA-9B69-B278562326E6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff8d195000 -     0x7fff8d1c0ff3  libarchive.2.dylib (30) <8CBB4416-EBE9-3574-8ADC-44655D245F39> /usr/lib/libarchive.2.dylib
    0x7fff8d1c6000 -     0x7fff8d1d0ff7  com.apple.NetAuth (5.2 - 5.2) <2BBD749A-8E18-35B8-8E48-A90347C1CCA7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff8d1d1000 -     0x7fff8d1dcfff  libGL.dylib (11.1.2) <BF99CC65-215A-3C7D-87D7-3F7EE6E9B3DD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff8d1dd000 -     0x7fff8d1e1fff  libcache.dylib (69) <45E9A2E7-99C4-36B2-BEE3-0C4E11614AD1> /usr/lib/system/libcache.dylib
    0x7fff8d1e2000 -     0x7fff8d1e9ff7  libcompiler_rt.dylib (35) <BF8FC133-EE10-3DA6-9B90-92039E28678F> /usr/lib/system/libcompiler_rt.dylib
    0x7fff8d62c000 -     0x7fff8d654fff  libsystem_info.dylib (459.20.1) <AEB3FE62-4763-3050-8352-D6F9AF961AE6> /usr/lib/system/libsystem_info.dylib
    0x7fff8d66d000 -     0x7fff8d676fff  libsystem_pthread.dylib (105.10.1) <3103AA7F-3BAE-3673-9649-47FFD7E15C97> /usr/lib/system/libsystem_pthread.dylib
    0x7fff8d749000 -     0x7fff8d784fff  com.apple.Symbolication (1.4 - 56045) <D64571B1-4483-3FE2-BD67-A91360F79727> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff8d8ed000 -     0x7fff8d8effff  libsystem_configuration.dylib (699.1.5) <20F3B077-179D-3CB0-A3C1-C8602D53B4DB> /usr/lib/system/libsystem_configuration.dylib
    0x7fff8de1f000 -     0x7fff8de38ff7  com.apple.CFOpenDirectory (10.10 - 187) <790ED527-EFD2-3EA6-8C97-A8C04E96EBA7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff8de39000 -     0x7fff8df2bfff  libxml2.2.dylib (26) <B834E7C8-EC3E-3382-BC5A-DA38DC4D720C> /usr/lib/libxml2.2.dylib
    0x7fff8e0d0000 -     0x7fff8e108fff  libsystem_network.dylib (412.20.3) <589A5F67-BE2A-3245-A181-0ECC9B53EB00> /usr/lib/system/libsystem_network.dylib
    0x7fff8e3b5000 -     0x7fff8e3e5fff  libsystem_m.dylib (3086.1) <1E12AB45-6D96-36D0-A226-F24D9FB0D9D6> /usr/lib/system/libsystem_m.dylib
    0x7fff8e3e6000 -     0x7fff8e400ff7  com.apple.Kerberos (3.0 - 1) <7760E0C2-A222-3709-B2A6-B692D900CEB1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff8e401000 -     0x7fff8e401ff7  liblaunch.dylib (559.20.9) <FA89A113-696E-3271-8FE1-A0D7324E8481> /usr/lib/system/liblaunch.dylib
    0x7fff8e402000 -     0x7fff8e402ff7  libkeymgr.dylib (28) <77845842-DE70-3CC5-BD01-C3D14227CED5> /usr/lib/system/libkeymgr.dylib
    0x7fff8e44c000 -     0x7fff8e498ff7  libcups.2.dylib (408.2) <E8AD18F9-61E4-3791-B840-504468C25556> /usr/lib/libcups.2.dylib
    0x7fff8e499000 -     0x7fff8e49dfff  com.apple.TCC (1.0 - 1) <CCA42EE2-3400-3444-9486-BC454E60D944> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff8e49e000 -     0x7fff8e4d8ffb  com.apple.DebugSymbols (115 - 115) <6F03761D-7C3A-3C80-8031-AA1C1AD7C706> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff8e4d9000 -     0x7fff8e4e9ff7  libbsm.0.dylib (34) <A3A2E56C-2B65-37C7-B43A-A1F926E1A0BB> /usr/lib/libbsm.0.dylib
    0x7fff8e4ee000 -     0x7fff8e501ff7  com.apple.CoreBluetooth (1.0 - 1) <8D7BA9BA-EB36-307A-9119-0B3D9732C953> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff8e502000 -     0x7fff8e52bffb  libxslt.1.dylib (13) <AED1143F-B848-3E73-81ED-71356F25F084> /usr/lib/libxslt.1.dylib
    0x7fff8e55f000 -     0x7fff8e570fff  libsystem_coretls.dylib (35.20.2) <6084A531-2523-39F8-B030-811FA1A32FB5> /usr/lib/system/libsystem_coretls.dylib
