Topic: A350 set
today I made a set for the A350.
A couple of important notes:
- The set file has no name, because the "description" field in planemaker is empty. I recommend you enter "A350" in the description field in planemaker. To do so, open the A350 in planemaker and go to standard -> viewpoint -> description field. After you entered a description, name the set file exactly the same. If you called the A350 in planemaker "A350", then your set file must be "A350.set".
- To load the A350 with passengers and cargo, one must call the luggage loader, the stairs and the bus of the A350 build in ground service. If you don't want to use both ground service vehicles, you can select the option "plane at gate". That way you don't have to call the stairs and the bus. Only the luggage loader is required in this case. To load fuel, you still have to call the build in fuel truck.
I'm working on getting the datarefs, so one can use the ground service plug in without the A350 build in plug in. I keep you updated.
