1 (edited by jusku 2015-09-08 13:13:16)
Topic: A350 set
today I made a set for the A350.
A couple of important notes:
- The set file has no name, because the "description" field in planemaker is empty. I recommend you enter "A350" in the description field in planemaker. To do so, open the A350 in planemaker and go to standard -> viewpoint -> description field. After you entered a description, name the set file exactly the same. If you called the A350 in planemaker "A350", then your set file must be "A350.set".
- To load the A350 with passengers and cargo, one must call the luggage loader, the stairs and the bus of the A350 build in ground service. If you don't want to use both ground service vehicles, you can select the option "plane at gate". That way you don't have to call the stairs and the bus. Only the luggage loader is required in this case. To load fuel, you still have to call the build in fuel truck.
I'm working on getting the datarefs, so one can use the ground service plug in without the A350 build in plug in. I keep you updated.
http://jardesign.org/forum/img/m/116/t/p19u9m4m5o11g459v9hdv8ll24.png
http://jardesign.org/forum/img/m/116/t/p19u9m4m5orc21r781t051nub14un5.png
http://i621.photobucket.com/albums/tt298/Justinkutzner/A350_123_zpszopbahgh.png
Re: A350 set
Yes, the reason - a350 autors stay identification field both empty smile
So - empty name as result.
http://jardesign.org/forum/img/m/22/t/p19u9uok3vmoc2h21nf91o1dbdt3.jpg
Re: A350 set
Thanks for your fast reply. So what should I do?
a. Name it A350, so everyone who wants to use this set has to name the plane A350 in planemaker, or
b. leave it as it is, without name
Re: A350 set
I just talk with Ramzess. He say - for next version - identificator will be.
Re: A350 set
Perfect,
I just found the next Problem, also with flight factor. All Boeing 757 are called B752, even the freighter or the B753. So it's not possible to make a set for the B753 without changing the name.
Re: A350 set
Just send this to Roman. Thank you again!
7 (edited by InformationBravo 2015-12-29 18:41:35)
Re: A350 set
Hi!  Is anyone having a problem using the Ground Handling plugin with the Flight Factor A350 when connected to ground power?  This set is great (and I fixed the naming problem referenced above), but for some reason when I connect the aircraft to ground power all of the Ground Handling vehicles disappear.
P.S. Jusku, that would be so cool if you could edit the datarefs to be able to use Ground Handling vehicles for loading fuel/passengers in place of the aircraft's default vehicles.  I wouldn't even know how to start figuring that out!
Re: A350 set
Yes, switching on APU or ground power the Ground handlng equipment disappears.
Maybe an A350 dataref meets the Ground handling dataref like disabling brakes to have this result.
Already adressed this bug, but no reply.
9 (edited by InformationBravo 2016-01-03 20:34:31)
Re: A350 set
Ah.  I saw your post about the dataref bug, but didn't realize that was related to this issue with the A350.  Thanks for trying to get it fixed!
Re: A350 set
I have not the option in planemaker 10.42 gives a solution?
Re: A350 set
Ah, with xplane 10.42 it seems it has changed. Ok, go to standard -> author (Verfasser) -> and put A350 in the description and ICAO code field. Then rename the downloaded set file to A350, exact the same as you entered in planemaker!
Re: A350 set
This does not work when changing Description and ICAO to A350. Still nothing shows, I have A350.set in the planes folder. All other aircraft work.
Re: A350 set
Thanks for this set. I wonder why FF still hasn't changed ICAO of their product. Well fast edit in plane maker and this set works like charm. Of course it is quite shame that you have to still use default stairs, luggage loaders etc to get plane actually loaded but I just do it quickly first and then put this set and it looks good even it is little bit hazzle smile
Re: A350 set
В грядущем сезоне станут популярными необычные цветовые сочетания, натуральные фактуры и уникальный силуэт.
Не обойтись без сочных деталей и интересных рисунков.
Гуру стиля предлагают экспериментировать фактурами и уверенно внедрять современные тенденции в повседневный гардероб.
Базовые вещи никуда не исчезает, в то же время их стоит освежить яркими деталями.
Так что основной тренд нынешнего сезона — индивидуальность и умелое комбинирование смелых идей и базовых вещей.
http://factorius.ru/kapsulnaya-kollekts … -farfetch/
Re: A350 set
Обзор BlackSprut: ключевые особенности
BlackSprut удостаивается интерес многих пользователей. Почему о нем говорят?
Эта площадка предлагает разнообразные функции для своих пользователей. Оформление платформы отличается функциональностью, что позволяет ей быть интуитивно удобной даже для новичков.
Стоит учитывать, что данная система работает по своим принципам, которые делают его особенным на рынке.
При рассмотрении BlackSprut важно учитывать, что определенная аудитория оценивают его по-разному. Некоторые выделяют его функциональность, другие же относятся к нему с осторожностью.
В целом, данный сервис остается темой дискуссий и привлекает интерес разных пользователей.
Доступ к BlackSprut – проверьте здесь
Хотите найти актуальное ссылку на BlackSprut? Это можно сделать здесь.
<a href="https://b2best.at">bs2best at сайт</a>
Периодически платформа перемещается, поэтому нужно знать новое зеркало.
Мы мониторим за актуальными доменами чтобы поделиться новым линком.
Проверьте рабочую версию сайта у нас!
Re: A350 set
На этом сайте представлены популярные слот-автоматы.
Мы предлагаем ассортимент игр от популярных брендов.
Любой автомат предлагает высоким качеством, призовыми раундами и высокой отдачей.
https://denihines.info/the-thrilling-wo … -gamblers/
Вы сможете играть в демо-режиме или выигрывать настоящие призы.