    0x7fff8e571000 -     0x7fff8e573fff  libsystem_sandbox.dylib (358.20.5) <4CF77128-6BE0-3958-B646-707FA9CE61B2> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff8e5d1000 -     0x7fff8e5eefff  libsystem_kernel.dylib (2782.20.48) <EAFD7BD0-0C30-3E7D-9528-F9916BA0167C> /usr/lib/system/libsystem_kernel.dylib
    0x7fff8e5ef000 -     0x7fff8e626ffb  com.apple.LDAPFramework (2.4.28 - 194.5) <CAFB9695-000F-34EA-8DF5-09996929C26A> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fff8e627000 -     0x7fff8e62bfff  libCoreVMClient.dylib (79.1) <201EF6DF-5074-3CB7-A361-398CF957A264> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff8e669000 -     0x7fff8e6afff7  libFontRegistry.dylib (134.1) <CE41D8C2-BEED-345C-BC4F-3775CC06C672> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff8e6b0000 -     0x7fff8e6e8fff  com.apple.RemoteViewServices (2.0 - 99) <C9A62691-B0D9-34B7-B71C-A48B5F4DC553> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff8e6e9000 -     0x7fff8e70bfff  libssl.0.9.7.dylib (106) <E23FBD0B-DFDB-30D2-B7EA-D6885610EBBA> /usr/lib/libssl.0.9.7.dylib
    0x7fff8e70c000 -     0x7fff8e9f3ffb  com.apple.CoreServices.CarbonCore (1108.6 - 1108.6) <8953580E-7857-33B2-AA64-98296830D3A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff8edcc000 -     0x7fff8eef4ff7  com.apple.coreui (2.1 - 308.6) <DEA5D3E1-D333-302B-A6CF-7643BFDFAED0> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff8eef5000 -     0x7fff8eef7ff7  com.apple.securityhi (9.0 - 55006) <5DB5773C-FC07-302C-98FE-4B80D88D481A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff8f40e000 -     0x7fff8f416fff  libsystem_platform.dylib (63) <64E34079-D712-3D66-9CE2-418624A5C040> /usr/lib/system/libsystem_platform.dylib
    0x7fff8fd5d000 -     0x7fff8fd5eff7  libodfde.dylib (22) <52D0ABCD-F464-362C-86EA-ACA10993F556> /usr/lib/libodfde.dylib
    0x7fff8fd5f000 -     0x7fff8fd83fef  libJPEG.dylib (1237) <6DB10054-5C64-32FB-83FD-E102A8F73258> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff8ffaf000 -     0x7fff900a3fff  libFontParser.dylib (134.2) <9F57B025-AB9C-31DD-9D54-2D7AB1298885> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff900a4000 -     0x7fff900a7fff  com.apple.IOSurface (97.4 - 97.4) <AE11CFBC-4D46-30F3-BEEC-4C8131079391> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff900a8000 -     0x7fff9010fff7  com.apple.framework.CoreWiFi (3.0 - 300.4) <19269C1D-EB29-384A-83F3-7DDDEB7D9DAD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff90110000 -     0x7fff90161fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <450293F7-DAE7-3DD0-8F7C-71FC2FD72627> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff90162000 -     0x7fff90467ff3  com.apple.HIToolbox (2.1.1 - 758.7) <6711FAA9-904A-3B49-9665-FC8D13B93C42> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff9055a000 -     0x7fff90669ff3  com.apple.desktopservices (1.9.3 - 1.9.3) <FEE11342-5BC4-37A7-8169-DA48BE17B9C9> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff9066a000 -     0x7fff906a5fff  com.apple.QD (301 - 301) <C4D2AD03-B839-350A-AAF0-B4A08F8BED77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff90715000 -     0x7fff90730ff7  libCRFSuite.dylib (34) <D64842BE-7BD4-3D0C-9842-1D202F7C2A51> /usr/lib/libCRFSuite.dylib
    0x7fff90731000 -     0x7fff90ac9ff7  com.apple.CoreFoundation (6.9 - 1153.18) <5C0892B8-9691-341F-9279-CA3A74D59AA0> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff90b37000 -     0x7fff90b3eff7  libCGCMS.A.dylib (779.11) <5D33FF8C-AC74-3B7B-A602-4AA470FEAF79> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
    0x7fff90b3f000 -     0x7fff90b99ff7  com.apple.LanguageModeling (1.0 - 1) <ACA93FE0-A0E3-333E-AE3C-8EB7DE5F362F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff90b9a000 -     0x7fff90c55ff7  com.apple.DiscRecording (9.0 - 9000.4.2) <4655B4B8-523D-3AE6-92A0-8486A2258B3B> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff90c56000 -     0x7fff90c63ff7  com.apple.SpeechRecognitionCore (2.1.2 - 2.1.2) <551322E2-C1E4-3378-A218-F362985E3E3C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff90c64000 -     0x7fff90c6bfff  com.apple.NetFS (6.0 - 4.0) <1581D25F-CC07-39B0-90E8-5D4F3CF84EBA> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff90c83000 -     0x7fff90cefff3  com.apple.MMCS (1.3 - 327.5) <FC998246-ED60-334D-9E94-453F35EF9C78> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
    0x7fff90cf0000 -     0x7fff90cf2ff7  libsystem_coreservices.dylib (9) <41B7C578-5A53-31C8-A96F-C73E030B0938> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff90cf3000 -     0x7fff90cfeff7  com.apple.DirectoryService.Framework (10.10 - 187) <85675744-B77D-37ED-805B-4BD0DD20845D> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x7fff90cff000 -     0x7fff90d01fff  com.apple.EFILogin (2.0 - 2) <3BA837D8-94F5-3240-9CF7-E40DC2808446> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff90d02000 -     0x7fff90e69ffb  com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <5678FC94-456A-3F5F-BA9A-10EB6E462997> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff90e98000 -     0x7fff90e9afff  com.apple.SecCodeWrapper (4.0 - 238.20.2) <C6C126F0-6BF4-3E29-A9B7-7BAD8D17EE4F> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fff910b8000 -     0x7fff910b8fff  com.apple.Carbon (154 - 157) <9BF51672-1684-3FDE-A561-FC59A2864EF8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff91249000 -     0x7fff91262ffb  com.apple.openscripting (1.4 - 162.1) <E6B42781-A556-355A-8A49-82A8D2B347FF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff91263000 -     0x7fff914e2ff7  com.apple.CoreData (111 - 526.3) <5A27E0D8-5E5A-335B-B3F6-2601C7B976FA> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff91b4d000 -     0x7fff91b7fff3  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <C6DB0A07-F8E4-3837-BCA9-225F460EDA81> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff91b8a000 -     0x7fff91b9bff7  libz.1.dylib (55) <88C7C7DE-04B8-316F-8B74-ACD9F3DE1AA1> /usr/lib/libz.1.dylib
    0x7fff91bf0000 -     0x7fff91c5cfff  com.apple.framework.CoreWLAN (5.0 - 500.35.2) <5E228544-77A9-3AA5-8355-E8F6626F50E7> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff91c5d000 -     0x7fff91ccffff  com.apple.framework.IOKit (2.0.2 - 1050.20.2) <09C0518C-90DF-3FC3-96D6-34D35F72C8EF> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff91cd0000 -     0x7fff91d66ff7  com.apple.cloudkit.CloudKit (283.67.2 - 283.67.2) <79F5AD38-61D5-30E6-96DC-974351D4195B> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fff91d8f000 -     0x7fff91da5ff7  libsystem_asl.dylib (267) <F153AC5B-0542-356E-88C8-20A62CA704E2> /usr/lib/system/libsystem_asl.dylib