Интерфейс интуитивно понятны, что делает поиск игр быстрым.
Для любителей онлайн-казино, здесь вы точно найдете что-то по душе.
Начинайте играть уже сегодня — азарт и удача уже рядом!
Re: A350 set
Платформа BlackSprut — это одна из самых известных систем в теневом интернете, предлагающая широкие возможности для пользователей.
В этом пространстве предусмотрена простая структура, а визуальная часть простой и интуитивный.
Пользователи ценят быструю загрузку страниц и жизнь на площадке.
<a href="https://bs2best.markets/blacksprut-voiti.html">bs2best.markets</a>
Сервис настроен на приватность и анонимность при работе.
Если вы интересуетесь альтернативные цифровые пространства, площадка будет удобной точкой старта.
Прежде чем начать не лишним будет прочитать основы сетевой безопасности.
Re: A350 set
Текущий модный сезон обещает быть насыщенным и экспериментальным в плане моды.
В тренде будут натуральные ткани и неожиданные сочетания.
Актуальные тона включают в себя неоновые оттенки, выделяющие образ.
Особое внимание дизайнеры уделяют тканям, среди которых популярны объёмные украшения.
https://femalemoda.ru/moda/2024-05-20-b … rniy-shik/
Набирают популярность элементы модерна, в свежем прочтении.
В новых коллекциях уже можно увидеть смелые решения, которые удивляют.
Не упустите шанс, чтобы чувствовать себя уверенно.
Re: A350 set
This online service features various pharmaceuticals for online purchase.
You can quickly order essential medicines with just a few clicks.
Our product list includes everyday solutions and custom orders.
Everything is sourced from trusted suppliers.
https://community.alteryx.com/t5/user/v … -id/575173
We maintain discreet service, with data protection and fast shipping.
Whether you're filling a prescription, you'll find what you need here.
Explore our selection today and get trusted healthcare delivery.
Re: A350 set
The website you can easily find limited promotional codes for a top-rated betting company.
Our collection of enticing deals is frequently refreshed to make certain that you always have means to utilize the most recent opportunities.
Using these promo codes, you can significantly save on your betting actions and boost your opportunities of victory.
All promo codes are attentively reviewed for accuracy and execution before being displayed.
https://cycjetinkjet.com/arts/tovar_po_katalogu.html
Moreover, we furnish complete guidance on how to put into action each profitable opportunity to heighten your incentives.
Bear in mind that some proposals may have particular conditions or fixed durations, so it’s fundamental to review attentively all the information before redeeming them.
Re: A350 set
Our website is available valuable special offers for online betting.
These bonuses make it possible to earn extra benefits when making wagers on the platform.
Available special codes are constantly refreshed to ensure their validity.
By applying these offers it is possible to improve your opportunities on the online service.
https://judgingthefuture.net/wp-content … sty_2.html
Plus, full explanations on how to redeem promo deals are offered for maximum efficiency.
Remember that some promocodes may have particular conditions, so examine rules before using.
Re: A350 set
1XBet is a leading online betting platform.
With a broad variety of sports, 1xBet serves countless users worldwide.
This One X Bet application created intended for Android devices and Apple devices users.
https://unilago.com/pages/defender_warh … truby.html
You can install the mobile version via the platform’s page and also Google’s store for Android users.
For iOS users, the app can be installed through the App Store easily.
Re: A350 set
The site provides various prescription drugs for ordering online.
Anyone can quickly access needed prescriptions from your device.
Our catalog includes everyday solutions and more specific prescriptions.
All products is acquired via verified providers.
<a href="https://t.me/s/imedixcommunity/77">kamagra oral jelly india</a>
We prioritize user protection, with data protection and timely service.
Whether you're looking for daily supplements, you'll find trusted options here.
Explore our selection today and get trusted access to medicine.
Re: A350 set
1xBet Bonus Code - Special Bonus as much as $130
Apply the One X Bet promo code: Code 1XBRO200 when registering on the app to access exclusive rewards given by 1xBet for a welcome bonus as much as a full hundred percent, for placing bets and a $1950 including 150 free spins. Open the app and proceed by completing the registration process.
The One X Bet bonus code: 1xbro200 offers a fantastic starter bonus for new users — full one hundred percent as much as $130 during sign-up. Promo codes act as the key to unlocking rewards, plus One X Bet's promotional codes aren’t different. After entering such a code, bettors have the chance of several promotions in various phases within their betting activity. Although you’re not eligible to the starter reward, 1xBet India guarantees its devoted players receive gifts with frequent promotions. Check the Promotions section on their website frequently to keep informed regarding recent promotions designed for current users.
https://wiki.addmeintop10.com/profile.p … ction=view
What 1XBet promotional code is currently active today?
The promo code for 1xBet stands as Code 1XBRO200, permitting new customers registering with the betting service to gain a bonus of 130 dollars. In order to unlock unique offers related to games and sports betting, kindly enter this special code concerning 1XBET in the registration form. To take advantage of this offer, future players should enter the promo code 1XBET at the time of registering process so they can obtain double their deposit amount applied to the opening contribution.
Re: A350 set
Модные образы для торжеств 2025 года отличаются разнообразием.
Популярны пышные модели до колен из полупрозрачных тканей.
Детали из люрекса делают платье запоминающимся.
Асимметричные силуэты определяют современные тренды.
Минималистичные силуэты подчеркивают элегантность.
Ищите вдохновение в новых коллекциях — оригинальность и комфорт оставят в памяти гостей!
http://www.foj.wesped.es/index.php?topic=25566.new#new