    0x7fff91ddf000 -     0x7fff91df1ff7  com.apple.ImageCapture (9.0 - 9.0) <7FB65DD4-56B5-35C4-862C-7A2DED991D1F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff91f41000 -     0x7fff91f4fff7  com.apple.opengl (11.1.2 - 11.1.2) <864B35BF-1E76-382B-8D5F-38C7282621E6> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff92184000 -     0x7fff92195fff  libcmph.dylib (1) <46EC3997-DB5E-38AE-BBBB-A035A54AD3C0> /usr/lib/libcmph.dylib
    0x7fff921f2000 -     0x7fff921f6fff  com.apple.LoginUICore (3.2 - 3.2) <417954C5-1675-31A8-9631-6B56E9AA3E93> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
    0x7fff921f7000 -     0x7fff921f8ffb  libremovefile.dylib (35) <3485B5F4-6CE8-3C62-8DFD-8736ED6E8531> /usr/lib/system/libremovefile.dylib
    0x7fff921f9000 -     0x7fff92205ff7  com.apple.OpenDirectory (10.10 - 187) <1E07769D-68DE-3BF2-8E9E-A1E98BF70D1B> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff92206000 -     0x7fff92220ff3  com.apple.Ubiquity (1.3 - 313) <DF56A657-CC6E-3BE2-86A0-71F07127724C> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
    0x7fff92221000 -     0x7fff92223fff  libCVMSPluginSupport.dylib (11.1.2) <6EFEC4A6-2EAC-3C27-820E-C28BE71B9FCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff92224000 -     0x7fff92224fff  com.apple.CoreServices (62 - 62) <C69DA8A7-B536-34BF-A93F-1C170E2C6D58> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff9225c000 -     0x7fff92318ff7  libcrypto.0.9.7.dylib (106) <E0A293F8-0799-38DC-9ADA-1AD705EDD12B> /usr/lib/libcrypto.0.9.7.dylib
    0x7fff9231d000 -     0x7fff9231ffff  libRadiance.dylib (1237) <9B048776-53BB-3947-8ECE-9DDA804C86B2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff92320000 -     0x7fff9236fff7  libstdc++.6.dylib (104.1) <803F6AC8-87DC-3E24-9E80-729B551F6FFF> /usr/lib/libstdc++.6.dylib
    0x7fff92370000 -     0x7fff9237bfff  libcommonCrypto.dylib (60061) <D381EBC6-69D8-31D3-8084-5A80A32CB748> /usr/lib/system/libcommonCrypto.dylib
    0x7fff9237c000 -     0x7fff9248eff7  libvDSP.dylib (516) <151B3CCB-77D3-3715-A3D0-7C74CD5C7FFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff924be000 -     0x7fff924dbfff  com.apple.MultitouchSupport.framework (263.9.1 - 263.9.1) <6ABD3AE2-DF6A-3AB2-994B-9C0FB42CE2B7> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff934a3000 -     0x7fff934a9fff  com.apple.speech.recognition.framework (5.0.9 - 5.0.9) <BB2D573F-0A01-379F-A2BA-3C454EDCB111> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff934aa000 -     0x7fff93509fff  com.apple.AE (681.2 - 681.2) <181B3B06-2DC6-3E4D-B44A-2551C5E9CF6F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff9350a000 -     0x7fff9350bfff  libsystem_secinit.dylib (18) <581DAD0F-6B63-3A48-B63B-917AF799ABAA> /usr/lib/system/libsystem_secinit.dylib
    0x7fff93517000 -     0x7fff9356bfff  libc++.1.dylib (120) <1B9530FD-989B-3174-BB1C-BDC159501710> /usr/lib/libc++.1.dylib
    0x7fff9356c000 -     0x7fff9359dff7  com.apple.ProtectedCloudStorage (1.0 - 1) <D0903EA8-D861-3488-BCF5-9D8E7C6D01FA> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff9359e000 -     0x7fff935a3ff7  libunwind.dylib (35.3) <BE7E51A0-B6EA-3A54-9CCA-9D88F683A6D6> /usr/lib/system/libunwind.dylib
    0x7fff935a4000 -     0x7fff935adff7  libsystem_notify.dylib (133.1.1) <61147800-F320-3DAA-850C-BADF33855F29> /usr/lib/system/libsystem_notify.dylib
    0x7fff9363d000 -     0x7fff936acfff  com.apple.SearchKit (1.4.0 - 1.4.0) <80883BD1-C9BA-3794-A20E-476F94DD89A9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff936dd000 -     0x7fff936e1ff7  libGIF.dylib (1237) <8A40FED5-FA90-3E76-A359-CD974C43A962> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff93746000 -     0x7fff9378cff7  libauto.dylib (186) <A260789B-D4D8-316A-9490-254767B8A5F1> /usr/lib/libauto.dylib
    0x7fff938d2000 -     0x7fff93946ffb  com.apple.securityfoundation (6.0 - 55126) <42589E18-D38C-3E25-B638-6E29740C224C> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff93947000 -     0x7fff93947fff  com.apple.Cocoa (6.8 - 21) <EAC0EA1E-3C62-3B28-A941-5D8B1E085FF8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff939da000 -     0x7fff939e5fff  com.apple.CommerceCore (1.0 - 376.24) <1B2B5206-43B6-3CA4-B057-8A7252CE6902> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x7fff939e6000 -     0x7fff93a6afff  com.apple.PerformanceAnalysis (1.0 - 1) <599AED3E-B689-3C40-8B91-93AD36C97658> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff93a99000 -     0x7fff93b7dfff  libcrypto.0.9.8.dylib (52.20.2) <977DA067-2588-3BF8-A7B2-F08FC6E9088F> /usr/lib/libcrypto.0.9.8.dylib
    0x7fff93b7e000 -     0x7fff93c1cfff  com.apple.Metadata (10.7.0 - 917.35) <8CBD1D32-4F4B-3F9A-AC65-76F2B5376FBF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff93c3c000 -     0x7fff93c61fff  libPng.dylib (1237) <F5652650-87ED-3D53-9E59-A897DFA41DD0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff93c62000 -     0x7fff93d54ff7  libiconv.2.dylib (42) <2A06D02F-8B76-3864-8D96-64EF5B40BC6C> /usr/lib/libiconv.2.dylib
    0x7fff93d55000 -     0x7fff93dcdff7  com.apple.SystemConfiguration (1.14 - 1.14) <06A8405D-53BA-30A9-BA8A-222099176091> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff93ed7000 -     0x7fff93f79fff  com.apple.Bluetooth (4.3.4 - 4.3.4f4) <A1120885-F31B-3C13-9B0D-2589F391CC7A> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff93f7a000 -     0x7fff94093ffb  com.apple.CoreText (352.0 - 454.6) <D45790B0-E1A3-3C7D-8BA2-AB71D2CFA7FB> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff94181000 -     0x7fff941a9fff  libxpc.dylib (559.20.9) <D35D0DB2-D7BD-3BE4-8378-062BFE545E1D> /usr/lib/system/libxpc.dylib
    0x7fff941aa000 -     0x7fff941d4fff  GLRendererFloat (11.1.2) <87953360-E0E4-3523-8EC3-2062C26C7FD2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fff941d5000 -     0x7fff94200fff  libc++abi.dylib (125) <88A22A0F-87C6-3002-BFBA-AC0F2808B8B9> /usr/lib/libc++abi.dylib
    0x7fff94201000 -     0x7fff94203ffb  libCGXType.A.dylib (779.11) <51607E77-F183-3CC2-A78C-238AFBDF6262> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x7fff94204000 -     0x7fff94253ff7  com.apple.opencl (2.4.2 - 2.4.2) <4A9574ED-15CF-3EBB-B4C0-D30F644D6C74> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff94254000 -     0x7fff942ddff7  com.apple.CoreSymbolication (3.1 - 57020.1) <85707039-0C8A-3409-B0B5-153431CC1841> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff942de000 -     0x7fff9470efff  com.apple.vision.FaceCore (3.1.6 - 3.1.6) <C3B823AA-C261-37D3-B4AC-C59CE91C8241> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff9470f000 -     0x7fff94a42ff7  libmecabra.dylib (666.7) <0ED8AE5E-7A5B-34A6-A2EE-2B852E60E1E2> /usr/lib/libmecabra.dylib
    0x7fff94a43000 -     0x7fff94a4eff7  com.apple.speech.synthesis.framework (5.3.3 - 5.3.3) <A5640275-E2A6-3856-95EF-5F0DC440B10C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff94a58000 -     0x7fff94e65ff7  libLAPACK.dylib (1128) <F9201AE7-B031-36DB-BCF8-971E994EF7C1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff94ea2000 -     0x7fff94eafff7  libbz2.1.0.dylib (36) <2DF83FBC-5C08-39E1-94F5-C28653791B5F> /usr/lib/libbz2.1.0.dylib
    0x7fff94eb0000 -     0x7fff9511aff7  com.apple.security (7.0 - 57031.20.26) <6568520A-587D-3167-BB79-60CE6FEADC64> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff953e7000 -     0x7fff95486e27  com.apple.AppleJPEG (1.0 - 1) <6627DDD9-A8FE-3968-B23A-B6A29AA3919A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff95487000 -     0x7fff9566cff7  libicucore.A.dylib (531.48) <3CD34752-B1F9-31D2-865D-B5B0F0BE3111> /usr/lib/libicucore.A.dylib
    0x7fff9566d000 -     0x7fff95670fff  com.apple.help (1.3.3 - 46) <CA4541F4-CEF5-355C-8F1F-EA65DC1B400F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff95671000 -     0x7fff95686ff7  com.apple.AppContainer (4.0 - 238.20.2) <2AA2EF49-9F38-31F6-8B08-8CC7C26F57F3> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 5
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 2380
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=250.5M resident=164.1M(66%) swapped_out_or_unallocated=86.4M(34%)
Writable regions: Total=8.4G written=3.8G(45%) resident=5.7G(67%) swapped_out=0K(0%) unallocated=2.8G(33%)
REGION TYPE                      VIRTUAL
Activity Tracing                   2048K
CG backing stores                  15.4M
CG image                             12K
CG shared images                    240K
CoreImage                             8K
CoreUI image data                    44K
IOKit                               1.6G
Kernel Alloc Once                     8K
MALLOC                              4.6G
MALLOC (admin)                       32K
MALLOC_LARGE (reserved)            75.0M        reserved VM address space (unallocated)
Memory Tag 242                       12K
Memory Tag 249                      156K
OpenCL                               16K
OpenGL GLSL                         256K
STACK GUARD                        56.1M
Stack                              17.7M
VM_ALLOCATE                         2.1G
__DATA                             58.4M
__GLSLBUILTINS                     2588K
__IMAGE                             528K
__LINKEDIT                         86.9M
__TEXT                            163.6M
__UNICODE                           552K
mapped file                        71.8M
shared memory                       196K
TOTAL                               8.8G
TOTAL, minus reserved VM space      8.8G
Model: iMac14,2, BootROM IM142.0118.B09, 4 processors, Intel Core i7, 3.5 GHz, 32 GB, SMC 2.15f7
Graphics: NVIDIA GeForce GTX 780M, NVIDIA GeForce GTX 780M, PCIe, 4096 MB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x111), Broadcom BCM43xx 1.0 (7.15.166.24.3)
Bluetooth: Version 4.3.4f4 15601, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD ST3000DM001, 3 TB
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple USB SuperDrive
USB Device: USB2.0 Hub
Thunderbolt Bus: iMac, Apple Inc., 23.10
74
just looked at the messages contact me email so we can set up everything  need instructions on how to setup Skype I do have builtin iMessages for apple computer so Skype should be easy. will be standing by to here from you and will research the how to Skype ...
captbullett@gmail.com
www.skype.com and Download it for MAC, very easy. Really!
